Question about Kenmore 17024 Built-in Dishwasher
Blowing fuse... We've replaced the overheating fuse located in the control board area about 5 times. It has just blown again after using the dishwaser one time--before it would go about a month before blowing the fuse. It seems to get about a few minutes away from completing the wash cycle and does not complete the draining process. Help!! We don't know what to do next--replacing the fuse is costing about $15 each time, before you know it we could have bought a new one! Thanks for the help. Tim
    President:
  • 878 Answers
Tim, this blown fuse issue was pretty common on this model. Whirlpool, which made this model came out with a fuse kit that included a terminal and heavier guage wire to eliminate this problem. It just splices right into the control board, easy job. The model number that you posted had some service flashes out on it including a heater and motor rework. If your model number ends in 00 or 01, yours may be included. You may want to check with Whirlpool to get that fuse kit and check on the service flash. The service flash is 22-721. Good luck, Catriver
Posted on Jul 24, 2006
Fuse is blown = need to replace, what type of fuse should I use
How to Change Treadmill Fuses ' LIVESTRONG.COM
www.livestrong.com > Sports and Fitness
Sep 29, 2015 - If the fuse on your treadmill has blown, it's time to replace it. ... Thetreadmill fuses are located inside the elevation motor. If you don't have the ...
Treadmill blowing fuse. ' All About Circuits
forum.allaboutcircuits.com > ... > Electronics > General Electronics Chat
Sep 1, 2014 - I have recently picked up a second hand treadmill with an issue (York Challenger ... If I unplug the motor from the control board it will not blow the fuse, and will give ... Not sure yet, but i'll replace the IGBT's/power mosfet (I still don't know whats ... Treadmill goes high speed then blows the fuse
Nov 25, 2015
Treadmill blows fuse as soon as it starts
Sep 29, 2015
treadmill motor controller problem?
Aug 25, 2012
Treadmill Controller - No power to motor
Feb 11, 2012
More results from forum.allaboutcircuits.com
Jan 20, 2016 | Exercise & Fitness
88 toyota pick up v6 keeps blowing efi fuse
you may have a short of some kind, when a fuse blows repeatedly it is no good just replacing, you are being told that something is wrong with the equipment.
You will almost certainly have to visit a technician for a diagnosis. It is unlikely to be something that an inexperienced end user can sort out I am afraid.
GOOD LUCK
Oct 26, 2015 | 1988 Toyota Pickup
The drain pump on my F&P IWL16 is leaking water. I've had the pump replaced 3 times, during which, the new control board with fuse bypass was installed to prevent the board from blowing again
The pump may not be seating tight against the bucket,
There are four bolts on the gal plate you can tighten to make pump seat tighter on the bucket.
Nov 24, 2012 | Fisher Paykel Eco IWL16
When the machine is on for 5 minutes it turn off causing a fuse to be blown.
compressor is overheating or is about to go. is there warm air blowing out the back of the machine? if not, replace the fan. if there is cool air, the compressor may be siezed. replace the dehumidifier.
May 11, 2012 | Whirlpool Dehumidifiers
Can a bad voltage regulator cause the main 30 amp fuse to blow?
Usually a bad regulator will only cause problems with charging...
Sounds like you've got a short somewhere in the wiring...I'd start by checking the ignition switch wiring and the connections going into the fuse box.
Mar 19, 2012 | kawasaki VN 1500 Vulcan Classic...
No power to inside thermostat
Hi, if you have no power, 24volts to your stat, remove your panel on the indoor unit to look at the control board. It will have a 3 to 5 amp fuse plugged into it. See if it is blown. If it is good, the next thing to check is the 120 voltx24volt transformer located in the control area.More then likely, you have blown that fuse for some reason. If you replace it and it blows again right off, you have a dead short on your secondary low voltage side. You will need to look for any stat wires that may be touching metal, the board may be bad. Pull or kill power to the indoor unit, remove the 4 screws holding the board in place, work it to where you can look at the back side for any hot spots, burned spots.If you find that it is, your board needs to be replaced. They do burn out very easy, a very common thing. Please let me know what you have found.
Shastalaker7
A/C Contractor
Nov 27, 2011 | Goodman CLJ30AR32 Air Conditioner
I have a RM 2652 fridge in my 2003 trailer and my refridgerator/freezer does not work. The check light now comes on, what could be wrong?
If your refrigerator has had a recall done on it I would check the L shaped bracket that was added as part of the recall, as it may have pinched thermal flame sensor and driving may slightly reposition it to cause an intermittent short blowing your 15 a fuse in rv panel. Remove it from the retaining fingers and slightly reposition fingers loosely around black insulation sleeve and reattach it to the previous location with the 2 sheet metal screws.
Now if the refrigerator won't come on at all check the resetable hi limit switch that is riveted to your units boiler area a few inches above your gas flame area. It has a button you can press located in between the 2 connectors.
Check for 12 VDC at the nylon terminal block in front of your main board AND on terminal J4. If power is there follow to the resetable hi limit switch on boiler. If you don't have power at all you may very well have a control board failure. You should check all 3 fuses on the control board also. So check all 4 Fuses (ONE) 15A on the RV Panel and the (THREE) fuses on the main board. If any of them are blown you can replace them ONCE only. If it blows the 15A Fuse on the RV panel again your going to have to locate the short most often from the RV panel to the main board on the refrigerator. If the fuses on the mainboard blow your going to have to troubleshoot the refrigerator wiring.
Thanks for choosing FixYa
Kelly
Sep 02, 2010 | Dometic RM2652 Refrigerator
Gaggenau EB 194 Double Oven fuse blowing
from your description, it seems the little fuse is overheating sometimes, a short is a short and an immidiate fuse blower. i would use a higher amperage fuse, 30 amps. any electronic tech can replace this, doesnt have to be your Gaggenau guy, as it seems to me hes made a regular income of this
Apr 17, 2009 | Gaggenau EB294/295 Electric Double Oven
My jvc receiver has blown fuse if i replace the fuse and it blows again what else could be blowing the fuse
blowing fuse only indicates that there is power surges in your area. in order to avoid blowing your fuse again. you may need to a have a surge supressor and auto voltage regulator used for your receiver and any appliance that may need it.
Mar 24, 2008 | Audio Players & Recorders
Fuse inside tv keeps blowing
Hi there!
If the fuse rating is correct as indicated on the board, then the PTC is probably busy going faulty. If not sure where it is located, normally on the front where the switch is and where the coil that sits around the tube is connected to the board. Little plastic box with three pins(sometimes two) black or cream in colour. Some circuits use a disc type with 2 legs, however not sure on your set. This is called the degausing circuit and demagnetises the tube every time you switch the TV on. Good luck, JUS004
Mar 16, 2008 | Sanyo DS31520 31" TV
Kenmore 17024 Built-in Dishwasher Logo
163 people viewed this question
Top Kenmore Dishwashers Experts
Fred Sops
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
