Question about Bowflex Revolution Home Gym
Pulley system "off track" inside main frame of 2005 boflex revolution
The main cable is off the track if the large pulley. We don't know how to get inside to get it back on the track. Both right and left sides are off track. We have both the user and assembly manuals and they are of no help. Can we take off the tension knobs? My husband owns an auto mechanic shop so he has lots of tools and expertise. Can you please help? The machine is used, but nothing appears to be broken or missing.
Thanks so much.
Susie
  • 3 more comments
  • Jay434 Nov 02, 2008
    Reassembled used bowflex revolution same problem. The handle just falls to the floor and the pulley chord (not yellow ribbon) is off track.
  • ahauze Nov 29, 2008
    I have the same issue too. I think I caused it by pully out the tensioner and turning the large pully the wrong way. The cable is all off the pully now and it is not obvious how it goes back on.
    HELLLLP!!!!
    Adam
  • Anonymous Feb 17, 2009
    ahauze, do you have to take off tension plates and remove tension bar before taking the sides off? Thanks for your help.
  • castcore Feb 21, 2009
    Hi, my yellow cable is also loose, anything I need to do different.
  • 8r14n May 10, 2009
    Just a quick add: I had the same problem on one side of a Bowflex Revolution XP. When I was able to solve it that side made a rubbing noise like the cable was rubbing on something. I discovered inside where the cable enters the main unit (plastic grey thing) there is a smooth curved guide right after the pulley. It guides the cable into and onto the main wheel.
    I took off the stationary 5# weight so there was no tension on the cable and slide the cable behind the smooth curved guide. Put everything back together and no more noise.
I had same problem. I fixed it by taking plastic sides off using a long phillips head screwdriver. Jay, you don't have to take the sides off to fix your problem. The sides come off only to untangle and rewind cables on pulleys. Pull the cables all the way out. Have a helper pull out and keep holding out the tension knob This is shown at the bottom of page nine in the manual. With someone holding the tension knob out turn the large pully located beneith the tension knob CLOCKWISE! I screwed mine up by turning it counter-clockwise. This winds the handle to the top and if you start with all the cable pulled off the pully, the cable should then wind itself nicely back onto the pully. Once the handle is all the way up, with the round ball on the cable jammed up against the pully, then and only then let go of the tension knob and let it fall back into place. If the handle falls down a few inches repeat this proceedure but push lower pully a bit harder and try to turn tension knob, while it is pulled out, in the opposite direction and it will then click into place one notch tighter and should hold the black ball on the cable firmly against the pulley. Let me know if this was helpful.
Adam
Posted on Dec 01, 2008
  • Michael Dockery
    Michael Dockery Jul 02, 2014
  • Michael Dockery
    I've had the same problem before and it seems to come back to haunt me on the same side, the problem being in the tension on one side but if you try to adjust then all of sudden chaos follows. I've tried watching the official instructions video by Bowflex but that did not work(the instructions being very similar to yours to the point of practically being the same). Anyways I'm looking inside my wonderful machine and I notice that the rope is actually off of the wheel and flipped over on top of the wheel(please ask for more info if this is confusing) and well frankly I don't know how to put it back on track. Pulling the rope down only makes it worse because the rope is actually off of the wheel. It makes it pretty difficult to put back on because of all of the little plastic rope guards that surround the wheel on the inside. Any suggestions how I can manually put the rope on track, should disassemble the whole side casing, do you know of any internal diagrams that feature the wheel? The last one might be obvious since it should be in the book, but all info helps. thank you!
I am not sure my problem is the same as the previous one, but here we go.
Product: 2009 Bowflex Revolution
Situation: I tried to create more tension on the rope as advised by the Bowflex manual. I pulled the knob out turned counter clockwise and all hell broke lose.
Problem: There was no tension in the cable and the rope would just dangle with now resistance for the right side of the Bowflex.
Solution: (You may need two people!)
1) Unscrew the top portion of the Bowflex. ( 4 Screws) 2) Make sure the handles are in the 9 position 3) Make sure the yellow ribbon is not tangled due to the extra slack 4) You need to make sure the grey rope ball is all the way against the pulley. You can achieve this by turning the TENSION KNOB clockwise (but do not pull it out) until the grey ball is tightly against the pulley. 5) Have your partner place one finger under the yellow cable and pull to create tension again the ribbon so to not tangle due to the extra slack 6) Pull the tension knob OUT and with your other hand turn the disc that is directly behind it with groves clockwise until your partner tells you there is no longer any slack on the yellow ribbon 7) Screw back on the top portion of the Bowflex
Posted on Jul 26, 2009
  • Demarche Jan 09, 2011
    You may need to repeat this more than once if you've pulled the cables all the way down. Also, watch for the cable being jammed through the bottom of the wheel well, where the pulley exits the bottom of the housing.
  • morpheus001 Apr 10, 2011
    I found this to be helpful. I have same problem. In doing the solution the knob won't go any further clockwise. The cable is wound all the way and the ball is at the upper pulley. I reach the point where i can rotate the lower pulley clockwise. I can rotate the pulley up to a certain point but no more. Not being able to wind up the webbing enough to create the tension is affecting the fix in my case. I may to order a replacement part.
Just a quick add: I had the same problem on one side. When I was able to solve it that side made a rubbing noise like the cable was rubbing on something. I discovered inside where the cable enters the main unit (plastic grey thing) there is a smooth curved guide right after the pulley. It guides the cable into and onto the main wheel.
Posted on May 10, 2009
The passenger window in my 2010 Mitsubishi Lancer came off its track. How do I place it back on the track?
This is most likely not the track, The window system uses pulleys and cables and the pulleys are plastic and the cable comes off. They are tough to work on. You have to remove the interior door panel. That means getting a door panel tool. Take the screws out that you can see on the arm rests and the trim. Use the door panel tool to locate the plastic panel retainers. They are spaced out on the edges of the door panel. Use the puller to remove them. When the interior panel if removed you can see a plastic sheet that covers the inside mechanics. Remove the sheet and you can see the window parts through the holes in the door. You can then remove the window cranking system. You probably are going to end up replacing the part.
Oct 24, 2014 | 2010 Mitsubishi Lancer
Tip
Mechanical System Troubleshooting for Stairmaster 4000PT Stepper
  1. Remove the side covers. WARNING: TO REDUCE THE RISK OF INJURY, DO NOT OPERATE THE MACHINE WHILE THE COVERS ARE REMOVED. DO NOT DEPRESS OR RAISE THE PEDALS WHILE ANYONE'S HANDS ARE INSIDE THE MACHINE.
  2. Remove the Poly-V belt and inspect the belt for cracks, fraying or any other unusual or excessive wear.
  3. Spin the alternator pulley to check the bearings. Replace the alternator if any clicking or grinding noises are heard.
  4. Inspect the alternator pulley for wear.
  5. Tighten the transmission pulley set screw to the flat side of the transmission output shaft.
  6. Remove the drive chain and inspect the chain for frozen links. Replace a chain with frozen links.
  7. Tighten the transmission drive sprocket set screw to the keyway in the transmission input shaft.
  8. Spin the transmission drive sprocket input 1 complete revolution. The transmission pulley output should turn 19 revolutions. Replace the transmission if any clicking or grinding noises are heard during rotation or the drive ratio is not 19 to 1.
  9. Remove the step chains and return springs from the main frame of the machine.
  10. Inspect the step chains for frozen links and the springs for corrosion. Replace a chain with frozen links and replace a corroded spring.
  11. Make sure that the step chain connection points pivot freely and have no vertical play.
  12. Remove the pedals, pedal arms, and leveling arms and lubricate according to the maintenance section of the manual.
  13. Verify that the clutch sprockets of the hub assembly spin freely in the forward direction and lock in the reverse direction.
  14. Inspect the hub assembly for wear. The drive shaft sprocket should not move up and down or side to side.
  15. Clean and lubricate the drive and step chains with 30W motor oil.
  16. Reinstall all parts, ensuring the proper tension of the Poly-V belt and the drive chain.
Stairmaster Mechanical System Troubleshooting for 4000PT
on Feb 25, 2015 | Stairmaster 4000PT Stepper
Replace washer spin basket kenmore elite 110
sounds like a bad bearing on the rear of the tub. If you remove the rear access panel you will see a large pulley and belt. That attaches to the inner drum (basket) and spins it. It floats on a bearing just behind the pulley. If the bearing is bad then you will be able to move it up and down about .25 to.50 of an inch.
Jun 25, 2014 | Kenmore Elite 45986 Front Load Washer
Advance tracking system turning off and abs light is on
You need to get the brakes checked. The brakes ABS warning is a fairly accurate system and it probably is made to shut off the tracking system because without brakes, the tracking system can not work properly.
The tracking system and ABS work by counting the revolutions to the wheels and balance left and right sides by using the brakes. If brake debris or bad brake pads interfere with the counting, the warning will engage.
You may be able to save the rotors with prompt action, but know that the brakes are not within specifications and are headed for a metal to metal conflict.
Mar 30, 2012 | 2005 Ford Explorer
My name is Bill.I have a 26" steerable track drive snow thrower made by MTD model #315e740f000. I am looking for a diagram that shows what the cluch cable attaches to that moves the machine. This...
I don't have a diagram, but we do have a similar track drive unit sold by Sears. There is a plastic cover over the output end of the engine that covers two drive belts and their associated pulleys. The clutch cables operate a movable pulley near each belt that causes power to proceed to the auger/impeller or the track drive assembly. The belts are a common failure point. There is a removable panel underneath the machine that encloses the transmission which is a large rubber-edged wheel that rides a very large metal wheel at right angles to it. Hope this helps!
Dec 08, 2010 | Garden
Nordic track commercial 1300 manual
It sounds like reed switch inside the side panel located on the frame by the large pulley either needs to be adjusted or replaced. Try adjusting the switch first the clearance between the switch and large pulley magnet will be 1/8" if you have the same result then replace the switch.
Jun 12, 2010 | Nordic Track Exercise & Fitness
I'm trying to do some work on my DR Trimmer and Mower. I need to know the configuration for putting a belt back on and how to adjust the cable that activates the mower head
The DR Trimmer/Mower V-belt (1/2” x 45” 4L450) loops around the Trimmer Head pulley and the engine pulley. The V seats into the pulley grooves and the flat side faces out.
On older models there is a stationary idler pulley near the front of the trimmer which remains inside the belt loop. Another smaller pivoting idler pulley sits further back near the engine pulley and rides on the outside (flat side) of the belt loop. This is attached to the clutch cable which can be adjusted to apply more or less tension to the belt.
To adjust the clutch cable on older models, follow it down to where it mounts to the Trimmer frame with lock nuts. Loosen those lock nuts and move the cable in small increments forward for more belt slack or backwards for more belt tension, tightening up the lock nuts when you find the proper position.
If you have a newer model, the trimmer won’t have the stationary idler pulley, it will have a twin idler pulley that pivots on a bracket and is attached to the clutch cable. The belt loops to the outside of the first idler pulley and to the inside of the 2nd idler pulley (pulley is inside belt loop). Be sure the belt retainer brackets don’t rub against the belt when it is engaged.
The Clutch Cable adjustment is the same procedure except that the adjuster is mounted to a bracket on the handlebars with lock nuts.
You may download the DR Trimmer manuals for more detailed information at the following web link:
http://www.drpower.com/Trimmer-Mowers_Manuals.aspx
Jun 12, 2010 | Garden
Haier HLP21E belt broke. My machine was overloaded. How do I replace it?
put new belt on big pulley first then roll in over on smaller one
Mar 29, 2010 | Haier HLP21E Top Load Washer
How do you connect the power windows?
They are supposed to be connected to the motor. Does the motor run when that doors individual switch is pressed? What do the ends of wire look like, connected to something or does it have clips at ends? If motor still runs then these wires are for manipulating the rack& pulley system for operation of the window glass.........sodeep
Aug 03, 2009 | 1994 Toyota Camry
Power window cable is off track
you can't. the window regulator needs to be replaced
May 17, 2009 | 2004 Lincoln LS
Bowflex Revolution Home Gym Logo
6,833 people viewed this question
Top Bowflex Sport & Outdoor - Others Experts
Jerry Greenberg
Jerry Greenberg
Paul Carew
ray gallant
Are you a Bowflex Sport and Outdoor - Other Expert? Answer questions, earn points and help others
