Question about Palm Tungsten E Handheld
Touchscreen will not calibrate
Even after a "hard reset" my Tungsten E hangs up on the stylus calibration step, repeatedly prompting me to "tap the center of the target".
  • ravencom Dec 04, 2008
    When I start the Tundsten I get the calibration screen and try, but it doesn't react to the stylus. Is the screen shot?
I followed the adivce of another post and removed the screws on the back of the machine. I disconnected the battery and left it off for a few minutes. It was then reconnected and the Palm worked perfectly. To be truthful, my 13 year old son did this for me and it worked like a charm. With a phone call to Palm support costing $15 and a repair bill of at least $149.00, I felt like I had nothing to lose. This actually worked!
Posted on May 03, 2009
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 448 Answers
Is this still unsolved
Posted on Jan 09, 2009
Radio stations
There is a radio option to recalibrate your touch screen. Please press the following three hard keys simultaneously RADIO/MEDIA, SEEK UP, NAV (AUDIO on REN). Once you begin to recalibrate the touch screen you must finish. Audio confirmation prompts are provided for each of the three points of calibration, one beep for the first, two for the second and three for the third. The calibration needs to be precise as possible and a PDA stylus would be recommended. The MyGIG radio requires the user to repress each calibration point to confirm the calibration process. A green crosshair indicates proper calibration.You must not start with the "+" but with the "+1", then goto "+2" and last to "+". Repeat this until all crosses are green and exit with pushing the menue or any other key. Done
Jul 20, 2012 | 2008 Dodge Grand Caravan
HOW CAN DO PHONE CALIBRATION?
Over the time, the touchscreen might have to recalibrate for better touch precision. If you press 1 but it activates 2 in the To calibrate Nokia 5800 touchscreen: Click the menu key > Settings > Phone > Touch Input > Touch screen calibration. There you are prompted to tap centre of target with stylus, where the 4 circles (target) at the corner animates one by one to guide user complete the touch screen calibration process.
May 05, 2010 | Nokia 5800 XpressMusic Smartphone
I have been having problems with the alignment on my touch screen. Just reset it and have been tapping the target repeatedly but it continues to move diagonally across the screen ad nauseum. What can I...
Remove the Screen protector from the device screen and then calibrate the screen with the stylus.
If the issue still persists, perform the Soft Reset on the device.
1. Use an unfolded paper clip, or the reset tool at the tip of your stylus.
2. Gently press and release the RESET button inside the hole on the back panel of your device .
3. After a soft reset, a logo screen appears, followed shortly by a Preferences screen asking you to set time and date.
4. All data on your device should be retained.
If the issue still persists, perform the Hard Reset on the device.
1. Press and hold the Power (on/off) button on the front panel of your device.
2. While holding Power, use an unfolded paper clip, or the reset tool at the tip of your stylus. Gently press and release the RESET button inside the hole on the back panel of your device.
3. If you see a progress bar, keep holding the Power button.
4. Next, the Palm Powered screen will appear. Release the Power button when you see it.
5. You'll see a screen that asks: Erase all data? YES = "up" button NO = any other button. Press UP on your 5-way navigator to complete the hard reset.
Your device will then take you through a series of screens to calibrate the digitizer and verify the time and date.
Note: A hard reset does not delete the current date and time. It does restore other settings to the factory default.
Sep 22, 2009 | Palm Tungsten E2 Handheld
BOTTOM OF SCREEN NOT WORKING,
This happens a lot with Palm digitizers. The only permanent solution is replace the plastic digitizer with an upgraded glass type. Before considering that, see if removing screen protector helps. (yeah, didn't think so. Worth a try!) Try Powerdigi, a better calibration program. Get it from http://www.palmpowerups.com
It worked for me.
Jul 03, 2009 | Palm TX Handheld
Tungsten e2 is always looping on the stylus calibration screen
actually ur Digitizer is faulty u can replace it urself cost around 25 $ or so do u want to proceed let me know , unless u change the touch panel digitizer u will be stuck at align screen thing
let me know if i can help more
RATE ME WELL !
Jun 02, 2009 | Palm Tungsten E2 (Multilingual) Handheld
Cant use stylus.
Unscrew the 4 torx screws on the back and remove the cover carefully.
Unplug the battery for 30 seconds. plug it back in and re- assemble the unit. Once it comes back on it will give you the chance to re calibrate the digitizer ( or you can now select it from the prefs menu)
If the touchscreen fails to repsond you will need a new digitizer.
You can purchase it from :
http://www.gethightech.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=PA1634&Category_Code=DIG\
there is also a video on how to take it apart here
http://www.gethightech.com/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=RD
Feb 17, 2009 | Palm Tungsten E2 Handheld
Palm Tungsten E/E2 digitizer - fragile?
Palm one is in trouble because of problems like this. They don't work on it but you can buy parts to try it yourself. I never had the problem myself but similar conditions. I do windows based units now.
Dec 30, 2008 | Palm Tungsten E2 Handheld
Screen problem
Sometimes 3rd party apps that don't work so well with the palms can freeze them up.
http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE/,/
?St=2,E=0000000000825403011,K=4996,Sxi=18,Case=Obj(26419)
You could do a hard reset and when you initially sync the palm, when it asks you for a profile choose a new one and see if this method removes your problem.
Diagnosing problems by 3rd parties link- http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE?
New,Kb=PalmSupportKB,ts=Palm_External2001,Case=obj(27908)
More info-
Does the calibrator keep looping or not seem to work?
If you can access the calibrator, but it loops through the target sequence (repeatedly asking you to tap the targets), there may be a physical problem that's causing your touchscreen to be confused:
  • Do you use an adhesive screen protector? A screen protector which is trapped under the screen edge may interfere with touchscreen calibration. Occasionally, just having the screen protector on the screen can cause the issue. Try removing the screen protector.
  • You may have debris trapped under the edge of the screen. Use the corner of a piece of thin, stiff paper (copier paper works well) to very gently slide all around the edge of the screen. Don't let the corner of the paper travel more than an eighth of an inch under the screen edge frame. By doing this, you may be able to dislodge small particles of debris trapped under the frame.
  • A heavy impact or scrape to the touchscreen can cause permanent damage. If your touchscreen is damaged, you may need a repair
Jan 08, 2008 | HP iPAQ RX3715 Pocket PC
Touchscreen keyboard
Sounds like a problem with the digitizer. Mine started out like this and got worse. I have owned my Palm for about 1-1/2 years and at least twice I had to do the following as my touch screen eventually quit working and I couldn't get the digitizer to fix it either. Below is what I have found that works and so far is the only solution. I think this is a bug in the system, but PALM has not yet posted any info or a patch to correct it. Unfortunately, this will erase all your data so be sure to back it up first.
Sounds like the digitizer is so far off that the input won't align correctly. This would, most likely, be confirmed if you get any response when you tap the touchscreen (moving cursor, beeping, etc). You'll need to try a soft reset using the little reset tool in the end of your stylus, or a paperclip if you don't have it. Press and hold the reset button inside the unit (located in the back panel) for a few seconds until it chimes and you see the Palm logo. Then try the Digitizer again to calibrate.
Now, if that doesn't work, you may need to factory reset the device. THAT MEANS YOU LOSE ALL YOUR DATA, so do whatever you can to get it backed up. You simply hold the reset, then press and hold the power button for several seconds. Instead of the standard Palm logo you'll see a prompt asking you to press up on the touchpad, on the front of the unit, to reset it to factory default. It will then run you through the initial setup routine to set the date, time and finally calibrate the Digitizer.
Dec 10, 2007 | Palm Tungsten E2 (Multilingual) Handheld
Touchscreen no longer works
Well watch this video and after you follow the directions get the screen and find the glass like cover and remove it from the screen bend it in a very lightly way, then put it back on and put the PDA back together and BAM.
Nov 07, 2007 | Palm Tungsten E2 (Multilingual) Handheld
Palm Tungsten E Handheld Logo
225 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
