posted by Bandycoot on Jul 24, 2006
At the end of a wash cycle when the door lock is waiting to disengage the machine trips the house circuit RCD.
If left in the same cyle position the RCD cannot be reset. If the position is moved the RCD can be reset and a new cycle begun. Checking the plug, there is a closed circuit between the earth and live (when in the cycle end position).
This fault occurs approx every 2nd cycle or every cycle. What could be causing this?
Solution #1
posted on Aug 31, 2006
IM GUESSING THAT YOU GOT A LEAKY GASKET THATS SPRAYING WATER ONTO YOUR DOOR INTERLOCK SWITCH CHECK TO SSE IF YOU AHVE ANY RIPS OR TEAR IN THE GASKET. DOOR INTERLOCK WOULD BE WORTH CHANGING AS THEY DONT COST MUCH.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Hotpoint Aquarius WD640 Front Load
Email this problem
Email this problem
This Problem Also Relates To:
Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint WMA76 Front Load Washer
Hotpoint Aquarius WF210 Front Load Washer
Hotpoint Aquarius WMA52 Front Load Washer
Hotpoint First Edition WMA20 Front Load Washer
Hotpoint VBSR3100D Top Load Washer
Hotpoint WF645 Front Load Washer
Can you Help with these Washing Machines problems?
Hotpoint Aquarius WD640 Front Load All-in-One...
same problem with hotpoint...
hi did you find out after how... Answer This...
washer takes on water...
Thank you for your help in... Answer This...
dish washer
dish washer
top arm not washing not going... Answer This...
salt refill
salt refill
please tell me about the salt... Answer This...
how to solve the problem
dear chopps how do you solve... Answer This...
Repair Service
Find Washing Machine Repairman Near You:
Find Parts
