HP Officejet PRo L7500 All-in-One I have set the fax confirmation to be printed on the first page of the fax however it won't do it.
  • 1 more comment
  • inch123 Oct 21, 2008
    I can receive confirmation a fax has been sent but I would like the confirmation to be printed on part of the lead page. There is a setting for this however it doesn't seem to work. Any suggestions?
  • inch123 Oct 22, 2008
    it has a function in the confirmation part that says 'image on fax send report.' i'm assuming that this is the function i'm looking for. so instead of a plain confirmation coming out that says how many, what fax number sent to etc etc, it also shows a part copy of the lead page.
    could also be that i'm reading it wrong. :)
  • justitia Mar 20, 2009
    I have the exact same problem as inch123 and the solution leroyal provides cannot be correct. I know other HP machines that shows a part of the sent page on the confirmation. And the Officejet L7500 does have that option in the manual and there's even a separate menu in the settings for it! Anyone else knows what could be wrong?
    Genius:
  • 2,120 Answers
I don't think HP's have that function.
Scroll through the menus to find SHOW IMAGE.
Posted on Oct 21, 2008
How to I turn off the automatic printing of the fax logs.
To change fax confirmation
1. Press Setup.
2. Press Print Report, and then Fax Confirmation.
3. Press the right arrow button to select one of the following, and then press OK.
Off - Does not print a fax confirmation report when you send and receive
faxes successfully. This is the default setting.
On Fax Send - Prints a fax confirmation report for every fax you send.
On Fax Receive - Prints a fax confirmation report for every fax you receive.
Send & Receive - Prints a fax confirmation report for every fax you send and receive.
May 03, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
How to turn fax send report on
the Officejet Pro 8500 Series can still do a fax confirmation page, you just have to set it up. Press the Setup button (looks like wrench), then 2. Print Report, then 1. Fax Confirmation. From there you can select to print it out on Send, Recieve, or Both.
Nov 20, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
WHY DO I GET A BLANK PAGE AFTER EACH FAX?
The fax machine that is sending you the fax may be also sending a confirmation page that is not needed or compatible with your machine.
I have an older machine that prints a confirmation page after each fax. People on the other end sometimes receive a blank page after each fax that I send them while my machine prints a mostly blank page with only a single line of text at the top with the date and time.
Feb 01, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
How can I remove the sending fax number on my transmissions on HP
Check the HP Officejet Pro L7300/L7500/ L7600/L7700 All-in-One series
User Guide
(page 83):
"Configure the fax header:
The fax header prints your name and fax number on the top of every fax you send. HP
recommends that you set up the fax header by using the software that you installed with the device. You can also set up the fax header from the control panel, as described here.
NOTE: In some countries/regions, the fax header information is a legal
requirement.
To set or change the fax header
1. Press Setup.
2. Press Basic Fax Setup, and then press Fax Header.
3. Enter your personal or company name using the numeric keypad, and then press OK.
4. Enter your fax number by using the numeric keypad, and then press OK.
To set or change the fax header via the embedded Web server
▲ Select the Settings tab, select Fax from the left pane, select the Basic sub-tab,
and then enter the Fax Header Name and Fax Number. Click the Apply button."
Sep 18, 2009 | HP OfficeJet K80 All-In-One InkJet Printer
I have officejet pro L7500, and i cant send a fax
put two pauses after the phone number then the extension
Jul 04, 2009 | Office Equipment & Supplies
HP OfficeJet Pro l7500 won't print. Printer queue shows 5 jobs with error on first 2. I tried twice after rebooting the computer.How to print , or how to download proper driver? SB
Officejet Pro L7500 is giving me error message that it can see the black and yellow print head I have replaced it and it is still giving me the same error.
Is there a way to clean it with out having to have it taken in to be repaired?
Jun 10, 2009 | HP Office Equipment & Supplies
Want to set Draft as Default Print Setting
Under Printers and Faxes in Control Panel (Classic View) right click on the printer and select properties then under Printing Preferences set Draft and click OK - this will now be the default setting.
Dec 11, 2008 | HP Officejet Pro L7680 All-In-One Printer
HP OFFICE JET PRO L7500/L7600/L7700
my hp office jet pro l7500 indicates the ink has expired in all cartages but the cartgages are new because they were just put in . Before the same error code came up and so bought new cartages. Also the door to the cartages will not stay closed without tape.
Nov 29, 2008 | HP Officejet Pro L7480 All-in-One...
Mirror images only
hopefully you have fixed this problem by now----if not, go to control panel bt clicking start then settings or could be start then control panel. WHAT YOU ARE LOOKING FOR IS THE PRINTERS AND FAXES FOLDER. once you have found that, right click on the HP Officejet Pro L7500 Series (or whatever your printer name is) and choose printing preferences. go to the advance tab. look for mirror image and click on it you will be given a small drop down to toggle it from on to off----choose off and the click on apply and then OK.
Aug 12, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
348 people viewed this question
k24674
jasbo
jasbo
