SOURCE: Installation of Windows XP Pro on Hp Pavilion laptop
what is the error message that you're getting.. usually windows vista will not downgrade your operating system to windows xp. You may need to remove vista before you can load xp.
make sure to save a back up of all of your important files before you do that.
SOURCE: Can not start the Windows after reinstaling it
Try to clean up your cd recovery, maybe some file cannot copy while installing.
tips: don't clean cd with circle direction, just wipe straight direction from center to outer cd for better result.
hope this will help you.
SOURCE: Error loading operating system - Windows Xp
If you are attempting to use Recovery and this is happening, Most likely you have a corrupted recovery partition....
If you are attempting to load Windows XP from A CDrom (Externally)
you will need to use an XP Cd that has integrated Sata drivers.. Windows home/pro 32bit does not..
Or Use a Windows Media Center Edition Version
SOURCE: i downloaded a hard drive deletion piece of
I think the software has made your window files corrupt or it has deleted the window files. To solve this problem, I think you need to do a fresh windows installation. In the process of the installation, you could save the files on your hard drive, that is if they are still there.
Best wishes.
Testimonial: "Thanks for your suggestion - coincidentally this is the solution I am about to try! "
SOURCE: my laptop is compaq presario v6000 when i try
when you see the compaq screen press the f10 key then go to boot sequncing a make sure it says cd rom than hard drive try to find this option. Then save the settings and put the xp cd in then reboot again and it sood enter windows xp setup.
