Question about Arris WR850G Router (DHWR850G)
Motorola wr850g i have a wireless network set up in my house and the wireless computers can connect to the internet but my computer with the modem & router cannot. I've tried to access the motorola interface but that wont even come up. any suggestions?
    Novelist:
  • 93 Answers
1) Are you sure you're connecting to YOUR wireless network? From my own house, I can access 5 different wi-fi networks, 3 of them unsecured. I've even logged into two of them, unintentionally.
2) Check all of your cabling connections that they are tight and
secured. This includes the cables from the wall to your modem,
between the router and modem, and from the router
to your PC. Ensure that your LEDs are not lit Red or not at all.
3) Ensure that you are using Ethernet cables and not telephone
cables between the router and PC. Ethernet
cables use a wider RJ-45 style plug using 8 wires where
telephone style plugs use the smaller RJ-11 style plug using 4 to
6 wires.
4) Ensure that your Ethernet adapter is enabled. Check the System
Tray at the bottom right of your display to see an icon that looks
like a monitor. You can click on this to see the status of
your Ethernet adapter. Also in Control Panel > Network and
Dial-Up Connections, you can examine the state of your Ethernet
adapter.
5) Firewalls. Your desktop firewall(s) may be blocking your internet access. Check them.
6) You may not be completely blocked (only web traffic - port 80 - blocked). Go to Start > Run and type CMD. At the DOS prompt, type ping 192.168.1.1 (should be the default IP address of your router). If you get a response, your PC is talking to the router. If you get "timed out", then they are not talking, for some reason. If successful, try pinging an external address, something like ping www.fixya.com, and see what happens.
Posted on Nov 10, 2008
Secure motorola router WR850G
If you want set wireless router with connect your internet, in that case you should secure your wireless router.The router transmits and receives data from the modem and computers connected to the network....read more: how to secure your router
Aug 28, 2012 | Arris WR850G Router (DHWR850G)
Why does my internet keep dropping?
change your connection system
you can get TP link units that plug into the house electrical system and run ethernet cables from the computers on a home network system
works like a charm over any distance on the same power circuit for the house
may be a wireless dongle will fix your problem
Apr 11, 2017 | Motorola Computers & Internet
Mdeschamps@comcast.netI have a Motorola router WR850G All connections are ok router front lights ok power on modem flicking green wireless flickling green network flicking green the security was changed a...
TRY RESETING THE ROUTER. BUTTON AT BACK IT IS A LITTLE HOLE
WHAT KIND OF WINDOWS (OPERATION SYSTEM YOU HAVE)?
DID YOU CAN RESTORE YOUR COMPUTER TO A DATE IT WAS WORKING TO GOT THE WORKING SETTINGS OR POST YOU OPERATION SYSTEM TO CHANGE THE SETTINGS
Feb 17, 2011 | Arris WR850GP Router
Cannot connect to the internet
Make sure that your computer is able to go online through the modem. If your computer is not able to go online through the modem then you will need to call ISP first. If your computer is able to go online through the modem then you need to connect the computer to the router and the modem to the router. open the set up page of the router and change the settings of the router according to the ISP.
Apr 05, 2010 | Arris Wireless G Broadband Router (wr850g)
The modem light is off on my Motorola modem.
Ah, someone that actually makes use of the word "nor" I would first unplug the CAT-5 cable that goes from your modem into your router to check that it's not your router's fault. To make sure that every computer that is plugged into the router is on the network you should PING each computer to see if you can reach it.
Find out the IP of your computer by clicking Start then Run then type in CMD. Once your in CMD (Command Prompt) you should type in IPCONFIG. That command will give you a response with your IP Address in it. Take that IP and go to another computer in your network and use the PING command in CMD by typing PING 192.168.1.??? in CMD.
If your PINGing session is successful then it's a problem with your ISP (Internet Service Provider) and should be handled by contacting them and having the problem fixed because it's an issue at their end. If it's not it's a problem with your router and can be handled by having a specialist come to your home and to fix/set up your network or I could remotely control your computer to fix it.
It's your choice, but the specialist will cost and I won't.
Thanks,
Brandonmxb
Dec 11, 2009 | Arris Wireless G Broadband Router (wr850g)
Router not working as well with D620 as with my older D610
If your router has the external antenna the signal will increase when you point the antenna in the direction where the computer is used the most. It always helps to locate the router in a central area and on the upper floors of a house because the broadcast signal falls like rain. Another trick to try is to change your broadcast channel in the router, the normal default is channel 6. Each channel broadcasts at a slightly different frequency. Hope this helps...Tennis123
Nov 05, 2008 | Arris Wireless G Broadband Router (wr850g)
Cant get motorola wr850g to see time warner cable modem
I had same problem and what i did is i restarted the device and i installed it to the cp again you probably did something wrong
Aug 14, 2008 | Arris Wireless G Broadband Router (wr850g)
Cant connect to the internet
red light means moden is out of sync with the isp. Power cycle. by unpluging the power from the back of yoru modem, unplug Your router and also turn off your computer. Turn on your modem frist wait until all lights are green>If they dont turn green. CHeck your cables. make sure telephone line is plugged into it or cable line. . There should be a cable pluged in from your modem to your wan port. Then from your router to your computer. Is this a wired or wireless connection. If its a wireless connection i need to know what what os your using. so i can help you set it up.
Feb 05, 2008 | Arris WR850G Router (DHWR850G)
Motorola router
first check your computers internet connection settings.and also check for any updates that could pretain to your modem/or computer.the problem is with your main computer,and not with the router.second check your firewall,make sure the correct port is open to let the traffic in.
Dec 28, 2007 | Arris Wireless G Broadband Router (wr850g)
Help!!
make sure your wireless on the laptop has the word motorola in the connection/.configuation set up,, right click wireless icon to find config info..,,the ssid name should be the motorola name.
Dec 04, 2007 | Arris Wireless G Broadband Router (wr850g)
Arris WR850G Router (DHWR850G) Logo
199 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
bobkoure
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
