Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Moved, now can't get the TV downstairs
The TV already needs a convergence chip repair, but I don't want to go through the trouble of getting it fixed if I can't get it down my basement steps.
Is there an Easy way to get the TV into two pieces so it can fit down the basement steps? my only other option is to rip up carpeting, take the stairs out, and then replace all.
thanks
  • Anonymous Feb 16, 2009
    The TV works fine, but we would like to move into basement family room and can't get down the stairs in one peice. Does it come apart?
    Genius:
  • 2,920 Answers
It went down the stairs in one piece it should come up the same way
Posted on Oct 29, 2008
How Do I fix the convergence on my 2001 Hitachi Projection Tv
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos aroundimages.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Jan 05, 2012 | Hitachi 53UWX10B 53" Rear Projection...
Picture has gotten darker over recent months regarless of signal source and continues to get darker. Brightness is set to maximum.
  • Screen looks 3D
Aug 02, 2011 | Hitachi 53SDX01B 53" Rear Projection...
My rear projection tv 51MP392H/17 has a blurred red shadow that makes it look kind of like watching a 3d movie without the glasses. for a while we could turn it off and back on and it would reset the...
Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. It still can be repaired.
Using your original remote go-to the settings menu then goto the convergence section. Try to adjust the red and then the blue convergence. You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight. If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem. Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix Reply
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. If you have never done this before we would advise calling a technician or if you want to do it yourself get a complete kit with instructions and support from TvRepairKits.com Their kits include a step by step instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.Thanks! hope you rate my response
Feb 02, 2011 | Philips Magnavox 51MP392H Rear Projection...
Having trouble with blue color lining up as it appears as double vision. Magic focus does not fix the problem and nothing we do manually seems to fix it. What can we do to fix this?
Your TV most likely has one of two possible problems.
  • Screen looks 3D
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Dec 04, 2010 | Televison & Video
Screen Distorted
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
May 18, 2009 | Apex Digital GB5108 51" Rear Projection...
Need schematic for Convergence PWB of Hitachi
  • Screen looks 3D
Mar 09, 2009 | Hitachi Televison & Video
Trouble with rca rear projection tv
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
69189a5.pngCONVERGENCE SOLUTION
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Feb 16, 2009 | RCA P61950 61" Rear Projection Television
The color in my TV seems to be going out.
  • Screen looks 3D
Feb 09, 2009 | Philips Magnavox 55P9271 55" Rear...
Sony kp-65ws500 picture trouble
  • Screen looks 3D
Jul 22, 2008 | Sony KP-46WT500 46" Rear Projection...
HELP! Should I buy this model for $200
It sounds like it maybe the convergence ICs or it could just need adjustment from moving.If it does need new ICs they are STK392-110 and you can get replacement iCs and free instalation instructions at the following link.
http://servicemanuals.vstore.ca/
May 30, 2008 | Panasonic PT-53TW53 53" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
128 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
