Question about Motorola Mobility RAZR V3
How do I fix it
I can't make any phone call, but ican receive and answer calls. plz help
    Brigadier General:
  • 7,752 Answers
Is your phone barred from your service provider pls check with them, if that is not the case then try and master clear the phone and see if that corrects the problem if not then you will need to take it into a mobile service center and have them check it out for you.
Posted on Oct 26, 2008
Full house
If it is a wired phone change the handset cord that is the most common problem.
Aug 25, 2014 | Vtech 5.8GHz Cordless Phone with Digital...
I cant send text messages, keep coming back as failed, i have recently started using this phone and the sim is out of my old phone, ican make and receive calls and can receive calls.
Hi the problem you are having is with the message center number as you have changed the sim card the chances are the phone was with a different network and still has these settings installed.
all you need to do is contact your service provider and tell them the make and model of your phone then tell them you need to set up the message center number as you cant send messages and also ask them to send you the latest wap and mms settings, these will allow you to send and receive picture and video messages and also access the net.
your service provider wont charge you for sending all this to you and they will send them via text message after they have given you the correct message center number, this will then update your phone to the correct settings and then you will be able to use your phone as it should be used.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Sep 02, 2010 | Nokia N95 Cellular Phone
My keys dont work I cant read text or answer calls help. I can see my screen when I first plug it in to charger. Ican move trackball but it wont let me open the icons. My phone rings when i push the button...
it seems you have drop waterto your keypad you must making dry first after that disasembly blackberry casing and keypad and brush it with toothbrush and alkohol 100 %
Aug 21, 2009 | Microsoft Office Outlook 2003 for PC
Keypad not working during phone call
u'll have to get the keypad checked ...because the connection b/w the buttons and the chipset does seem to be ok.
May 29, 2009 | Motorola Mobility RAZR V3
Sound Ican hear them they can't hear me
Call your muted A747 from another phone.
Answer the call.
On your A747 select Options with the top left button.
Select the first entry, Mute/Unmute.
This fixed the same problem on my A747. Before doing this the Mute/Unmute had no effect. After doing the repair, all is OK.
Mar 29, 2009 | Samsung SGH-A747 Cellular Phone
I cant find the bluetooth ican in the handset
go to main menu, then setting, then go to connectivity. then u can select blue tooth connection on.
Jan 26, 2009 | RIM BlackBerry 8700c Cellular Phone
Sony ericsson 350i (using phone with flip closed)
under settings./calls ,scroll to bottom of page.answer on /off tab set to OFF you can use phone as normal then
Jan 18, 2009 | Lands Phones
Ican not setup my KX-TG6311 phone. It will dail out or receive calls. It has been charged the 7 hours. What do I do now? Dwight
is it your antena icon blinking? if answer is yes, pls follow the registration process again
May 08, 2008 | Lands Phones
Auto answer problem
I have lg kg195 too but my works fine....i think you should go to customize profile and then answer mode and then turn it off may be that will work....
Jan 15, 2008 | LG KG320 Cellular Phone
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
