Question about Samsung Digimax V700 Digital Camera
Lens(?) issue everytime i power on my v700, the image is blurry. i have to hit the camera against my hand in order to make the image clear. is there a way to fix this?
    Problem Solver:
  • 57 Answers
Hi, your problem is relating to focus. It is not the right way to hit the camera against hand to get clear picture. It may cause serious problem. Actually your camera is not able to focus, it may be because of mechanical jamm of lens. Camera needs service. I suggest you to go to nearest repair shop or Samsung shop.They can handle it better. good luck.
Posted on Jul 25, 2006
The video image keeps coming blurry
The focus ring in the lens assembly could be jammed up by dust, lint, sand, or dirt. Try to spray some compressed air into the lens assembly to free it up. If that doesn't work, sometimes you can gently hit the camera against the palm of one hand, in the hope of freeing it up.
Otherwise, you will have to have it serviced.
Good luck, and hope this helps.
Dec 11, 2010 | JVC Everio GZ-MG155 Camcorder
The camera lens is blurry. Not clear focus.
1) Check if there is a ring on the lens that you can adjust to sharpen the focus, 2) try the tips in the article How To Improve Your Webcam Video Quality.
Apr 12, 2010 | Philips SPC315NC Webcam
Blurry images
If it is brand new, return the camera, and show what is happening.
The blurry pictures has to do with a few things. A damaged lens system, a dirty lens, other damage to the lens while it was extended, water or moisture damage can also cause this, including internal circuit damage or broken parts.
Make sure it has not had an impact or other damage, because if it had, then more than likely you will have no warranty, and it will not be taken back by the store.
Oct 25, 2009 | Cameras
Blurry pictures
THE IMAGE SENSOR OF YOUR CAM ARE HAVE A BURN SPOT
Aug 18, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
When i look through my lens, its blurry
Adjust the viewfinder diopter to suit your eyesight. The control is near the viewfinder; try adjusting it and see if the image clears up. Be careful not to poke yourself in the eye as you do this.
Jan 21, 2009 | Canon EOS Rebel Ti / 300V 35mm SLR Camera
Everytime I take a picture it turns out blurry
Inside the lens their is a focus motor that has to be perfectly set if it get out of ajustment this will cause a blurry image it you try to zoom some times you may get a lens error this is because the lens has been obstructed from the inside by the focus lens. the lens eather needs to be replaced or rebuilt.you may find a broke one off ebay with a good lens pretty cheap if you are going to try and repair it your self.
Mar 20, 2008 | Mercury Electronics CyberPix S-555V...
FD 200 MAVICa won't focus
Do yopu remember if the front (lens) area received a hit, even though with low force?
I am asking because in most MVC-FD cameras I opened to fix them about the same focus problem, I did find that an internal bracket that holds the lens assembly, it was bent due to an external force or hit in the front.
The bent bracket really was not the problem. The reason of the focus issue was that when the bracket was bent, the flat ribbon cable of the lens was pressed against a mounting screw, causing that the flat ribbon cable was damaged (punctured) affecting 2-3 traces of it, and preventing the lens to operate properly.
Repairing such problem requires to either replace the damaged flat ribbon cable, or the whole lens assembly.
You can get your hands in a broken camera with good lens assembly, and swap the parts.
Best regards,
Feb 25, 2008 | Sony Mavica MVC-FD200 Digital Camera
Focus on DSC-W5 doesn't work
Hello Woodyallen, in order to repair your precious camera you should replace the Lens Block Assy, part number A1105719A. Please contact your nearest Sony Service. Best regards, Arpad
Dec 21, 2006 | Sony Cyber-Shot DSC-W5 Digital Camera
Camera Problem with Toshiba TLP 261
hi Document camera image is blurry: -The lens is dirty - Clean the lens with a blower or lens cleaner -The picture is out of focus - Focus the picture by turning the focus ring -The light is not on - Turn on the light check user manual for more details: http://www.fixya.com/BrowseManual.aspx?mnlid=5662&prdid=147420&__PAGED_=1 good luck
Mar 27, 2006 | Toshiba TLP 261 Multimedia Projector
Samsung Digimax V700 Digital Camera Logo
77 people viewed this question
Top Samsung Cameras Experts
Computer Links
Jerry Z
Are you a Samsung Camera Expert? Answer questions, earn points and help others
