Question about Panasonic PV-9451 VHS VCR
Dean I place in a vhs tape,and the screen is blue.Why am I getting a blue screen instead of a picture
  • 1 more comment
  • Dean Serra
    Dean Serra Jul 24, 2006
    I get no sound from the tape in the vcr.I do get sound from the vcr's tuner when no tape is in.
  • vivalabam Mar 31, 2009
    When playing a VHS the screen is BLUE. Unless I play it on fast forward mode, then I get a fuzzy picture.
    Not all VHS's will play BLUE. Only some, about 75%.
    Whats happening?
  • Anonymous Mar 29, 2014
    The screen is snowy and goes blue while playing a vhs tape
    Novelist:
    Champion:
  • 275 Answers
If you can hear sound thru TV tuner or thru the Audio - video inputs, in all probability it is a case of Dirty Video heads. Get yourself a good 'Wet type' Head cleaning Tape, and clean the Video heads. It should do the trick!
Posted on Jul 26, 2006
    President:
  • 3,130 Answers
Do you hear sound? if you dont then the TVs not set to the proper input or channel . Is the VCR hooked up the way it always was or did you just install it? If you didnt then if you here sound then the heads are dirty or theres a problem in the video section of the VCR answer these few questions and Im sure we can get this thing going or at least find out the problem.
Posted on Jul 24, 2006
I bought a panasonic cassette adaptor for my vhs-c tapes . it says svhs adaptor on the front of the box .will the ordinary vhs-c tapes fit in it and does the door open on the front or is it loaded from the...
You don't specify the adapter you have, but most load from the top. The main thing here is that VHS and VHS-C are both the same size of tape. Whether they are recorded in SVHS mode or not will not affect the adapter, just whether or not you get a picture. Theadapter only allows you to put a compact cassette (VHS-C) into a standard VHS VCR. The adapter will require batteries to allow it to place the VHS-C cassette tape into the proper position for use in the VCR.
Dan
Nov 24, 2010 | Panasonic PV-P1 VHS-C CASSETTE ADAPTOR
Cannot view tapes. Picture fuzzy, interference lines on screen.
Well I have heard that sometimes the tape inside of the videocastettes that show the pictures on the screen wears out over time periods and from rewinding and fastforwarding so many times or the old age and useage so you could get the video castette tapes fixed but its not worth it now you should buy a DVD player because they are better and have less problems and most VHS tapes are on DVD too. Or check to see if any other devices are on at the same time.
Feb 23, 2010 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Vhs tape won't play
sounds like to me the tape is to tight .try rewinding the tape all the way then fast forward all the way till it stops repeat and it should loosen up. if not the tape is no good the blue screen might go away after the tape is loosened n try cleaning the tape player good luck
Sep 19, 2009 | JVC DF420 D-VHS Tape
VHS-C tape jumpy when playing back
My apologies, I overlooked the "-C" in your post.
This problem is due to a type ofcopy protection built into vcr's.
"Macrovision" copy-protection is merely a weakening of a particular part of the signal that makes up the picture and was primarily intended to prevent people from copying videotapes. I imagine almost everyone's seen it but probably didn't know what they were seeing: the resulting picture is a little jittery and is in black-and-white or alternates between black-and-white and color. The reason you're seeing a blue screen is because modern televisions, in the absence of a signal or a weak signal, will just show a blue screen instead of snow or a very poor picture. As mentioned above, you can get around Macrovision by inserting into your connections a signal amplifier that specifically amplifies the portion of the signal that Macrovision diminishes.
Feb 07, 2009 | Maxell HGX-Gold (4 pack) VHS-C Tape
No video out
Hi, All I get is a blue screen.  It does accept the tape, and I do get normal audio from the tape. I believe that I do get the words "play"  "fast", etc..., displayed on the t.v. screen  So I guess you could say there is that for a video signal - otherwise I would just get a static screen - I just get no video signal from the tape. Not sure what kind of soda (i.e. coke, pepsi, etc). Thanks again, Frank
Nov 02, 2008 | Hitachi VTFX6400A VHS VCR
VHS Sound - No Picture
try cleaning the vcr with a video tape cleaner
or maby the yellow video output need replacing the cord i mean
Sep 13, 2008 | Panasonic PVQ-M2509 Combo
VCS 442 Zenith
one way is to connect an antenna to INPUT of VHS, place a tape, press play, STOP and switch VCR\TV switch to TV. u should be able to change the channels from the VHS. If that don't work, u may have switch problems.
If this works, tell the boss..........FixYa.com
P.S. The 'blue screen' means that you don't have a signal to the antenna inpur\TV protion of VHS.
Mar 27, 2008 | Zenith VCS442 VHS VCR
Blue Screen
Could be dirty heads if you have a dry head cleaner tape try it (Maxell and RCA make ok tapes to try for ~:30-1min) ALSO:
There is a delay in the time you adjust the tracking and
the results being visable on the screen on this unit,
I suspect the tracking is adjusted off center. It takes some getting used to the way this deck's tracking adjustment works as the VHS video is upconverted to be captured onto the dvd and that is what you see, the upconverted video, fed out to your TV, analog or digital, this unit upconverts everthing to digital even analog channels, there needs to be a noise/blue screen off feature in the menu like my old hitachi VHS deck and my JVC ~$60 deck has now. On analog TV or old tapes it comes in handy for adjusting the tracking/antenna.
Feb 08, 2008 | RCA DRC8335
Refering to my last post
Screen will be blue. It Is known as video mute What happens when you play a cassette now? If you are still getting sound, and no picture, then the video heads are dirty. Get a good Wet Type Cleaning cassete and clean the Video heads. Do 2-3 runs of the tape, and check if picture is now visible.
Mar 29, 2007 | Sharp VC-A373U VHS VCR
Panasonic PV-9451 VHS VCR Logo
203 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
