Question about Maxtor Hard Drive
Maxtor 40gb error reading disk
I tray make a partition use f disk and I make 3 partition after I format C disk was ok after I format D disk was also ok and I tray format E disk shows wrong comannd than I tray again format and delate all partition and message was ERROR READING DISK and every time I tray diffrent program to solve problem always see error readind disk somebody can HELP thank you .edwardo
  • 119 Answers
SOURCE: Can't format or create partition......
you can try an FDISK form a windows boot disk, but you may need to read up a little on how to use it. or maxtor has a program available on their web sit called powermax that can try to find & repair possible problems. powermax may be the best & easiest way to go. good luck.
Posted on Feb 28, 2007
mumma_1
  • 903 Answers
SOURCE: I can't format the maxtor 3200
you need to create a partition first, then format it.
Posted on Nov 28, 2008
datadoctors
  • 5 Answers
SOURCE: Maxtor III does not show on connected.
Data Recovery Lab can recover data from faulty hard drives. They specialise in hard drive recovery, USB RAID data Recovery and laptop data recovery. For more information you can call 0207 516 1077 or visit www.datarecoverylab.co.uk.
  • No-data No Fee Data Recovery Service Guarantee
  • FREE data recovery analysis
  • Fast turnaround
Data Recovery Lab also provide FREE data recovery advice and consultation for all business and private customers in the UK
Posted on Mar 09, 2009
Crankstart
  • 696 Answers
SOURCE: Maxtor external harddisk recognition problem by pc
Hi Maxtarm,
It sounds like either the drive or enclosure is failing rather quickly.
The first and cheaper solution is to take the drive to your local computer shop and have the techs there move the harddrive into a new enclosure and test it. If it works in the new enclosure, you're done, but please take my advise and never rely on a single copy of your files. Always keep your important files in 2 or more places, on your computers hard drive, external drive and a backup to CD's or DVD's you can store in a firesafe or friends home is a good idea.
Now assuming that change of enclosures doesn't work, you will need the help of a recovery pro to get your files back. If that is the case comment back here with your location (Country, state, city) and I will advise you on a reputable recovery provider in your location.
Hope this helps Fixya,
Chris
Posted on Jul 15, 2009
  • 825 Answers
SOURCE: My Maxtor Athena 20GB hard disk is in error
delete the entire partition and do a quick format....
then do partition according to your requirement and try formatting...
if it still says error, then use any disk formatting utility like partition magic and try one more time....
still problem then you should take it back for replacement if it comes under warranty period....
Posted on Apr 20, 2010
300 gb hard drive but only 32 gb is visible
Check your jumper settings on the drive it sounds like youve got the jumper over the 32gig limit pins.....cheers from Scott and plz vote
Oct 23, 2010 | Maxtor DiamondMax 10 6L300R0 (6L300R020PK)...
Can`t install a O S on a new hard disk
you will need to run fdisk. to create a partition on the HD .
then format the drive c:
you can use any partition creator software
May 14, 2010 | Acer X193W LCD Monitor
Apr 20, 2010 | Maxtor Hard Drive
MY external hard disk maxtor is not detected
Is this a new Maxtor external drive? It came with a CD. Run the utility.
If there is no data on it that you want to save, you can also blow away the partition and format it:
Right-click [My Computer]
[Manage]
[Disk Management]
Find your external Maxtor Disk inthe list and / or graph
Right-click on the disk and select either "Format" or "Delete Partition"
(try format first) Use "NTFS quick format"
If you delete the partition, then "Create Partition" and then format.
You can assign a drive letter or accept whatever it assignes (probably Drive D)
*done*
Sep 30, 2009 | Maxtor / 80GB / 7200 / 8MB / SATA-150 /...
Want to format for pc
Since you want to format it, let's blow away the partition:
1. Right-click [My Computer]
2. [Manage]
3. Disk Management]
4. Find your Maxtor in the list or graph.
5. Once you are certain, then right-click the Maxtor entry (or graph) and select "Delete Partition"
6. Answer [Yes] to the next scary question.
7. If it has other partitions, you may want to examine them and delete them later.
8. You can now "New Partition" (right-click)
9. The create a "Primary" drive and format it.
*done*
Sep 25, 2009 | Maxtor OneTouch 4 500GB External USB 2.0...
Seagate 40 gb big problem please
I'd take a look at the <a href="http://segate.com">Segate</a> website.
Dec 16, 2008 | Seagate 500GB Maxtor Diamondmax21 SATA2...
Hard Disk Partition
you have make Bookable floppy to boot & restart when it show 3 types you can choose without cd rom sopport and type fdisk then u can edit from there.
Sep 21, 2008 | Maxtor Hard Drive
DVD-Rom drive doesn't work.
right click my computer .. manage.. storage.. disk management. unalocated. its totaly empty . create partition then format it ntfs and name the volume uhhhh USB160GB for easier to recognize
May 17, 2008 | Maxtor Hard Drive
SEAGATE HARD DISK DRIVE PROBLEM...
I am venturing a guess, but it could possibly be your memory and not your hard drive.
Additionally, you can partition and format the 40Gb HD in a second PC using a third party utility such as Partition Magic which would also allow you to verify the integrity of the hard drive
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 01, 2008 | Seagate HDD 40GB 7200RPM ATA100 2MB...
Maxtor Hard Drive Logo
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
