Question about Canon imageCLASS D860 All-In-One Laser Printer
Line on ADF feeder
I have cleaned the roller but still have the line. Its ok if I scan on glass but line comes on paper when going thru the ADF
  • villads Oct 22, 2008
    Would if I knew how to get inside machine.
    Master:
  • 788 Answers
Clean the narrow piece of glass inside the machine next to the large glass.
Posted on Oct 21, 2008
  • Dean Joly
    Dean Joly Oct 22, 2008
    You don't need to get into the machine. Just open the lid as if you were cleaning the large glass, you should see a smaller strip of glass at the left end.
  • Dean Joly
    Actually on your machine it will be on the right.
When I use the printer to scan via the document feeder, I get two parrallel lines down the right hand side of each page of the pdf. I've cleaned the glass and everything else but still get the lines....
Open the scanner cover and you will see two glasses. One long and thin and the other larger than an A4 sheet of paper. The long thin glass is used to scan thru the adf and the larger glass is for flatbed scanning.
As your lines are from the adf scanning, you will see tippex on the long thin glass. just clean it off and all will be well. Clean the flatbed glass as well while you are doing the job on the adf glass.
Sep 29, 2011 | Brother MFC 7420 All-In-One Laser Printer
Black line in paper
On what operation are you receiving the black line in your paper?
This problem usually appears when you try to scan or copy using your ADF (automatic document feeder).
To remove this black line in your paper, clean the ADF platen glass in your printer and do as well in the flatbed scanner glass. This ADF platen glass can be found right below where the documents in the ADF goes through. Its a glass about 1 inch in with and beside the flatbed scanner glass (the one where your documents is lay down for copying and scanning. Dried ink or paper residue sticked in the glass can cause this line in the paper. Clean it with a a clothe and spray some windex on it.
Feb 10, 2011 | Panasonic KX-FLB801 All-In-One Laser...
My feeder to scan puts a line down the entire document - the line doesn't appear when I scan from the deck of the printer. I've attempted to clean the rollers but the line still appears on my document?
You don't say what kind of printer you have.
So, I will generalize my answer.
The reason for the line using the ADF and no line with the flatbed is that the paper is moving when using the ADF. So, a piece of dirt, dust or whatever on the ADF glass will cause a line because the paper is moving over a mark on the glass. The copy made on the flat bed glass doesn't move, so no line.
Anyways, clean the thin piece of glass that should be to the left of the big flat bed glass. That will fix your problem
Jan 20, 2011 | HP Office Equipment & Supplies
SCX 4826FN everything that goe in through the top feeder (scans, copies, faxes) comes out with a solid vertical black line on the paper. All other printing jobs that pull paper from the tray are ok. It...
This black line sounds like it is definately coming from the ADF scanner glass. This is the thinner strip of glass that is located just to the left of the large original glass. You can verify this by making a copy from the large glass instead of using the feeder on top. If the copy comes out clean then it is definately the scanner glass. Just clean the glass well with glass cleaner and a soft cloth. This glass is only used when copying/scanning using the top automatic feeder
Good Luck and Thank You for using Fixya.
WheatlandServices
Nov 04, 2010 | Samsung Office Equipment & Supplies
When I copy using the automatic feed I get lines the full length of my page. When I put on glass it comes out ok. HP5610 all in one
clean the scan glass in the adf feeder its dirty or has white out or something on it. its a small **** glass where the paper feeds thru
Mar 31, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Black vertical lines on faxes sent using auto document feeder
If you lift up the lid on your scanning device you will notice a glass strip about 1 inch thick and then the large area of glass used for flatbed scanning. The 1 inch strip is used for ADF scanning. Because your papper is moving across the glass strip, any dot, smudge or scratch will affect your scanning and cause verticial lines down the page. Sometimes the dot is not visible to the eye. Get some glass cleaner that has alcohol in it and thoroughly clean the glass strip and it should solve your problem. If it turns out to be a scratch on the glass then cleaning won't help.
Nov 15, 2008 | HP Photosmart 375 InkJet Printer
Vertical lines when scanning using automatic document feeder...Glass is clean
It is not in the glass. More than likely it is in the rollers of the ADF feeder. If you open the cover of the ADF feeder you can see there are 3 screws (! is found under another small cover furthest to the back of the machine. Once these three screws are removed you can left the entire ADF feeder from the unit. You will then be able to clean all the rollers. Do not use alcohol as this will dry our your rollers and cause them to eventually crack. Just use soap and water to clean the rollers. Then reinstall the ADF feeder assembly back on the machine.
Nov 08, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Line in copies that go thru feeder
Over time the automatic document feeder (ADF) will get dirty, occasionally causing vertical black streaks or lines in scans and copies .
Manual cleaning of the ADF might be necessary. Follow the procedure below to manually clean the ADF .
You will need the following materials:
  • Soft lint-free cloths
  • Glass cleaner
if you look carefully on the left side of ADF ( top feeder ) there is an assembly which u can lift , there wud be a set of rollers if u lift that part there would be a glass strip . u are suppose to clean that strip .
While holding up the inside of the ADF, clean the glass in the location of the vertical streak with one of the cotton swabs. Try cleaning the glass first with a dry cotton swab. If that does not correct the problem, then moisten the swab with glass cleaner .
If the vertical lines or streaks still appear, go through the above cleaning process again, this time cleaning the entire surface of the ADF scanner glass.
and after this try the following steps as well .
CAUTION: Use only glass cleaner. Avoid abrasives, acetone, benzene, and carbon tetrachloride, all of which can damage the scanner glass.
Apr 19, 2008 | HP OfficeJet 7310 All-In-One InkJet...
CANON PC-1080F feeder error message
Well, open the adf and see if there's anything jammed in there. While you are at it, clean all the white out off the rollers and the scan glass. Then make sure the ADF cover is snapped shut properly
Feb 27, 2008 | Canon PC-1080F Plain Paper Laser Fax
Black lines
Here you go.
1. Put a paper on the glass don't use the ADF see if you printed copy has a black line on it.
If you do not have a black line on it, do the following.
Lift up the ADF tray go in to additional functions #6 Adjust/Clean and then #2 clean the ADF feeder.
The roller is in the top of the ADF feeder at the right and is white in color. When you press the (set) button you will see it spin.
Also clean the glass you have some whiteout on it. (Look at the glass real good when cleaning it).
Nov 19, 2007 | Canon imageCLASS D880 All-In-One Laser...
Canon imageCLASS D860 All-In-One Laser Printer Logo
117 people viewed this question
old marine
old marine
Corne Viljoen
