Question about HP Compaq Presario V2000 Notebook
What dose Audio Device mean?
Hi my name is kristen freeman. how can i get my sound back.
  • HP Master
  • 4,338 Answers
Re-install the audio drivers from Hp's web site:
here is the link:
http://search.hp.com/query.html?lang=en&submit.x=6&submit.y=6&qt=Presario+V2000&la=en&cc=us
You have to pick you model from the list, then select drivers and software link. then select your operating system.
Your model # is on the bottom of the laptop on a sticker.
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Oct 24, 2008
There is no audio driver
You can download the audio drivers for your computer from the manufacturer's WEB site.
I cannot give you the link to the manufacturer's WEB site because you have not provided the make and model of your computer.
Dec 30, 2010 | Computers & Internet
No sound device in my laptop
reinstall the audio driver.
Dec 03, 2009 | Computers & Internet
I recently got my computer fix but it came back with no audio.
Did you check that compatible driver for your audio device is installed Properly? Go to Device Manager and verify. if there is yellow marked device error with name of Audio/Sound you need to update this driver.
Go to;
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=04&l=en&s=bsd&ServiceTag=&SystemID=DIM_P4_E521&os=WW1&osl=en&catid=&impid=
Download and install/update this driver, reboot your system and check audio output. Hope this will work for you.
Best of Luck,
Regards;
Hassan
Jul 27, 2009 | Compaq Audio card Sound Card
Dell Dimension 3000 system recovery
AH yes, Kristen very familiar with your issue, it is trying to load the primary boot record from a device it dosen't see , ( re: a floppy thats not there) you need to check the BIOS and make sure the booting sequence is correct (re:disable floopy if one dose not exist, etc) please write back if you need help doing all of these things
Apr 18, 2009 | Dell Dimension 3000 PC Desktop
No sound icon and no sound can hear
you can have a check whether the audio driver is installed or not by the following step :
go to control panel (classic view) > sounds and audio devices
if it display no audio device installed means then the drivers are not installed ...
if it allows you to adjust the volume means then the audio codecs and drivers are installed and it shows the name of the audio driver ...
if it not installed means then you must download the audio driver from net ... to download from net you must first know the model of your motherboard then you can go the manufacture site and you can download it from there ..
if you give me your motherboard model means i will give you the link to the driver ...
if you have downgraded your operating system than the recommended means let me know your motherboard model i will provide you the link to the drivers ...
if you have not downgraded means then you will have the drivers in the motherboard manufacture cd which will be given to you at the time of the purchase of your motherboard or the pc ...
regards
-Dileep
Dec 06, 2008 | Compaq Audio card Sound Card
Onboard sound card driver
hi did you try this ??
http://www.downloadsource.net/7653/SiS-7012-Audio-Chip-Driver-Windows-9x-NT4-2000-XP-32-bit-XP-64-bit-2003-64-bit/
Sep 15, 2008 | Intel Frontier Design Dakota 24-Bit PCI...
How do i install audio output device
No Audio Output Device Installed
Some users have been experiencing problems with a "No Audio Output Device Installed" error when trying to play music, or when hovering the mouse over the speaker icon in the system tray. You may get a white X in a red circle to indicate this error.
Go to the device manager by pressing WINDOWS KEY + R to go to the run menu, and then run "devmgmt.msc".
From here, select your malfunctioning audio device(s) and make a note of the driver name. Then, right click on it and select Uninstall. This will remove the audio drivers from your system.
Once this is done, re-load the drivers for your sound card from the CD your manufacturer gave you with your PC or sound device. If you cannot find this, search for the driver on the manufacturers website using the driver name that has been written down. No Audio Output Device Installed
Aug 26, 2008 | Toshiba Satellite A135-S4527 Notebook
The sound from my acer laptop, is turned of how do you turn it back on so i can hear music, and movies
Then go to control panel,system ,hardware ,device manager option
There if u find any question mark or exclamation mark in yellow Color that means sound drivers are not installed properly
please reinstall sound drivers properly
or else
In control panel , select sound audio devices open it there u have
volume,sounds,audio,voice,hardware options
1)See whether it is mute
2)In audio option select default audio device and recording device
should be same
this should solve u r problem .if it is not solved please let me know u r problem briefly
or else put the model number and brand name followed by drivers search in ww.google.com
Aug 26, 2008 | Acer Computers & Internet
No audio device
or else
should be same
Aug 25, 2008 | Computers & Internet
NO AUDIO DEVICE
Hi, left click the start button & open control panel, than open the System icon. Click the hardware tab, than click the device manager button. Scroll down to & open the + sign next to sound, video and game controller. Do you see a yellow ! point or a red x ? Than your audio software driver is not installed. Your PC most likely came with a driver cd. Load that into your cdrom drive & install your sound driver software. If you post back the model no# of the PC & Mfg's name or the motherboard's name and model no# (or both). I can find it on the net & post it's link for you to install here. (Your choice).
Good Luck!
Mike
Mar 28, 2008 | Computers & Internet
HP Compaq Presario V2000 Notebook Logo
41 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
