Question about Aiwa NSX-AJ20 CD Shelf System
Tape door won't open and decks won't play
I can't get the tape player to play. At first the right door wouldent open but the left side would but not play, now the right door misteriously will open and the left won't. When the power button is turned on, a mechanical clicking noise is produced about three to four clicks and then stops. Any Ideas??
Thanks, Vern
    New Friend:
  • 111 Answers
Mechanisum stucked.
remoove the cover and change the all belts.
nuwan.
Posted on Jan 12, 2009
I have an Aiwa Surround Sound Theatre system Model #cx-nmt720. Has a 3 disc player, am/fm, and 2 cassette decks (one on right allows recording/dubbing) Everything works great except cassette...
The unit may be damaged or may just need adjustment- only a tape deck technician will be able to answer the question after seeing the unit. To answer it remotely like this, is really an impossible task.
Nov 03, 2012 | Audio Players & Recorders
Left Deck Door Stuck Shut on Cassette Deck
Hi what has happened is when you pressed play the tape head that reads the tape has come up as normal this locks the door as you cant open it when its playing but instead of the tape head releasing and going back down into start possition it has become jammed in the tape itself.
You have two options turn off at mains and give it a gentle bang a couple of times this might free the tape and let the head go back to start possition its upto you how hard you tap it but doing this usually works and will allow you to get the tape out failing this then its going to be a case of stripping it down till you can get access to the tape head and be able to free it from the tape allowing door to open let me know how you get on ok and if you need further assistance
Feb 07, 2008 | Audio Players & Recorders
Sony TC-WR690 doors will not open to remove the cassette.
If you remove the cover after unplugging the AC, you will see that when you push the eject button that on the back side the putton is held back by a white plastic piece. Push down the white plastic piece as you press the eject button. The door will open and the tape will release. I jsut did this today on my Sony TC WR 670 dual tape player. Both sides were blocked. I noticed that both fuses on the board were also blown. New fuses didn't solve the problem. May be that the transformer is out?
Apr 21, 2012 | Sony CASSETTE DECK Single Dual Cassette...
Forgot how to record (dual) tape to tape (been a while)......can not remember sequence of buttons to press or if i need to press buttons at the same time (i.e. Trying to record 1 cassette tape to another...
The left side is usually the playback deck and the right side is the record deck.put in a tape on the left side and push play.Then push the record button first and while holding it down ,the play button on the right side deck.One deck will not have record buttons on it,and that is the playback deck.
Jul 09, 2010 | Audio Players & Recorders
Play function won't disengage on Technics dual cassette deck
Remove the cover to see if any belts under the cassette player is cut. Or to see if there are any obstructions.Remove the front cover.which will remove the tape housing of the cassette player. you can check for any broken plastic compoments that might be keeping the housing from opening.Or any belts that may have been cut.
Dec 25, 2008 | Audio Players & Recorders
Denon Dual Cassette Deck DRW-660 will not eject either tape. I put a tape in right side, played a bit, stopped, will not eject. I put another tape in left side, closed, cannot eject. Cannot eject either....
Some dual decks use a common drive belt. It may have become too slack (due to age) to drive mechanism. I am sure its time to change all belts in both decks. This will solve the problem
Apr 05, 2008 | Audio Players & Recorders
The cassette mechanism has a large gear that rotates to different positions for the different modes. On time around is a play - stop cycle. It is stuck in one position and won't come around to the stop spot. Need to take the cover off and help it to turn to get the cassette out. Then figure out if something is wrong preventing it from turning or if the wheel driving it is the problem. They are all a little different so this is where your mechanical apptitude comes in.
By the way, you'll figure out right away they don't intend these things to be fixed.
Hope Ya Fix It.
Feb 04, 2008 | Audio Players & Recorders
Marantz Cassette Deck Model Sd 35 Tape door will not open
It sounds like the drive belts on the deck have broken (not allowing playing, FF or REW) and/or the tape got "eaten" meaning the tape itself has wound itself around the rollers and cannot free itself. I strongly doubt this is an electrical issue. Definately sounds mechanical.
As far as the door not opening, there's usually a hook that holds the door closed. If the unit is mostly disassembled, look near one of the sides of the door for a metal hook. It's normally spring loaded and can be moved manually. That should free the door. If your tape was eaten, it might take some gentle persuasion to unwrap it from the rollers.
Good luck.
Making copies?
Oh yes, on the TD-WE375 above the left deck also stops playing sound when the right deck is readied for recording.
Oct 15, 2007 | Technics RS-TR373 Single Cassette Deck
Aiwa NSX-AJ20 CD Shelf System Logo
349 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
