Have purchased a set of speakers, how do i install them
  • 849 Answers
Dont need to install the speakers, if soud driver is installed the just put the speaker jack in green hole you will find back of computer.
Posted on Oct 21, 2008
Hello there, I recently purchased a Logitech z-5500 speaker system online, I have plugged all the speakers and set it all up correctly. It makes sound when I pres the "Test" command on the...
verify if the computer has a digital output that matches your speakers (5.1 or 7.1). Also, verify that the cable leading from the PC to the main speaker box is OK. Also, the speakers may come with an installation CD, so you'll need to install the accompanying control application.
Jan 02, 2011 | Logitech Z-5500 Computer Speakers
I have purchased a new Philips DSP 3300 hometheater. I have installed the same. However I have not connected the DVD player to the TV and have not changed its factory setting. Its conencted as is from the...
i have purchased philips dvd and philips home theater 5.1 3300w model. how to connet to the home theater to dvd and tv. because i miss my home theater manual book.
Oct 06, 2010 | Philips Audio Players & Recorders
The base in my A525 dell speakers went out. The Subwoofer is still good. This there a way to purchase new speakers w/o purchasing the subwoofer
Yes, i have a brand new set of DELL A525 Speakers, reply to this solution on FIXYA (ie say you want them) and i will put them on EBay for you to purchase on a (buy it now) so you you can have them straight away, £10 + P&P £2.70 or give me your email on here and we can sort it out that way. (set up a disposable email address or you may get spammed)
Cheers Chris
May 19, 2010 | Dell A525 Computer Speakers
I have lost the driver for my OZAKI C-MOUTH speaker system CM699. Where can I get one
Dear
1st
My computeris 2.1 output But, i have purchased 5.1 speakers.only 2 speakers r workin.Wat to do?Any softwares?except Audio card.
2nd
If you are running Microsoft Windows 2000 or Windows XP make sure the speaker setup is correct. It is possible that during an installation of another program that these speakers are automatically changed causing issues with your sound. To do this follow the below steps.
Open Control Panel
Open "Sounds and Multimedia Properties" in control panel.
Click the "Audio" tab.
In the Audio tab click the "Advanced" button under "Sound Playback".
In the Advanced Audio Properties window make sure your speaker setup is correct. If you're not sure what to set this setting as, set it to the default "Desktop Stereo Speakers" option.
If you needed to change this setting click "Apply" and close out of all windows.
Mar 02, 2010 | Computers & Internet
I purchases logitech S120 speaker system for my dell. Hooked up per instructions but computer states no system installed and I get no sound.
check it is ok or not in another computer.
go control panel and click speaker and sound option look setin option and set it,
Nov 04, 2009 | Logitech Z4 Speakers
Purchased an LS11 installed it, and it doesn't on my Dell OptiPlex GX270 with Windows XP Professional. Can you help me?
Check whether u have installed the speakers correctly. if u installed them correctly then goto control panel and then go to sounds and audio devices. there u check speaker setting and make it 5.1 . hope this helps.
Aug 21, 2009 | Audio Players & Recorders
Loss of sound to pc speakers after installing Bluetooth speakers
Computer is sending signal to bluetooth only. Check in your sound settings to see if computer will allow enabling of both. Hope this helps.
Dec 22, 2008 | Logitech Z-560 Computer Speakers
Speaker problems
First, make sure the speakers are plugged into the center green connector.
Second, go to Gateway's website and download the latest audio drivers for your system and reinstall them. That should do it.
Dec 22, 2008 | Gateway (G-MAX2000) Computer Speakers
Hooking up a new 8" woofer speaker to my amplifier
If I'm reading the amp manual right, you should be able to connect the amp in 3 channel mode. To do this:
  • Connect both left door speakers in parallel to Ch A Left.
  • Connect both right door speakers in parallel to Ch A Right.
  • Bridge Ch B and connect it to the new 8" sub.
  • Set the Ch A LPF/HPF to HPF.
  • Set the Ch B LPF/HPF to LPF.
This should allow you to run all 4 door speakers and the sub from the amp. It will also automatically route non-bass to the door speakers and "only bass" to the sub.
Mar 22, 2008 | Pioneer GM-6300F Car Audio Amplifier
Help installing speakers
download latest sound driver for your computer do custum windows update
Jan 27, 2008 | Audio Players & Recorders
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
