Question about Brother MFC-9420CN All-In-One Laser Printer
Brother MFC-9420CN Transfer Roller
When I removed the transfer roller, a small stainless steel clip came out with it and I am not sure where to replace it. The clip has a 90 degree shape, the upright portion has a square top with a hole in the center, while the horizontal piece has two arms that appear to fit around something as they slightly bevel out. Also on the upright piece, there is slight bend so that the square piece sits slightly forward of the rest of the clip. I hope this makes sense and you can tell me where it should be replaced. BTW, when I reinstall the TR roller it still says no TR roller installed.
    Problem Solver:
  • 5 Answers
This web site below have the guide to replace the belt and how to reset them
http://www.simplyinked.com/support/index.php?tsrc=knowledgebase&act=117&category=C5
Posted on Oct 29, 2008
Where is transfer roller
Transfer roller the assembly is apporx 11" long and is attached to insaid
of the rear cover
Feb 14, 2013 | Brother MFC-9420CN All-In-One Laser...
When ready to print paper only goes through a little and then message says paper jam..it now happens all the time
If you have had your printer for some time now it could possibly be that the feeder rollers are worn and aren't picking up the paper correctly, causing the printer to think it is jammed. The rollers don't have to be changed very often, but they do get old. A new roller kit will cost you anywhere between 30 and 50 dollars online. They are super easy to install. The only thing to make sure of is: don't order a full maintenance kit. Yes, they have the rollers, but they are most likely going to send you a fuser as well, which will triple the cost. Try to find just the rollers. The replaceable rollers are; the transfer roller, paper pick-up roller (which is probably your problem), cleaning roller, and separator pad (also one that has to do with the paper).
Aug 18, 2010 | Brother MFC-9420CN All-In-One Laser...
Error message: No TR Roller Install the transfer roller
Hi
This error has already been noticed by Brother and they have a fix for this issue. This message will appear on your Brother machine if the ground clip is not present on the Transfer Roller Assembly. The clip can become dislodged due to a paper jam or removal of the Transfer Roller assembly.
To check the fix from Brother visit this link--
Brother TR Roller Install error removal Pictures
Please get back to me if you have any queries.
Daniel Scott
Jun 22, 2010 | Brother MFC-9420CN All-In-One Laser...
Fuser problem with Brother MFC 9420CN laser all in one
Unplug the printer and allow it to cool.  Then gently wipe off the surface of the photo-sensitive drum with a cotton swab.  If this doesn't work you may need to replace the drum.
Nov 20, 2008 | Brother MFC-9420CN All-In-One Laser...
Faded Image coming from Brother 9420cn
You probably have the new roller by now.  But just incase the problem continues, clean the high voltage contact on the right side for the roller and on the drum unit itself.  If it is dirty you'll get light printing.
Nov 19, 2008 | Brother MFC-9420CN All-In-One Laser...
Brother 9420cn message on display transfer roller not installed, appeared during printing session, cannot rectify
Replacing the transfer roller
1 Turn off the machine’s power switch.
2 Open the back cover of the machine.
3 Release the transfer roller lock levers on
the right and left-hand sides, and then lift
the levers to release the transfer roller.
4 Take out the transfer roller by gently
pulling the right-hand side up and sliding
the transfer roller to the right.
5 Put in the new transfer roller by holding
the lock levers of the transfer roller and
adjusting the angle of the transfer roller
lever shafts (both sides) to match the
transfer unit grooves. Put the transfer
roller onto the shafts and place the roller
onto the springs as shown below:
6 Push the lock levers down to lock the
transfer roller into place.
7 Close the back cover.
8 Turn the machine’s power switch back
on.
Apr 30, 2008 | Office Equipment & Supplies
TR Roller
Here is the solution for the Transfer Roller problem from brother especially the MFC-9420CN. I found it on the Brother website.
http://pub.brother.com/pub/com/pdf/no-trroller.pdf
Mar 01, 2008 | Brother MFC-9420CN All-In-One Laser...
MFC 9420cn is asking for a transfer roller?...
Open the back cover near the top. The transfer roller is part of the cover that you open.
Jan 16, 2008 | Brother MFC-9420CN All-In-One Laser...
Brother MFC-9420CN All-In-One Laser Printer Logo
493 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
