Question about Weiser Lock Powerbolt 1000 Lock
POWERBOLT REPLACED BATTERIES AS SYSTEM APPEARS DEAD. DOES NOT RECOGNISE SECURITY CODE. IS THERE A RESET
  • 14 Answers
  • Take out batteries and unplug powerstrip.
  • Let it sit for 1 minute, then put the batteries back in and wait another minute.
I contacted customer support... they tell me the FAQ information on their own website is incorrect. The opposite is true, therefore the following is correct:
  • If it does not beep, the powerboard needs to be replaced
  • If the unit continues to beep, the keypad needs to be replaced
Here in Canada, they will send you a new one within 3-5 days free of charge. Call customer support:
Canada: 800-501-9471
US: 800-677-LOCK
-=dån=-
Posted on Sep 14, 2009
Any four digit code works no matter how many times you reset code. how do you erase all codes and start fresh?
How do I change the access code (and delete my old code) on my Powerbolt 1000?
The steps below are to change your access code to a new code. This will also remove any previous codes stored in the Powerbolt's memory.
pb1000programbutton
  1. Manually put the bolt in the extended (lock) position. Press the PROGRAM button once, enter your new 4 - 8 digit code and then press the LOCK button.
  2. Press the PROGRAM button twice, enter the same new code and then press the LOCK button once.
  3. Press the PROGRAM button three times, enter the same new code and then press LOCK once.
If your old code still remains in the unit, you will need to perform a hard reset of the unit. To perform a hard reset of the unit, remove all four batteries and leave them out for 1 hour. After the hour has passed, you may re-enter the batteries.
I'd recommend replacing the batteries if you haven't done so yet.
Good luck--and please provide feedback if this helps!
Aug 21, 2011 | Kwikset Powerbolt/Electronic Deadbolt-...
How do I clear (erase) all codes from my Weiser Powerbolt 1000 in order to start with fresh entries? Adding new codes does NOT override/delete old existing codes as page 7 of my manual indicates. I now...
United States of America Customer Service Contact Information
Call Us Toll Free: 800-422-4278 (Mon-Fri, 6:00am - 4:30pm PST)
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
Good luck, Elizabeth!
Jul 26, 2011 | Weiser Lock Powerbolt 1000 Lock
Our Powerbolt 1000 started beeping this morning. I've tried replacing the batteries and disconnecting the power strip. The beeping continues. I am unable to reset the code. Are there any other...
Powerbolt is Beeping?
This is the relevant excerpt from the Powerbolt programming and troubleshooting instructions:
Why is my Powerbolt 1000 unit beeping?
To determine why your lock is beeping abnormally, please follow these steps:
Take out batteries and unplug power strip.
If it does not beep, the keypad needs to be replaced (17733-1).
If the unit continues to beep, the powerboard needs to be replaced (A17734-3,3 Powerboard 1470 brass finish; A17734-3,26D Powerboard 1470 satin chrome finish; A17734-3,5 Powerboard 1470 antique brass finish).
The complete page that I cut this from can be found by cutting and pasting this link into your browser search bar:
Since you've already gone through the battery change, etc.,this suggests that you need to replace the appropriate Powerboard for your lock.
So this is the link to Weiser Customer Support Page:
http://www.weiserlock.com/en/CustomerService/ProductSupport/SupportContact.aspx
I suggest calling the appropriate toll-free number and having a conversation with a representative about this problem, first of all to confirm that you need the part before you go through the expense.
Also, they will be able to get the correct part on order for you.
Jul 16, 2011 | Weiser Lock Powerbolt 1000 Lock
How do I errase the code and reset a new code on my kwikset powerbolt keyless entry door look
Follow this link to find out how to remove the cover for your Powerbolt:
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspx
This link:
http://s7d5.scene7.com/is/content/BDHHI/40486-02
is the "manual" for the installation of the lock. Programming instructions are found on Page 6.
I'd recommend changing the 4 alkaline AA batteries at the same time.
Jul 05, 2011 | Kwikset Powerbolt/Electronic Deadbolt-...
I need to reset the code
Jun 22, 2011 | Weiser Lock GED1460X3BR Lifetime Polished...
I would like to reset the security code.
This link:
Apr 29, 2011 | Kwikset Powerbolt/Electronic Deadbolt-...
Code not accepted
You might have to reset the lock and do a complete reprograming of your master security code and any other code(s) you want to use. While normally, the master code and other programmed codes shouldn't have to be reset, it's possible that the reset button was inadvertantly pushed, so you'll have to reset the lockset I would remove the batteries and clean off the lock's battery terminals with some rubbing alcohol to get them clean, just in case there is a film on them. Then reinsert the new, fresh batteries and reset the lock. Program in your master code, you can use the same one as before if you wish, and then program in another one, again, if you wish.
Here's a copy of the user manual so you can verify that the reset and programming steps to enter your are done properly and that the lock is set up correctly.
http://www.smarthomeusa.com/Products/ED1460XXXX/manuals/WeiserLockPowerbolt1000-manual.pdf
Hope you find this Very Helpful and best regards!
Aug 23, 2009 | Weiser Lock Powerbolt 1000 Lock
How to reset kwikset pwerbolt 1000
6. Resetting the code: - please follow these instructions to reset the code on your Powerbolt 1000 unit:
  • Remove the inner cover plate from the lock.
  • Locate the small round program button near the left side of the circuit board (Red or Black).
  • To program, the latch should be extended out in the lock position, press the reset button once, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. Re-enter the same 4-8 digit code to confirm, the latch should retract. This completes the programming. This signals that your code has been accepted.
  • To enter a second code, follow the same procedures as in step 3, but this time press the reset button twice then enter your code.
7. Replacing the batteries: - please follow these instructions to replace the batteries on your Powerbolt 1000 unit:
  • Remove inner cover plate located above the thumb turn on the inside of the door
  • Replace all 4 batteries with quality alkaline AA batteries. (Do not use rechargeable batteries.)
  • Ensure that the batteries are correctly oriented or unit will not function properly.
8. Changing the password code: - please follow these instructions:
  • Manually put the bolt in extended (lock) position. Press PROGRAM button once, enter new 4 - 8 digit code and then press LOCK.
  • Press PROGRAM button twice, enter the same new code and then press LOCK once.
  • Press PROGRAM button three times, enter the same new code and then press LOCK once.
    These stept will program only the new code you enter for your unit.
9. Why is my Powerbolt 1000 unit beeping? - To determine why your lock is beeping, please follow these steps:
  • Let is sit for 1 minute then put the batteries back in and wait another minute.
  • If it does not beep, the keypad needs to be replaced (17733-1).
  • If the unit beeps, the powerboard needs to be replaced (A17734-4,3 Powerboard 1460 brass finish; A17734-4,26D Powerboard 1460 satin chrome finish; A17734-4,5 Powerboard 1460 antique brass finish; A17734-4,11P Powerboard 1460 bronze finish).
Nov 02, 2008 | Kwikset Powerbolt/Electronic Deadbolt-...
Weiser Lock Powerbolt 1000 Lock Logo
434 people viewed this question
Top Weiser Lock Locks & Locksmithing Experts
john h
sonic boom...
sonic boom...
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
