Question about Reddy Heater-30-55,000 BTU Variable
Ready heater will run then shuts off
Readdy heater wil run for a few minutes then shuts off. Push reset button then it will re start.
  • 1,420 Answers
Change out the thermocouple.
Posted on Oct 21, 2008
Once the heater reaches the set temperature at the thermostat it shuts off.the flame goes out but the pilot light stays on. the heater will not kick back on automaticaly when it gets cold however it will...
you will have to look into why the unit is tripping and needs resetting. Heaters usually have a fan delay, meaning that when the heat is satisfied, the fan continues to run for about an minute. If not, it could cause an overheating issue and trip a safety. Look for that to start with.
Aug 05, 2017 | Williams 3003622 Ceramic Wall Mounted...
Spa kicks off in a cycle. needs to be reset
Dean,
Thank you for asking me to help you with your problem. However, this is either not within my level of expertise or the question is unclear or there is not enough information and I cannot help you at ths time.
Nov 25, 2011 | Jacuzzi Pool & Spa
I turn off the main water valve to fix a leaking problem and now the water heater does not work. What is the problem, how do I fix this?
Turn the water valve back on, shut the power off to the water heater for a few minutes and let it reset it self. Push the reset button, and try again. Hope this helps
Mar 08, 2011 | Bosch Water Heaters
Fans on both indoor and outdoor units are running but compressor wont restart, even after turning power on and turning back on. also, if compressor resets and runs, it'll run for a few minutes then trips...
the compresor have delay protection and this wil not alow compresor to run only after few minits (turn off the unit and disconect from the main power suply, wait 30 minits and after that turnit on) or the refrigerant gas in the plant missing. in this case you must call specializated personel to find the leack and fixit, after that they wil refil whit refrigerant gas (r404, r 134, or what your unit have)
Feb 14, 2010 | Heating & Cooling
I have a 100,000 btu reddy heater, and every time I turn it on, it runs for about 5 minutes, then stops, then I have to push the reset button and start it again. Can you tell me where to start? thanx
If it actually ignites and burns but shuts off either the flame sensor is bad (or dirty) or the control is bad. I would verify the flame sensor is clean and had good electrical connections to the controller for starters.
Feb 10, 2010 | Reddy HEATER R115 115,000-BTU PORTABLE...
Ready heater forced air runs few minutes then shuts off
Sounds like a full services like its getting too much air,and blowing out the flame. Check your fuel filter,and add a new spark plug ,also change the vanes on the pump, thus aFuu service. these sould be performed every fall before .
Dec 16, 2009 | Reddy HEATER R115 115,000-BTU PORTABLE...
Readyheater portable forced air 170,000btu/hr
reset switch my heater did the same thing after 5 sec of running
Dec 20, 2007 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy Heater-30-55,000 BTU Variable Logo
274 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
