Question about Apple iPhone Smartphone
Iphone voice mail password required
Whenever I look at my phone, it says "Password incorrect, enter voicemail password." Well, I never set up a password for voicemail so how do I resolve this issue?
  • Anonymous Dec 27, 2008
    Same problem with my iPhone. my vm is probably way full with messages dating back months.
  • Anonymous Dec 28, 2008
    same with my iphone im about to chuck it in the lake
3 Suggested Answers
SOURCE: iphone visual voicemail
I would suggest the following... It is the easiest solution going.
simply go to your local at&t store and tell them that you need a blank simcard that you can put into your iphone and activate at home.
once you do that you will want to take the simcard out of the iphone and put in the new sim.
Plug the iphone into your computer after youve installed the new sim.
You will then be guided through the itunes activation process.
once completed all features will be working and the voicemail will work on at&t's Visual voicemail settings.
Good Luck... This Will Work... All the best
-techjunkie4life
Posted on May 22, 2008
Apple Care
  • 52 Answers
SOURCE: iphone virtual voicemail
To setup your voice mail just call your voice mail by holding down one.
And then after you set it up you can restart your iPhone and it will work.
If not call Apple at 1-800-MY-APPLE or at&t at 611
Thank You. Nick
Posted on Dec 22, 2008
BarrettDenCo
  • 1772 Answers
SOURCE: people can't leave me a
Sorry to read about your problem, I hope this helps you out.
goto you voice mail on a regular phone and check message..if you have no message, reset you iphone under network settings
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Posted on Dec 21, 2010
How to register password of voice mail
Reset Voice Mail Passwois method is used to change your Voice Mail password for all types of Voice Mail (Basic, Premium, Visual, etc.)
  1. Press *611 then press SEND (airtime is free).
    Alternatively, call (800) 922-0204 (toll free) from any phone to reach the automated customer service menu.
  2. Listen to the instructions then when prompted say "Reset voicemail password".
  3. If prompted, enter the requested information for security verification.
  4. Follow the prompts to reset the password.
    The password can't have repeating digits (e.g., 1111) or consecutive digits (e.g., 1234).
Through the My Verizon app:
  1. Navigate: Apps > My Verizon.
rd from Device Tap the Menu icon (located upper-left). Tap Account. Tap Account Settings If prompted, enter the My Verizion password then tap Sign in. Tap the Security tab then tap Manage Voicemail Password. Enter and confirm the new Voice Mail password then tap Update. The password can't have repeating digits (e.g., 1111) or consecutive digits (e.g., 1234).
Sep 28, 2016 | cellular Cell Phones
Set up voice mail
What model phone do you have and which carrier? For example, with a Verizon iphone 5 these are the steps:
  1. From the Home screen, tap Phone .
    The Home screen is accessed by pressing the home button (located at the bottom of the device).
  2. Tap Voicemail
    You could be directed to the automated Voice Mail system at this time. If so, follow the voice prompts to set up your Voice Mail and greeting instead of completing the steps below.
  3. Tap Set Up Now.
    If the 'Set Up Now' pop-up does not appear, your voice mail has already been set up. Simply tap Greeting in the upper-left of the voice mail screen and begin at step 6.
  4. Enter a password then tap Done.
    The password must be between 4-6 digits in length.
  5. Re-enter the password then tap Done.
  6. Tap Custom to record a greeting.
    To use a Verizon default greeting, tap (check) Default.
  7. Tap Record to begin.
  8. When finished, tap Stop.
  9. Tap Save.
Apr 11, 2016 | Cell Phones
Unistall visual voice mail?
it is a feature that provided by the carrier, you can ask them to disable it or just type in incorrect password in settings - phone and change voicemail password and phone will stop connecting to the carriers server.
Sep 22, 2014 | Apple iPhone Smartphone
What my voicemail 4 digit passcodefor 2402620085
Your voicemail password is a 4 digit number that you enter when you want to listen to your voicemail messages from any other phone other than your mobile phone - this is called remote access. This voicemail password gives you the protection to know that only you can listen to your voicemails.
It is vital that your password is set to a random 4 digit password. To change your password, all you need to do is:
  1. Dial 173 from your mobile
  2. You will then be asked to pick a 4 digit number, and then press the # button
  3. If you are happy press press 2
Your password is all set up and you will be prompted to enter it whenever you want to listen to your voicemails through remote access.You will only need to use this password when accessing your voicemails from another phone. You will not need to use this password when accessing your voicemail from your own mobile phone - you simply dial 171 as normal
You can reset your voicemail pass code by dialing 611 or 1 800 331 0500
From the main menu, press3 (To get help with voicemail)
Press 2 to reset your voicemail pass word
Enter Billing Zip code
Customer will receive a text message to their wireless phone with their new voicemail password.
OR
You can log into your "My Account" from the www.cingular.com
From the My Phone page, click Reset Voice Mail Password.
Choose a wireless number from the dropdown menu and select Submit.
A text message is sent to the wireless phone with the new password.
Feb 24, 2012 | Cell Phones
I forgot my iphone voicemail password, how can i just erase so i can make a new one.
  1. Call 611 or 800-331-0500.
  2. Press 1 to use existing number, or enter the wireless number starting with area code.
  3. Tap the 3 key to "get help with voicemail." (5 for enterprise customers)
  4. Tap the 3 key to reset your VM password.
  5. Enter the Billing Zip code for the account.
  6. A temporary password will be sent via SMS
  7. Access voicemail with this temporary password.
After performing the above steps, my voicemail was accessible once again, and I didn't appear to have lost any prior voice mail messages. AT&T's support page has several other options available as well, but I found the above to be the quickest and easiest to execute directly from my iPhone.
Jan 31, 2011 | Apple iPhone 3G
Unexpectedly, my voicemail has a password. I have no idea how that happened but I can't check my voicemail without a password. Not available in "settings" to change anything it remove this...
Hi, you'll need to restore your iphone as a new iphone it will wipe all the data from your phone but its necessary as if you try to restore your phone and use previous back ups it will bring the voicemail password back...Hope this helps..
Use the following steps to restore your iPhone.
***** IF YOU CANT SEE YOU IPHONE IN ITUNES OR IT IS STUCK AT THE APPLE LOGO - POWER DOWN YOUR PHONE - HOLD DOWN THE HOME BUTTON FOR AROUND 6SECS WHILST CONNECTING TO ITUNES - RELEASE BUTTON - ITUNES WILL THEN APPEAR WITH MESSAGE SAYING IT HAS DETECTED IPHONE IN RECOVERY MODE & CONTINUE TO RESTORE YOUR PHONE - FOLLOW FROM STEP 6! ) *****
  1. Make sure you have the latest version of iTunes installed and running before attempting to update.
  2. Connect your device to your computer.
  3. Select your iPhone when it appears in iTunes under Devices.
  4. Select the Summary tab.
  5. Select the Restore option.
  6. When prompted to back up your settings before restoring, select the Back Up option (as seen in the image below). If you have just backed up the device, it is not necessary to create another.
  7. Select the Restore option when iTunes prompts you (as long as you've backed up your device, you should not have to worry about restoring your phone).
  8. Once the restore process has completed, the device restarts and displays the Apple logo while starting up:
    iPhone only: For the iPhone only, after a restore, the iPhone displays the "Connect to iTunes" screen. Keep your device connected until the "Connect to iTunes" screen goes away or you see "iPhone is activated." If iTunes does not have an Internet connection, you cannot complete this step.
  9. The final step is to restore your device from a previous backup. Once your device is restored and-in the case of the iPhone-in the process of activating, you should be able to see the following in iTunes:
    Select the backup you want for your device and select the Continue button to complete your device's restoration.
If you do not want to restore from backup, select "Set up as new...
Dec 26, 2010 | Apple iPhone 3G
Unable to retrieve voicemail does not accept new password
Reset voicemail password from AT&T's automated system
Enter the wireless number starting with area code.
Press 3 to "get help with voicemail."
Press 3 to reset your VM password.
After a few seconds, iPhone will display "Password Incorrect - Enter Voicemail Password."
Enter the last seven digits of the wireless phone number and tap OK.
Reset voicemail password from AT&T's website
NOTE: You must be registered and logged into myWireless Account to view this information.
From the myWireless Account home page, select Phone/Device then choose the Reset Voice Mail PIN link from the left column.
IMPORTANT: If there is more than one line on the account, make sure the correct wireless number is displayed in the Wireless Number list before selecting Reset Voice Mail PIN.
To reset the password for any of the lines on the account, choose a wireless number from the dropdown menu
Click Submit.
Dec 17, 2010 | Apple iPhone 3G
Suddenly getting "password incorrect" message for
Enter the wireless number starting with area code .
Click Submit.
Nov 01, 2010 | Apple iPhone 3G
I had to restore my phone yesterday because I was trying to update it and for some reason it messed it all up. So I finally got it semi restored and I still can't use it because the password incorrect...
Click Submit.
Oct 19, 2009 | Apple iPhone Smartphone
Voicemail does not work
Had the same problemwith my iPhone 3G this is how I fixed it -
1) From the iPhone 3G, I called my own iPhone 3G number.
2) Went through the setup. After finishing the ssetup Hang off the iPhone 3G.
3) Then the voicemail button on the iPhone 3G worked - first time, there was a **** pause, it asked me to enter my voicemail password that I had set in step 2, and that's it.
Good luck.
Jul 14, 2008 | Apple iPhone 3G
Apple iPhone Smartphone Logo
275 people viewed this question
Top Apple Cell Phones Experts
Lesley Cameron
Lesley Cameron
Ed Nelson
Ed Nelson
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
