Question about Epson Stylus Photo 820 InkJet Printer
Printer Parts Worn Out
My Stylus Photo 820 reported an error message I haven't seen before. It said something like "Select printer parts are worn out - contact service representative" Has anyone seen that? Is it fixable, or is it time for a new printer?
  • JHCHAMBERS55 Oct 30, 2008
    i HAVE THE SAME PROBLEM AND AM SURE I'M BEING SOAKED FOR A NEW PRINTER...ANY NO OF A REBOOT TO GET RID OF THIS MESSAGE
  • David A. Fay Jan 09, 2009
    Printer parts worn out - need service
  • 353 Answers
This is usually a sign that the Waste Ink Pads in your printer are saturated with ink and the waste ink counter has exceeded its limit. However, your two printer lights should also be flashing alternately.
If this is the case, the Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
http://www.ssclg.com/epsone.shtml
and reset the Protection Counter. This will stop the lights flashing and restore normal operation. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. If you want to have a go at doing this yourself, the 820 service manual can be downloaded from here:
810/820 http://www.mediafire.com/?m6ouftizois
If the printer lights are not flashing, you really need a technician to have a look at it for you.
Posted on Feb 01, 2009
Error code 0001002D is displayed and can not clear
Thank you for the inquiry.
This usually is a Epson Large Format printer error. You will need to replace parts to clear.
blank.gif headerline.jpg header.jpg epson_loyality.gif blank.gif menu_background_l.gif home_off.gifseparator.gifcoveragearea_off.gifseparator.gifservices_off.gifseparator.gifprinters_off.gifseparator.giftechnical_off.gifseparator.gifsearch_off.gifseparator.gifenquiries_off.gifseparator_r.gif menu_background_r.gif blank.gif 0001002D Cleaning unit EOL
Just like any other mechanical equipment, a printer requires attention to keep it running smoothly. So, just like when the check engine light illuminates on your cars dashboard so does your printer, but instead of a spanner the error 0001002D will appear on your control panel LCD which is informing you that a maintenance procedure is due to be performed. This will normally involve replacing the parts which keep the print head clean, hence the error "cleaning unit END OF LIFE" and the waste pads. This procedure can be undertaken here at Large Format Repairs for the Epson Stylus Pro 3800 right upto the beast that is the Stylus Pro 11880.
worn_flushing_box.jpg worn_cap_assembly.jpg Worn flushing box Worn cap assembly worn_head_wiper.jpg worn_carriage_waste_pad.jpg Worn head wiper Worn carriage waste pad
Jun 03, 2011 | Office Equipment & Supplies
Message "Service required. Parts inside your
You'll probably find that that the print head is worn out (according to Epson) and it needs to be replaced. It's cheaper to buy a new printer.
Mar 13, 2011 | Epson Stylus Photo RX700 All-In-One InkJet...
Epson Stylus Photo R350 giving a paper jam error message
An Epson service man (he was VERY kind to suggest this) told me to use a weak detergent solution on the rollers, NOT alcohol as that will dry out the material the rollers are made of. Although the problem has recurred a couple of times, it's worth repeating when necessary. I actually activate the 'print' command so it tries to feed in paper, while I FIRMLY hold a piece of fine cotton cloth stretched over a thin plastic ruler, which I hold down where the paper feed grabs its paper. The printer has a couple of tries to feed paper, reports an error message (because there was no paper) and I activate it again, thus exposing the WHOLE of the feed wheel to the cleansing cloth! WORTH A TRY!
Jan 30, 2010 | Epson STYLUS R350 Photo Printer
I have an epson stylus photo R200. It has stopped working and has alternate red flashing lights. Error message says serviceable parts are nearing end of life. How do I get it to carry on working?
I'm not sure about the servicable parts. You might want to contact Epson.
I have seen "parts are nearing the end of life" which applies to the ink pads that absorb excess ink. In that case, the printer needs to be replaced or serviced by Epson or an independent service provider. If you just get the ink pads serviced, it may still fail soon. Then you can run the resrt utility. For more information and the reset utility: http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp?cookies=no&com.broadvision.session.new=Yes
I hope this helps.
Dec 15, 2009 | Epson Stylus Photo R200 InkJet Printer
Install epson stylus photo 820 printer
Hi
you can get the software driver at www.support.epson.com
just select the printer driver and download it//
Jul 17, 2009 | Office Equipment & Supplies
Epson stylus photo 820
Hi Ikarp9090
If both lights are flashing, it usually means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. You can restore your printer to a working condition immediately by using the SSC utility - download from:
Install it, and double click the ssc printer icon in the bottom right corner (System Tray). Choose Configuration and set your printer type (820), then close the ssc window. Now right click the ssc icon in the sytem tray and choose Protection Counter. You should see that the current count is above the limit; then choose reset to set it to zero. You will need to fib about having changed the waste ink pads! Turn the printer off then back on again. This will stop the lights flashing and restore normal operation.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help. It is a pretty simple job once someone explains how to get the case apart!
If this solution helps you, please rate it; if it doesn't, please provide further information by posting a new comment.
Apr 29, 2008 | Epson Stylus Photo 820 InkJet Printer
Epson Stulus photo 820
A very strange effect new to me (and I'm ****** old). All I can suggest is to uninstall the printer, reboot and reinstall. Report back.
Apr 06, 2008 | Epson Stylus Photo 820 InkJet Printer
Epson Stylus Photo 820 InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
