Question about Whirlpool GSX9885J Top Load Washer
Washer will not spin dry. Control Board seems to be the problem. Please advise
Washer washes OK but will not spin dry. Control Board seems to be the problem. here is a smal area on the board which seems to be burnt. Please advise
  • 62 Answers
Ck water pump, but that sounds like a board
Posted on Oct 22, 2008
I have a Tricity Bendix AW1000W. The drum will not rotate. The belt is fine, the brushes on the motor seem ok, the machine fills with water ok and the pump drains it ok but there is no drum wash rotation...
Could be anything , from a loose connection or broken wire to a control board or timer fault..You say the brushes are o/k, but if they are less than 3 or 4mm long, they need replacing.
Even the motor itself could be faulty.
I assume the drive belt is o/k, and correctly tensioned..
It is difficult to advise you further because thier are too many variables involved.
Please leave your comments on my suggested solution.
Thankyou.
Nov 25, 2009 | Tricity Bendix AW1000W Front Load Washer
DOES NOT SPIN DRY EACH TIME
HI. This will, normally, occur if there are serious issues that concern the integrity of your control sector. This sector can be a timer module, or a control board, as well.I would advise to force a control reset, by shutting down the appropriate circuit breaker for five minutes. You may, also, unplug the unit, as well. This procedure will initiate a control reset, and may correct this issue that exist within the control sector.
Once the five minutes have passed, simply re-introduce power to the unit, and try a normal washing cycle. Observe the units actions during the spin attempt. If it fails to spin on time, this will confirm that the control sector(timer, or control board), is damaged. It will need to be replaced, in this case.
Nov 21, 2009 | Maytag Atlantis MAV6451 Top Load Washer
I have a Kenmore frontloading washer, model no. 417.42042100. At the end of the wash cycle, the clothes are still very wet; that is, still SOAKED with water, even though all the water has been drained...
HI. your unit is equipped with a spin control board. this board, if damaged, will not initiate an adequate spin. This will not allow for proper drainage and drying of the clothes. The spin motor regulates the rotation speed during the spin cycle. It seems to be the culprit at this time. Have the spin board replaced asap.
This part will usually cost around $150.00 at the most.
Aug 27, 2009 | Kenmore Washing Machines
Wprb8050d0ww does not drain, clothes very wet
eric it seams that its draining ok?thats important.must happen in a certin time frame to get clothes dry.also this thought comes to me check between the tubs with your hand thru the top.if clothing got there it couldnt spin well.but as a repairman i have replaced more ge motors than boards.god bless i hope that helps
Jan 03, 2009 | GE WPRB8050D Top Load Washer
Washer wont spin
Is the lock door light on if not change the wax motor & the main control board (board is approx $169.00+).That is the problem unless the belt slipped off .Common neptune issue you have will most likely repeat itself so,you decide from there.
May 03, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washer doesn't agitate
sounds like your washer went mellow on you(doesn't get agitated, right)?
ok. enough humor.
sounds like there's a problem with the motor/belt/control board in that order
Mar 13, 2008 | Splendide 2000S Vented Washer/Dryer
Broken washer/dryer
This sounds like a motor control board is faulty. Please load a couple of towels in the machine run it. Watch the machine as it goes through its' cycles.
1. Do the towels tumble when the machine is washing ?
2. When it begins to spin, does it spin one way at a fast pace or does it spin one way and then the other ?
Answering these two questions will help in troubleshooting your problem.
Jan 07, 2008 | Kenmore Elite 45986 Front Load Washer
Maytag Nuptune Washer
These units seem to all use the same control board and have the same issues. the intermittent and door lock issues are random and frustrating. it will take a person that wants to fix it. see this link for what to do. I have other links that explain the same.
http://www.fixya.com/support/t364216-whirlpool_duet_ht_ghw9400pl0
Oct 03, 2007 | Maytag MAH8700A Front Load Washer
Whirlpool GSX9885J Top Load Washer Logo
102 people viewed this question
Dan Webster
Dan Webster
Sal De
