Question about Whirlpool LTE5243D Top Load Stacked Washer/Dryer
Washer Problem - Fills but doesn't start wash cycle.
I replaced the lid switch, then about four loads later I had the following problem: The washer fills, but then won't continue to the wash cycle. A faint noise could be heard indicating the machine was trying to wash. A Burning smell ensued, so we stopped the washer. We moved timer to spin cycle and it then drained and spun. Hope someone can help. Thank-you.
    President:
  • 878 Answers
Your model is a direct drive washer. It's very possible that after 4 loads your motor overheated. This could be the result of something passing through or caught in your pump at that time. If your coupler was broken, you would be able to drain but not spin. Let the machine cool down and see if it returns to normal.
Posted on Jul 24, 2006
    New Friend:
  • 163 Answers
You got a broken clutch and is ease to replace, tilt the washer to the floor with the motor in the upper position, remove the motor(two litettle scews) and remove the clucht(you will see it, is a small ruber pices) go and by a new($12.00us) one and replace it, replace the motor and thath is...good luck...
Washer Doesn't Start
once again check your lid switch where the lid hits when you put the lid down
Jan 15, 2013 | Kenmore 98702 Stacked Washer/Dryer
Fills with water then won't go to the wash cycle until you slam the lid several times
It sounds like the lid switch is faulty. The washer has a lid switch that checks to see if the lid is open, if lid is open the washer will not start the wash cycle. Check/replace the lid switch and you should be back in business.
Oct 04, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Sears Kenmore 80 series will not rinse or drain
A washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
Take note of your symptoms:
1. Washer fills, may or may not agitate, will not advance to the rinse cycle, and will NOT drain - lid switch.
2. Washer fills, does NOT agitate or spin, but WILL drain - motor coupling.
If you still have questions, please let me know. If the suggestions I have listed do not match your washer symptoms, please post back and elaborate more on what the washer is/is not doing. That way I can provide you with better assistance. I hope this information is helpful to you.
Jul 05, 2009 | Kenmore 24032\24036 Top Load Washer
UZltimate care II washer pauses for a long time between cycles
Jun 27, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer will fill up with water but will not start to agitate
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price. If you still need assistance, please contact me and let me know. If my diagnosis is not correct, please post back and elaborate a bit more so I can assist you further. If your washer is not configured this way, or if you still have questions, please let me know.
Jun 11, 2009 | Washing Machines
Washer stops after it fills and won't start again
Hi, you need a new lid switch. If you could get me a model #, I could get you exact info on the part and instruction.
please let me know if I can assist you fyrther.
Vic
Jun 01, 2009 | Kenmore 22642 Top Load Washer
Washer fills with water but does not turn on, I have replaced the wash cycle timer and I still have the same problem.
The washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, repairclinic.com or appliancepartspros.com. Just use your model number as your search criteria. All three sites offer competitive pricing, so shop all three for the best price. If you still need assistance, please contact me and let me know. If my diagnosis is not correct, please post back and elaborate a bit more so I can assist you further. If your washer is not configured this way, or if you still have questions, please let me know.
May 11, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool TAWB600EQ1 - Washer
ck lid switch usually on right side of lid opening or on later models under back corner at lid hinge area
Aug 10, 2008 | Roper RAS8244KQ Top Load Washer
Whirlpool LTE5243D Top Load Stacked Washer/Dryer Logo
77 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
