Question about Magellan RoadMate 700 GPS Receiver
Will not start up
My Roadmate 700 is a couple years old so it is no longer under warranty. It would only start up every once in a while for a little, now it won't turn on at all. Sometimes there are a couple lines that appear on the display. I suspect that it might be the hard drive. If it is, is there anyway that I can buy a new hard drive for it? I can install it myself, but I was also wondering if there was a place that repairs these types of things.
  • jimdee Dec 25, 2007
    Thank Dan: I did just as you suggested and sure enough, I found the third IC chip had all three leads broken on one side. My question now is, can this be repaired, can I purchase the board somewhere, or will Magellan repair it for me, or can I get it repaired somewhere else? Any ideas? Thanks again for the help,
    Jim
  • Anonymous Jan 03, 2008
    Throw it away and buy you a Tomtom. No offense, but I try many things and just wasted my time. I was frustrated out of my wits. Magellan products are not built to last but 6 months.
    Novelist:
    Scholar:
  • 86 Answers
Attempt this at your own risk as this is merely suggestion. Do not blame me if your already broken GPS is.... brokener? Since it is no longer under warranty, here's something that you could do. Ever soldered before? If not, find someone who has. If the problem is the hard drive, which is somewhat common then your out of luck. If the problem isn't the hard drive though then try this. (be grounded before you open the case. - take 4 screws out. - carefully, slightly open wide end (left side (facing you)). - push bottom half towards narrow end (there are 2 hooks on opposing end) - CAUTION: there will be an RF cable attached to the main board next to the antenna, remove it. - fold the case over and you'll see the card in the rear housing. - Normally the culprit, look to where the cable leads on this card. - the connector (on the ckt card) could be loose, if so solder it back on. - Remove the circuit card and look on the back. - There should be 3 small IC chips next to each other on the bottom side, if not and the 3rd chip isn't to be found... your out of luck yet again. Good luck and if you get confused during the process, let me know and I'll try to clarify. and put the 4 rubber rings back on.
Posted on Aug 19, 2006
  • Daniel daniel
    Daniel daniel Aug 31, 2006
    When booting up your MRM 700 the first screen you see appear: blue background with Magellan symbol is pulled from your Main Board's NAND Flash memory. If your system doesn't progess past this point then either your HD is bad/corrupt or you could just have some loose cables etc.
    The 3 "secret" menus (that I have used) are accessible through pressing :
    Zoom in key plus repeat button
    Zoom out key plus repeat button
    Zoom in and out at the same time as stated previously
    I mainly just use the zoom out and repeat button to clear the user data. The other functions within other menus I would use with caution, unless you are certain of the functions being performed.
    -Daniel
I too have been having problems with my roadmate 700, and as I was tinkering, I found that I could access the factory test settings by pressing the Plus (+) and Minus (-) at the same time, as I powered up the device. THere is a hard drive test in that menu.
Posted on Aug 12, 2006
I have a Magellan RoadMate 1412 that does not work. I have had it for a couple years. I don't know if the battery is dead. Where can I get it repaired?
you can either send it to Magellan for repair or take it to a decent localTV repair shop who will be able to have a look at it for you
Jul 25, 2010 | Magellan RoadMate 700 GPS Receiver
Roadmate 700 will not power up
Direct to the nearest Magellan Agent. If you have fully charged the unit and you know the batteries are OK!
If its under warranty take the warranty card with you
Please rate our help to keep the FREE service online++++Thanks for using FIXYA
Sep 13, 2009 | Magellan RoadMate 700 GPS Receiver
My Magellan Roadmate 700 is locked.
it can be bcoz the satellite is not working a the moment. or the computer navigation is broken.
so check both things
Jul 22, 2009 | Magellan RoadMate 700 GPS Receiver
Roadmate 700/760 freezing/locking up
i use to own a 700, i advise you to get the new magellan mastreo 4000 or higher,i did my research and the magellan700 roadmate is no longer being serviced.that is what the magellan website has had showed and someone on here also has said it and they start to have alot of problems.i own now a mastreo 4000 so far so good no problems.
Feb 29, 2008 | Magellan RoadMate 700 GPS Receiver
Magellan roadmate 700
The battery looks like a Lithium battery and it should be 3 volts or close.
I to loaded new maps and am not autherised to use them. What a joke! Looks like a case of to much security to protect Magellian's already to high of a profit!
Feb 02, 2008 | Magellan RoadMate 700 GPS Receiver
Keeps seeking but no GPS positioning
get a new unit like any magellan mastreo series or roadmate 800 ,i had a 700 they start having alot of problems after i did my research on here.
Sep 06, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan Roadmate 800 - External Power Connection
The only thing I can think to add is a general question to Magellan asking why they let a four-year-old child design the power connector as "lightly" soldered to the main circuit board. Very dumb...
Sep 04, 2007 | Magellan RoadMate 800 GPS Receiver
Magellan Roadmate 700 can't power up 2nd time in car
Are you willing to part with it, I may be able to use it for parts denisdsouza@hotmail.com
Jun 19, 2007 | Magellan RoadMate 700 GPS Receiver
Yes, get a new car connector. -Daniel
Apr 23, 2007 | Magellan RoadMate 700 GPS Receiver
Temperature below safe level
I've fixed that error by swapping out the PCB board (or the keypad board). Which you can't very easily do that.. unless of course you have a boneyard of these lying around. Additionally, it could be the Hard Drive, this error hasn't been narrowed down to any one specific cause to my knowledge. I'll take it off your hands if your going to buy another one though. Respectfully, -Dan
Oct 24, 2006 | Magellan RoadMate 700 GPS Receiver
Magellan RoadMate 700 GPS Receiver Logo
116 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
