USED TONER BOTTLE IS FULL
The printer and copier funtions are not working and there is a big red message "Used toner bottle is full" I tryed to find the waste bottle but I've been unable to locate it.
thanks in advance!
A door on the left in paper tray
Posted on Jan 13, 2009
  • xyetim Jan 13, 2009
    near the paper tray and on the left
Message the toner bottle is full please call the server machine printing rico 4500
The bottle full message indicates that the waste toner collection bottle is full. The full bottle needs to be removed and the toner disposed of properly. Then a replacement collection bottle needs to be installed and the waste toner counter reset. This site has the toner bottle: http://www.precisionroller.com/waste-toner-containers-for-ricoh-aficio-mp-c4500/details_47769.html . It is possible to reuse the bottles but most people will spill the toner when they try to empty a collection bottle. You do not want loose toner in your environment.
Turn off the printer (at the power switch) and wait for the lights to stop blinking before attempting the replacement. See page 62 of the network guide for the replacement procedure. See https://www.ricoh-usa.com/downloads/downloads.aspx to search for your printer and get the manuals.
I hope this helps
Jul 06, 2015 | Office Equipment & Supplies
Waste toner bottle full so replaced but will not reset and says still full
then the clear section of the waste toner bottle is not clear some toner is left blocking the sensor that monitors the waste toner level
Apr 02, 2014 | Konica Minolta New Bizhub C25 Color Laser...
Ricoh aficio Aficio 3224C used toner bottle -1 is full
On a 3224, the used toner bottle is easily replaceable. To get to it, open the front cover of the copier. In the lower left corner, you will see a white or light gray plastic container which slides straight out -- that is the used toner bottle. You can replace it (if you have a new one) by taking the old one out, putting the black plug in the hole to prevent toner from spilling, throwing it away, and inserting the new bottle. If you don't have a new used toner bottle, you can empty this one out into a large bag or trash can and then reinstall it.
Mar 18, 2011 | Ricoh Aficio CL3500N Laser Printer
Used toner bottle is full how do I change it or fix it?
hi just empty it in plastic bag and re use the bottle
thanks
May 13, 2010 | Office Equipment & Supplies
Used toner bottle full on a ricoh aficio 400
The sensor is dirty or damaged cleans or replaces. This is not reset.
Apr 08, 2009 | Ricoh Office Equipment & Supplies
Used Toner Bottle Full Ricoh Aficio 1035P
The used toner is stored in the Transfer Belt assembly on the right door that you open to remove a jam. Remove one spring on each side and release the catch while gently lifting up on the belt and roller assembly. It swings 90 degrees up from the rest of the assembly. There are 6 screws that hold a cover on the lower assembly. remove it and dump the waste toner. *** VERY MESSY*** have a vac on hand. Not a shop vac unless you want toner clouds floating around the office. If the six screws aren't present, dump the toner out of the **** between the mylar-rubber blade and the lower assembly. once this is done, the message will clear.
The used toner bottle is not actually a bottle at all. Not sure what you emptied, but it sounds like the actual toner bottle itself. The waste toner is contained with in the transfer belt unit. When you open the right side cover, this is the unit that is attached to the door. It is a brown belt that provides transfer of the image to the drum and separates the paper from the drum. Remove this unit by locating the release levers on either side of the transfer unit (push both of them towards the machine). After removing, you will need to actually take the belt unit off of the transfer unit. To do this, remove the two tension springs on either side, and then take a small flat bladed scredriver and release the clips that hold it down (you will see when you get started). Once you get it off, you will see the long blade that actually scrapes the toner off the belt. Dump the waste toner out this end. You will need to shake it pretty hard. A better (and cleaner) option is to vaccum it out using the crevace tool on you vac. Just make sure you completely empty it. Now....do everything in reverse.
Hope this helps,
Chad
Oct 07, 2008 | Ricoh Aficio 1035 Copier
Ricoh aficio 2045eSP
Please make a power off and then start it. Let it to initialize then install the Ink Bottle. Make it off again. and then power on.
Try to check it out and print.
Hope it will solve your problem. Otherwise let me know if you need further assistance.
Regards
ELLIN
Sep 20, 2008 | Ricoh Aficio 2022 All-In-One Laser Printer
How to reset waster toner bottle full Xerox 3535
Here's what I did.
Emptied the waste toner cartridge. Left it out of the machine. Held the microswitch (located to the right of the optical sensors) in the "cartridge in" position with a paperclip. Printed one document. Inserted the waste toner cartridge. Error now gone!
GCC.
Aug 27, 2008 | Xerox DocuColor 3535 Copier
Waste motor error
The wate motor transfers (you guess it) waste toner to the waste toner bottle. If the bottle fills up, the motor cannot transfer more waste to it. This is rare, for the printer should ask for a new waste toner bottle when the previous one fills. However,it happens frequently when users try to empty and clean the bottle instead of replacing it.
If a new waste toner bottle is in place, then the printer needs a new motor, which can only be purchased through an Authorized Service Center.
Oct 24, 2007 | Samsung CLP-510 Laser Printer
562 people viewed this question
jasbo
jasbo
