I could not find any listing for this product. I hope you can help.
I believe the above product was made by a company named Southcorp Whitegoods, Australia.
I believe our convection oven/broiler has electronic ignition which appears to no longer be working:
When it functioned, I would twist one dial to "low" setting and then twist the temperature dial to the desired degress. The unit would begin to click and a flame would be generated from the broiler area which rose to the oven area and we could cook without a problem.
Now, I do the same and there is no clicking, no flame, but a slight odor of gas. Of course, I turn the unit off immediately then.
I have 3 questions:
1. Any idea of what the problem might be?
2. If it is the ignitor, is there a work-around to light the unit. I've tried manually lighting what appears to be the electronic ignition to no avail.
3. Could the broken mechanism (ingitor?)for such a rare oven possibly be replaced?
Any direction is appreciated.
-Chas
I have replaced spark modules and ignitors of ovens or ranges that you can no longer get parts for with whirlpool modules and ignitors. There are basically two types, just make sure you get the same type. One type , typically used by GE uses a continous ignitor that glows when it works, and Whirlpool (on most models) uses the spark module and ignitor that makes the clicking sound like your oven did for ignition.
Was this solution helpful? Show your Appreciation by rating it:
Post a New problem for Bosch HLK4525GB 900 Watts Convection
Email this problem
