Hcn653w(hdtv1080i monitor) serial *31fw4009341*the tv won't come on
    Brigadier General:
  • 6,966 Answers
Your post/description could be interpreted two (2) ways:
  • the unit is completely dead, no power indicator, no blinking LEDs (lights);
  • there is some indicator of power but unit will not come out of standy.
Corrective action may include:
  • power supply, check of the mains, circuit breakers, fuse, power strip;
  • determine if any other indicator such as blinking lights that may show activation of built-in protection circuitry. Normally the number of blinks and the sequence corresponds to a general area where to start diagnosis.
Either of the above stated possibilities calls for diagnosis internally and electrical power checks.Both of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 21, 2008
    Master:
  • 538 Answers
Any kind of lights, sounds or anything with that unit?
  • 13,433 Answers
The problem is most likely fuses or other problem in the power board. That is all Im able to say with the information you have given.
Can a TV be used as a PC monitor
Can't post a solution tho this problem, without getting the exact model number and brand name of the device. Serial number won't give us any details of it.
Jun 12, 2012 | Televison & Video
Samsung HCN653W DLP TV will not come on.
how sthe bulb on it is it new been chaged can u unplug unit for wile plug back in how many flasshes can u count usally flasshes meen a serv code
Jan 24, 2008 | Samsung HCN653W 65" Rear Projection...
On my hcn653w when i cut my tv on it produce a shadow of everything. what is the problem?
Convergence amps are bad....Replace them or the whole board. W/ any experiance it's fairly easy. If not it will run about $400-$500@ the shop.
Aug 05, 2010 | Samsung HCN653W 65" Rear Projection...
All of a sudden my 6 yr old samsung HCN653W has a
your cable box is effecting the component line in 1 or 2 in the back of the tv
Jul 12, 2010 | Samsung HCN653W 65" Rear Projection...
Hcn653w is showing ablurry picture. it will clear up for a minute and then gets back blurry.
Ur tv have a convergence problems,it dead.U know how to solders?U have a soldering iron,solders,solder Wicks?Tries Websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost $300-350 for parts and labors.
Mar 30, 2010 | Samsung HCN653W 65" Rear Projection...
Do not get any local tv stations
have you tried to have the tv learn the channels? if yes make sure the input cable works.
Dec 21, 2008 | Mitsubishi WS-55819 55" Rear Projection...
The TV turns on and off after a few seconds and repeats itself.
Hi.
Either the stk convergence modules or the vertical ic have failed.
replace the 3 parts and it should fire up again.
Nov 21, 2008 | Samsung HCN653W 65" Rear Projection...
Convergeance Board for HCN653W.
This is a very old post Do you do need Help?
Nov 13, 2008 | Samsung HCN653W 65" Rear Projection...
Please advise if you would be able to guide me as to where i could purchase tv parts...
Hello MMJB,
Here are the link to purchase your parts.
674e151.gifhttp://www.partstore.com/Part/MCM+Electronics/MCM/LA7845/New.aspx
183b00b.jpghttp://www.partstore.com/Part/Matsushita/JVC/TDA6111Q/New.aspx
4509847.jpghttp://www.partstore.com/Part/Samsung/Samsung/HCN653WX/Samsung/Samsung/0502001230/New.aspx
Best regards
circuitcity
Jul 09, 2008 | Samsung HCN653W 65" Rear Projection...
Akai HDTV1080i Monitor
Can you tell us the exact model?
Dec 02, 2007 | Televison & Video
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
