Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
Kenmore Fridge: Freezerfan seems to run almost constantly
My Kenmore Fridge is about 4 years old. Freezer on top. First problem was I noticed water puddling on the top shelves of fridge. Saw that it was coming from openings into freezer area. There was no water coming from drain tube so I removed the back panel of freezer. Tray that leads to drain was filled with ice. Also some ice on upper left area of coils. I removed everything from fridge and freezer and let all ice melt. Made sure drain tube was clear and put it all back together. Now it seems that the fan in the freezer is running "almost" constantly. Fridge and freezer seem to be the correct temperature?? What is causing the fan to run "almost" constantly. It does seem to stop for a little while occasionally. Is it the Defrost Timer or Defrost thermostat?? I am sure I will be seign the water leaking from the freezer again soon... Thanks, Bob
3 Suggested Answers
SOURCE: kenmore top freezer fridge does not cool but freezer works
Turned refrigerator off for 8 hours, let the frost melt and the fan in the freezer worked again. The compressor now only has a soft clunk when it goes off.
Posted on Feb 01, 2009
  • 93 Answers
SOURCE: 1 yr old Kenmore fridge (18 cu ft top freezer mdl
Either the defrost timer is going out or it could be your defrost bimetal thermostat that is located behind the back wall in your freezer. Both parts are cheap and easy to install. I would replace both.
Posted on Sep 12, 2009
Issue with Kenmore Refrigerator/Freezer
ok,1st check on fridge side toward upper back of the top and feel for air coming thru, and there is another one down possibly behind crisper .I had this same deal. Had to do total defrost,, put food in cooler,, theres two blower fans in these types of fridges,,one in the bottom back,, and one in the back of the frezzer,, I used an old hair dryer and let it blow warm to top interior of frezzer,, careful not to let any cords hang/drop in any water!!,ok once done dry out as much water as possible, turn fridge on set both controls to 4,when fridge kicks on do the feel test,, you may need to close the frezzer door, air should be felt near top inside of fridge,if so than shut fridge side and feel inside frezzer near bottom and air should be felt,, side-by-side need to circulate air from frezzer to fridge, then back to frezzer
Jan 23, 2013 | Refrigerators
We have a Kenmore top freezer (no ice maker) refridgerator less than a year old. The frige part is warm while the freezer is frozen. Turns out the vents on the top of the fridge were clogged w ice. We...
Very likely the vents are freezing due to the defrost drain is blocked so instead of the water from the defrost draining into the pan on the bottom as its supposed to its pooling in the freezer and freezing over the air vents.
This tip i wrote will help ya to clear the drain. http://www.fixya.com/support/r9945686-check_when_refrig_cools_ok_but_leaks
GENE
Sep 14, 2011 | Kenmore Refrigerators
Water pooling at the bottom of kenmore fridge
I had a Kenmore fridge - about 20 years old when I replaced it this year. It used to do the exact same thing especially in warm/hot weather. What it is is the water from the freezer defrosting. There should be something on the back near the top, inside the fridge sticking out - a tiny little tray sticking out and it may also be part of supporting one of the shelves, I can't remember. Anyways, water from the defrost pools in there and is supposed to evaporate, but it gets clogged with gunk and the water spills out and runs down the back of the fridge down to the bottom. Get a pipe cleaner or something and poke it into this hole and clean out the pipe to the hole isn't blocked. This is all inside the fridge, not outside, on the back panel outside. That's the best I can do to describe the solution - it's an easy fix you can do yourself. Good luck!
Jan 01, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Kenmore top freezer fridge does not cool but freezer works
Jan 30, 2009 | Kenmore 64823 Top Freezer Refrigerator
Ice maker stopped working, plus fridge not cold, but freezer o.k.
I would check that fan motor in the freezer section is running. it distributes cold air from freezer into refrig section also if this motor is running the top portion of freezer will not get cold enough to allow ice production. the motor is easy to repl and is mod# specific you should be able to buy one online.
Jan 21, 2009 | Kenmore 64802 Top Freezer Refrigerator
Fridge not cooling- top freezer frosting over
"Fan in freezer does not seem to be running"
This wiil cause it to frost up in the freezer and this fan is the only way to get cold air into the Fridge area.
Dec 22, 2008 | Frigidaire FRT18FS6C Top Freezer...
Leaking inside of fridge
i guess u will benifit from this link
plz rate this post
click here
Sep 02, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
50 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
