Question about JVC C-20010 20" TV
MY T.V only the ontimer is on
I got up and tried to turn it on but it wouldn`t. The on timer is on but the the screen will not come on.Can someone help me? When I plug it in only the on timer blinks red. I have no idea how to fix it.
    President:
  • 3,130 Answers
Sounds like you got a problem with the power supply on the TV set and unless your experienced with electronic repairs, your gonna have to seek out a pro to assit you with this repair. Sorry i could'nt assit you more in this matter. Good Luck
Posted on Jul 24, 2006
IF I HAVE 18 JOBS FOR THE MONTH 14 ON TIME FIVE LATE WHAT IS MY ONTIME %
Your "ontime" percentage is 77.77% or 77.8% or 78%
(ontime jobs)/(total jobs) x100% = 77%
May 01, 2014 | Office Equipment & Supplies
2000 Pontiac Grand Am SE security system wont let car start
first most GM OEM systems will need to recognize the key first and foremost ,to do that you will need to roll window down on driver door,turn the key to the run position and with engine NOT running leave the key on for 10 minutes exactly ..then turn ignition off then try to start engine. if original system is working engine should start normally
Mar 26, 2017 | Cars & Trucks
Dryer not turning on.........before I would change the timer setting and it would would work.......after a couple of weeks, when i change the timer setting it wouldn't turn on at all. Question is
Definitely sounds like a timer problem. Sears Parts Direct should have your part. The model # you supplied is incomplete to determine if you have a gas or electric dryer. Check the model # again and go to Sears page to find the correct part.
May 08, 2012 | General Electric DBXR463EG Dryer
Wont Display Anything , Black Screen !
The screens brightness might be set to the lowest number as a joke. Try to change that.
Dec 09, 2011 | Texas Instruments TI-84 Plus Silver...
Recommend a timer 110 volts for submersible water pump in well
I think each tab is 15 minutes. If you don't care about a real time clock you could use a dual range plug in timer like a Omron H3CR-F. This has a on time setting and an off time setting
ON- and OFF-times can be set independently and so combinations of long ON- or OFF-time and short OFF- or Ontime settings are possible.
Fourteen time ranges from 0.05 s to 30 h or from 1.2 s to 300 h depending on the model to be used. Thes only have likd 5A contacts so you might have to have the timer operate another realy to control your pump.
Jul 19, 2010 | Paragon 1015-00RS Indoor Multi Operation...
Door will not unlock after self clean.
It's probably the timer motor which is stuck. unplug the range!! I recently had the same problem with my whirlpool (hereinafter known as **** inc.) range. Self cleaned the oven and then the door wouldn't open. Googled up similar problems and generally found out that ****inc. had this problem on both gas and electric ranges and it costs an arm and a leg for a new board plus labor. Found out how to manually open door with coat hanger but of course still had problem with same error messages; also the oven, clock, etc wouldn't function. Took the cover off the back of the stove. UNPLUG THE STOVE On the left rear facing the back of the range he found the timer motor had stopped.He unplugged input(230 volt power) leading to the stove, then unplugged and insulated the wiring to the timer motor and the microswitch on top of it ( 4 wires). Then he took the long steel wire off of it and unlatched the oven door. Told me that this probably had something to do with the timer motor on the self cleaning cycle and that it was stuck Said this whole thing could probably be fixed with a bit of WD40. Said probably nothing wrong with board but it sure must be a moneymaker for **** inc. The service techs probably clean the timer motor, say they changed the $300 board, and go on their way. Plugged stove back up and voila! Everything worked except self cleaning function. Hope this helps someone. caution!!!! Do NOT use the self cleaning function unless you fix the timer motor. Replace it or clean it.
Nov 21, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
JVC C-20010 20" TV Logo
44 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
