Question about Whirlpool Duet GHW9150P Front Load Washer
Burning smell, loud when spinning, bleach spots
Front load has been progressively making loud noises when washing and spinning especially. Noticed this AM it was very loud so went in to check on it and it smells like burning rubber. Also I have noticed bleach spots on my clothing..Bleach holder not draining properly???
Thanks for you help..
  • Anonymous Oct 23, 2008
    I have had nothing but trouble with our Whirlpool Duet front loader, good thing we purchased the extended warranty because we have had numerous repairs even before the unit was a year old. The latest is a racket when in the spin cycle which has gotten so loud you cannot even hear yourself think! Whirlpool has the Good Housekeeping Seal of Approval so I recommend contacting them and filing a complaint as I have. Send a copy to Whirlpool as well. They need to now these units are lemons!
  • cathy213 Feb 04, 2009
    I too have has numerous problems with our frontloader duet. The latest is the horrific noise during the spin cycle. The "authorized repair company" that whirlpool sent out said this noise is normal. It is so loud you can't have a conversation in the next room. I have also noticed oily spots on some of my clothes that came from the washer. Of course it is out of warranty.
    Scholar:
  • 112 Answers
Usually this is due to the tripod mount on the back of the drum cracking. Simply replacing the bearings does not help in most instances. The only true remedy is to replace the drum, along with the front and rear tubs. These are usually covered under warranty but the labor (6-8 hours) is a customer pay unless the unit is very new. Also, it is recommended that you replace the drain pump as well when performing this repair. It is a good idea to get this looked at as soon as possible as more damage can incur. I have seen them vibrate so violently that they break the control boards above the drum. If you give whirlpool an earfull, they may or may not offer some help on the bill.
Posted on Oct 23, 2008
    Problem Solver:
  • 5 Answers
The bearings that hold the drum on the shaft are faulty, the bearing seal eventually wears out, water gets in, the bearings rust and become loose due to the forces exerted when the machine is spinning. The burning smell is due to the bearings being loose so the drum is off centre (very noisy spin) they rub against the door seal which is rubber, when spinning this causes alot of friction and heat. The spots on the clothes are a common thing, the bearing fluid leaks into the drum causing oily stains, this might look like bleach but it isn't.
A bearing repair job is quite expensive (£80-150) if you can order the spare part bearings you will get the job done cheaper by just paying labour charges.
My Kenmore Elite HE3 Mod 11044832 202 started making LOUD knocking noises during final spin cycle, then started to smell like something burning. Whit placis shreds in the washer.
the plastic is the drum has dropped so its eating a way the plastic on the back of the drum so no not worth fixing the mould is an easy fix just soke a cloth with neat bleach and leave over night make sure you do a rines after woulds as you don't want bleach on your cloths ok
Oct 21, 2012 | Kenmore 44832 Front Load Washer
Amana ALW880QAW doesn't spin and agitation is slow
winephan,
I could be the pump slowly ceazing causing the belt to slip which would give a burning smell.
Motors in those units, are well build...have a service guy in but DON"t say anything about the motor.. because they will say it because you mentioned it
I sounds like you pump
Jul 22, 2010 | Amana ALW880WH Top Load Washer
The washer makes a loud noise when it spins and there is a burning smell.
sounds like bearing may be going out shut down call repairman if the smell,smells like rubber its the belt
Nov 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Loud noise, then not so loud, but now electrical burning smell and little draining
the smell is your clutch and the lack of draining is a clogged washer drain protector. see these at www.repairclinic.com drain protector is part 541811 and clutch is 2670. go there enter model number and scroll down to the red 100 click it and look for these part numbers.
Mar 02, 2009 | Whirlpool LSR5132PQ Top Load Washer
Very loud final spin cycle with burning rubber smell
Hi Mcbride2
It could be one of 2 things. 1 the belt. or 2 the main seal and bearing. i recomnd to get a tech just to make suer.
brent
Sep 06, 2008 | Maytag Neptune MAH5500B Front Load Washer
The basket drive and the drive block will need replacing. The nut that holds the basket to the drive block may have come loose causing the drive block to 'jump' over and damage the tabs on the basket drive that causes the thumping as the spin cycle ends. To repair, you will need to purchase a basket drive and drive block. The agitator, balance ring, basket and transmission, will have to be removed in order to replace the basket drive. If less than 3ys old, consider contacting whirlpool for possible warranty concession.
May 26, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
LG WD-1234FH
You will need to have it checked by a qualified LG technician to see what is the deal with the burning odor.  And the noise is probably the washer not balanced correctly.
Oct 28, 2007 | LG WD-1080FD Front Load Washer
Loud noise on Spin Cycle
CENTER SUPPORT BEARING IS BAD. VERY COSTLY IF NOT UNDER WARRANTY USE FOR BOAT ANCHOR. GOD KNOWS I HATE TELLING PEOPLE THAT. SORRY, FXIT
Oct 11, 2007 | Admiral AW22 Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
621 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
