Question about Gateway Computers & Internet
What causes the mother board to burn out on a labtop it was left on overnite about 2-3 times
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 164 Answers
1.Well usually you dont wanna leave it on for that long in 1 session.
2. Your fan could've died which made your mobo overheat.
Posted on Oct 21, 2008
GE model #GSS201EMBWW is not defrosting, checked defrost heater and it was burned out. Replaced with new 2 heater design and now it burns all the time, which is most likely what burnt the other 1 out....
This is how the defrost works . I have NEVER found a defrost problem associated with a bad main control board since these computerized GE's came out in 2000 . Lots of thermistor problems , lying to the board , causing different problems .
Your GSS model refrig does not have a defrost timer . It works off of the main control board . Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater WR51X10101 . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off due to selected temperature .
Aug 30, 2010 | GE GSS25SGMBS Side by Side Refrigerator
The system getting restart continiously
just try to boot without hardisk if a boot screen appears showing that the motherboard have no problem . and then buy a new ram and insert it . buy a correct ram
Apr 26, 2010 | ASUS P5GC-MX/1333 Motherboard
Machine is not booting
  • I know what is your problem?May be problem on your HDD you change it then solve your problem.If you are not fix,You need Fox con MX PK g31 chip mother board.It is very adjustable motherboard for pin less p4 HT processor.
Mar 19, 2010 | Intel D946GZIS Motherboard
I have a hotpoint side by side freezer/fridge. model #HSS25GFPJ WW, it is on the list of units with defective mother boards. i was sent a new mother board for free and i installed it. i am still having a...
Your idea may be a good idea and worth trying. I would suggest if you do so, you perform a complete shut down, 24 hours minimum. This machine has been hell on wheels. Restart and check it's progress. I would suggest that you shut off the water supply to the machine during this time to eliminate complications.
As well, make sure the lights go out when the doors are closed.
The lights go out just before the door closes.
All settings to normal.
If the problem restarts I would call G.E. factory service direct and request a free service call. They owe you.
Oct 28, 2009 | KitchenAid Architect KBFA25ERSS Stainless...
Motherboard drivers asus
2 ways to do it one go to asus website and down load the drivers from there site and burn them to cd or go to driverguide.com set up a free acount and search the drivers one at a time downloading each of them again burn them to cd.
Jun 10, 2009 | ASUS Computers & Internet
GE Fridge, Compressor not getting power from mother board
I asked that because in most cases, when it is a problem in a motherboard, it is likely a power surge or lightening. I can also tell you that when it comes to mother boards and component level, likelihood, it isn't transistors or anything unless it smells or looks burned. Most shops would just replace the motherboard and ship it as repaired becaue the cost of the IC isn't worth the possibility of something in another IC on the same board knocking iit out again. Short of plug and play, you have no real way of proving this board good/bad. You might try EBAY with your model number to see if you get lucky. I just got rid of an electronic stove because the control board went bad. New board was $150 with a possibility of it going out in 6 months. As I am not made of money, I now have a gas stove. I you could, please rate this as a fixya as I am just being honest and saving you time and aggrivation. Good luck
Jan 10, 2009 | Refrigerators
Hard disk drive not found
It seems to me that the Hard drive or main board is damaged. To try this suggestion connect your hard drive to another computer and hope it DOES NOT WORK reason you are hoping this is cause if it does work you will need a new main board. I'm really sorry I cant do any more than that cause i know parts dont come for free. I have debated your issue for quite some time and i must say that is what is boils down to Unfortunately. When you try this and figure out which of the 2 is bad let me know and i will see how best i can assist. One thing that you may try if its the board is flashing the bios. Search the net for the instructions of clearing the cmos for your particular system. I Do Pray that clearing the cmos will work.
Nov 13, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Water/ice led indicator malfunction
Daniel, first check the harness that comes out of the freezer door bottom. Make sure it that is is connected right and there are no wires broken or pinched. Then check the dispenser board connectors. On the back right there is a main mother board. On harness J4, top left, 5 pin harness, check for a steady 12V DC voltage on pins J4-1 and J4-2, numbers reads from left to right. If you have this voltage, replace the dispenser control board. If you don't replace the main mother board. Catriver..post back.
Sep 17, 2006 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Computers & Internet Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
