Question about Black & Decker 22" Electric Hedge Trimmer
Roller pin keeps popping out
The roller pin in my HedgeHog keeps popping out of the gear case after 10 - 15 minutes of use and disconnects the gear from the armature.  Any suggestions as to how I can keep it down?  The rest of the machine is fine.
Thanks
HP Pro 8500 printer will not feed paper keep getting "load paper" error even though paper in tray; found small white "gear" in tray.
If the gear is broken, you most likely need to replace the pick up roller which is extremely hard or almost impossible. You may try to see if the error is really with the broken gear, or you if you just have a dusty roller that picks up paper by checking if the rollers is actually spinning when it is trying to pick up the paper.
To see what the issue is with gear or roller, try the following:
1. Remove the output paper tray and paper from the loading tray.
2. Send a copy job or print job through.
3. have a flashlight to shine light on the pick up roller and se if it spins. Try touching with your hand to be sure.
4. If the roller spins, put some alcohol on a cloth or paper towel and clean the rubber rollers.
5. Wait a few minutes, load paper and try sending copy job again.
If the roller is not spinning, then you have a problem with gears for sure.
http://www.303electroncs.com/
our eBay parts store: 303Electronics eBay Stores
If you need further help, I’m available over the phone at https://www.6ya.com/expert/alex_22751bbefa74c3d0
Mar 30, 2017 | HP Officejet Pro 8500 Wireless All-In-One...
C3202 error
C 3201;C 3202 Fusing motor malfunction.Remove the fusing unit and inspect the upper and lower fuser roller and the drive mechanism gears.If is OK reset the error.To reset turn OFF the copier.Press and keep pressed the Uility key and turn ON the copier.Keep pressed the Utility key and wait to displayed Trouble Reset message.Release the key and touch the message then turn OFF the copier.Wait 1 minutes and turn ON.
Apr 03, 2013 | Konica Minolta Office Equipment & Supplies
HOW TO CLEAN ROLLERS OF LEXMARK E120
Hi andjam01,
Please follow the steps below on how to clean the roller of Lexmark E120.
1. Remove the fill plug from the right side of the cartridge. (Developer roller facing away from you). Dump out any remaining toner from the hopper.
2. On the left side, remove the two small screws and the gear cover.
3. Remove the center screw on the developer roller cover.
4. Lift up the developer roller cover from the center, and remove. Be careful not to damage the plastic pins on the cover.
5. Remove the doctor blade spring.
6. The doctor blade is now loose. Carefully lift it out, watching the contact spring on the right side. Also, be careful not to damage the retaining blade that is located under the doctor blade.
7. On the large black drive gear, there is a locking star washer pressed onto the shaft. With a small pair of wire cutters, cut the old washer off, and remove. You can try to bend up the different legs of the washer, but that is very time consuming, and most likely at least one leg will break anyway and the washer will still have to be replaced.
8. Remove the large black drive gear. Make sure you don't loose the small flat washer from under where the star washer was.
9. On the white developer roller gear, take the tips of your small wire cutters, and place them into the two small holes. Spin the gear so the metal shaft is in the slot on the opposite side of the gear. Remove the gear.
10. Remove all the gears.
11. Remove the three screws and gear alignment plate.
12. With a small flat head jeweler's screwdriver, pry off the metal lock from the developer roller bushing.
13. Turn the developer roller bushing so the plastic tab is facing up.
14. Lift the developer roller out of the cartridge. The bushing will come off with the roller.
15. . Clean out any remaining toner from the hopper. Make sure the developer roller retaining blade does not get damaged!
-->Wipe the developer roller down with a clean lint free cloth. Testing is ongoing, but for now, do not use any chemicals to clean it.
Hope it helps.
Thank you for using FixYa.
Apr 16, 2011 | Lexmark E120 Laser Printer
Brush roll won't turn on for the shark NV22L vacuum. the light on the brush roll is dark, not red or green
Atthe bottom of the vacuuam are screws to take off...two of them are near the rear wheel assembly....two of them are behind the front mini wheels (just pry the front mini wheels so that they pop out...they pop back in)
Remove all of the screws. Remove the bottom from the top..they come apart in two pieces. Ceck the belt on the bottom piece. Slide the roller out starting from the end opposite from the motor end. With the roller off, slacken the the belt so that it misses the gear on the motor (you will have to hold it with your hand). Plug in the vacuum. Turn the power on to the roller on position. The motor should work and the green light should be on. If the motor doesn't work, then it is defective. If it does work, turn off, unplug and shoot the gear and the two ends of the roller with WD-40. reassemble. good luck.
Feb 10, 2011 | Shark Helmet NV22L Shark Navigator Upright...
I have a hp laserjet 4250 printer it had a paper jam in tray 2 i have cleared the jam but it keeps saying i still have the jam in tray 2
There is still paper stuck in the printer. try lifting the printer off of tray 2 to inspect it or here it is straight from the service manual...
Jams in tray 2
Table 7-10 Causes of tray 2 jams
Cause Solution
The feed or separation rollers are dirty, worn, or damaged. Clean the rollers. If they are dirty after cleaning, or if they are
worn or damaged, replace the rollers.
The pickup roller is worn or damaged. Replace the pickup roller.
The tray 2 paper pickup assembly drive gears are damaged
or the assembly is defective.
Check the drive gears in the paper pickup drive assembly.
Replace the pickup drive assembly if the gears are
damaged. See Paper-pickup drive assembly.
The tray 2 pickup solenoid (SL101) is damaged. 1 Disconnect the connector for the tray pickup solenoid
from the dc controller PCA (location J92).
2 Measure the resistance between the cable connectors.
3 If the measured resistance is not approximately
160 ohms for the HP LaserJet 4200/4300, or 110 ohms
for the HP LaserJet 4250/4350, replace the tray 2
pickup solenoid.
The tray 2 lifter-drive assembly or the stack position
sensor (PS107) is defective.
Replace the lifter-drive assembly. See Tray 2 lifter-drive
assembly and/or Printer switches and sensors.
The dc controller PCA is defective. Replace the dc controller PCA. See Dc controller PCA.
Dirty, worn, or deformed pick-up roller, cassette separation
roller, and cassette feed roller.
Clean the rollers if they are dirty. Replace any worn or
deformed rollers. The cassette separation roller and the
cassette feed rollare are to be replaced together.
Damaged gears in the cassette pick-up drive unit. Move the gears in the cassette pick up drive unit. If the
gears are not rotating correctly, or are damaged or worn,
replace the cassette pick-up drive unit.
Dec 25, 2010 | HP LaserJet 4250 Printer
Rear passenger side window just fell down and won't go back up. is this possible?
Yes its possible, the roller has come out of the track You would have to remove the arm rest and panel screws off and remove the cover with the door open unsnap the clips on the door and let the door hang down use a flashlight to see the roller that's off track pick the glass up and slid into the glass guides and move the window up till you get the roller into the track, have the key on in case you need to raise the window up or down to get it to go into the track, if the roller is broke you can buy one at a junk yard, if the roller is ok then the stop pin may have fallen out and you will have to use a roll pin to keep the roller from coming out of the track. Hope this helps.
May 14, 2010 | 2004 Cadillac CTS
Telescopic handle problem in swissgear lap top roller suitcase.
The problem area is inside the riveted fabric. You may have to destroy your Swiss Gear case in order to salvage it.
Nov 22, 2017 | Swiss Gear by Wenger Wenger Gear Granada...
The brushes are not spinning. I get suction, but the brushes don't turn.
Your belt has probably broken. Here is a link to the belt you need:
Dyson DC17 Belt
And here is instructions on how to change it:
1. Loosen 3 screws from bottom plate using flathead screwdriver or coin edge and remove it.
2. Wiggle roller until it pulls straight out.
3. Squeeze new belt and loop it over metal drive gear (you'll easily see the gear).
4. Keeping belt on gear, insert edge of roller through belt and rotate the roller while pushing it through belt until it is inside the belt, then continue rotating roller and sliding it over until belt is in position over gears on roller.
5. Insert roller into slots on that it came out of, reattach bottom cover and its done.
Nov 27, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
How to replace belt on Dyson DC17
Preface: Dyson folks were great, answer so simple I was embarassed after I called. 5 minute fix.
Mar 21, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Looking for a drive gear for a Lexmark LX83
All I can say is good luck! Parts for ink jet printers are nearly impossible to get. They're so cheap that it's not worth it to repair them.
Feb 21, 2009 | Lexmark X83 All-In-One InkJet Printer
Black & Decker 22" Electric Hedge Trimmer Logo
55 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
