Question about GE Washing Machines
Water overflowing & not spinning out. - GE Washing Machines
  • 750 Answers
Hello o511 ,
Welcome to Fixya,
My name Is Huuum.
And I have your solution to why this is happening to your washer!
You said, water overflowing & not spinning out
Here are three reasons why this is happening
1. Faulty Water Inlet Valve
The water inlet valve isthe device that meters water from the supply lines into your wash tub. On domestic washers, there are two lines, one hot the other cold. Thesevalves are susceptible to mineral build-up and sediment deposits. There are two common failure modes:
Failure Mode One: Valve will not open.
Ifyou can verify that the solenoid on the valve body is receiving therequisite voltage and the valve will not open, then it is faulty. Since the solenoids operate independently, it is likely that one sideof the valve will work and the other will not. This can produce strandresults such as a very hot wash when warm is selected (due to no coldwater). Or the reverse in that the wash water is cold when warm isselected. If mineral or hard water deposits are a problem, you maywitness a substantial increase in the time required for the tub tofill. This is caused be a decrease in the flow ware of the valve.
Failure Mode Two: Valve opens but will not close.
Thisis verified by a valve that allows water to flow into the tub eventhough no power is being supplied to the solenoid. This one is usuallyquickly diagnosed when the machine begins to overflow and the powerplug for the washer is disconnected from the wall. However, this willnot stop the water from flowing into the machine. The water must beshut off at the wall. As with the previous failure mode, the variant ofthis failure mode is that it may take the valve a while to completelybridge the flow of water after the power has been removed from thesolenoid.
How to Diagnose?
There are acouple of ways to diagnose a faulty valve. However, there is a simpletest that one can perform that will usually let you know if the waterinlet valve is faulty.
Scenario:
When set to cold washand rinse, the unit will not fill. When set to warm wash and coldrinse the washer will fill with hot water only and will fail to rinse. This is a common scenario where the cold water side of the valve doesnot appear to be contributing to the fill, but the hot water sidedoes. This symptom could be easily reversed where cold water is beingsupplied, but never hot water.
So, how can the problem bedetermined? It is as simple as switching the wire harness plugs on thehot and cold side. In the example above where the cold water is neverbeing supplied, the symptoms would be the opposite when the wiringharnesses were switched. So the machine would produce only produce cold when warm or hot is selected. No water should be present when youselect cold. This verifies that the timer, wiring and switches are allin working order. Assuming this tests checks out, you simply need toreplace the water inlet valve.
2. Faulty water level (pressure) switch
The water level(pressure) switch detects the hight of the water in the wash tub by thepressure it creates. Much like your ears feel greater pressure whenyou dive into the deep end of the swimming pool, this switch senses theincrease in pressure from water added to the tub. The size of the loadyou select determines how much prssure is required before the switchtells the water inlet valve to close.
If voltage is still being supplied to the water inlet valves and the tub is full, then the water level switch is likely faulty.
3.
Faulty Water Level Switch Supply Tube
The tube that connectsthe water level (pressure) switch to the outer wash tub must havepressure integrity for the washer to be able to determine the correctwater level. There are four possible problems that can prevent thistube from performing its duties.
  1. The tube can become clogged with lint or debris. This canprevent water from entering the tube and therefore not apply pressureto the switch.
  2. The tube can become cracked. Much like astraw in a soft drink, if the supply tube has a crack in it, it can notsend pressure to the switch.
  3. The tube has become kinked. If the tube becomes kinked, it can not send pressure to the switch.
  4. Thetube has become disconnected from either the tub or the switch. Ifeither of these occurs it can not send pressure to the switch.
To prevent leaks, it is wise to replace a water level switch supplytube that has become brittle. Failure of this tube during operation ofthe washer could result in a sustained water leak.
RESULTS IN :
Ifthe water level switch is not resetting once the water is drain, powerwill not be available to operate the motor during spin.
I believe I solved the reason why you ar overflowing and not spinning!
Let me know how it goes!
Thank You ,
Huuum,
Please remember to leave a rating!
Posted on Oct 21, 2008
Washer overflowed after moving Load Capacity Switch from Super to reset and then to Large load?
On this model of washer you have 4 separate components that could cause overflowing. The water valve, pressure switch, pressure switch hose & the air dome. If you have to turn the water off to prevent overflowing, I would recommend replacing the water valve. If you can turn the timer off & the water stops overflowing, I would recommend checking the pressure switch, hose & air dome.
Jan 16, 2011 | GE Washing Machines
The washer doesn't stop filling and will overflow if not stopped. If you move the dial forward it won't agitate but it does pump out the water and spin.
Take control panel off & look for a clear tube. That is a air pressure line, that, once the water reaches a certain level, the pressure in the line shuts water valve off. Should hook into the main control dial. Check that the line is attached, or not kinked! If that isn't it, then you may need to replace water valve. Give this a try, it may solve your problem. Hope it helps.
Nov 25, 2010 | Washing Machines
Continuously adds water, won't cycle & agitate, spins only when manually move dial.Please Help!
If the water is not overflowing onto the floor, then you have a water siphoning problem. raise and loop the drain hose behind the washer so that it is higher than the water level in the machine.
if the water runs over the top of the tub onto the floor and doesn't shut off until you turn the machine off, then you have a pressure switch problem.
if the only way to shut the water off is to turn it off at the faucet then you have a water valve problem.
May 25, 2010 | Whirlpool Washing Machines
I have a miele G841 dishwasher and the saftey pan is always filling up with water and then a intake - drain error code comes up and the dishwasher will not allow water to enter for rinse until I drain...
Hi dear.If you are handy enough,that's what you can check to make a solution for yourself.Goodluck.
Check all hoses, connections and threaded unions for leaks.
Note:
If the leak source has not yet been detected, check the following areas
in the toekick and the drip pan for wear and tear:
�� Connection between the circulation pump and the sump
�� Axial face seal of the circulation pump
�� Connection between the drain pump and the sump
�� Connection between the salt container and the water intake
�� Connection between the water intake and the cabinet side wall
�� Overflow (e.g., excess foam formation)
�� Water level between the overflows (�� seating of the lower door seal?)
�� Connection between the cabinet and the salt container
�� Non-return valve in the sump (�� water running back from the drain hose?)
3. Check overflow float switch B8/3 for continuity and correct operation.
4. Carefully dry all electrical components in the drip pan area.
Cause:
Float switch defective.
Remedy:
Replace overflow float switch B8/3.
I hope that helps.Thanks.
May 18, 2010 | Miele 23 in. Novotronic G841 Built-In...
The water drains too fast and overflows
Here is a tip that will help you with that problem...
Changing or Upgrading your Old Washing Machine
http://www.fixya.com/support/r4696582-changing_or_upgrading_old_washing_machin
heatman101
May 14, 2010 | Kenmore 23822 Top Load Washer
Any washer cannot drain too fast, the problem is in your drainage pipework, there is likely to be a partial blockage or restriction of some kind, it means rodding the pies, or taking it apart to clean it.
Mar 23, 2010 | Kenmore 23822 Top Load Washer
Washer over flows with water and does not go into spin cycle
water level sensor is not working properly
with your solenoids to shut off water
Jun 02, 2009 | Washing Machines
GE WBSR WASHER WATER OVERFLOWS
He probably disconnected the water level sensor when replacing the belt or the timer is dead.
Check for any unconnected sensor or check if the main program button is turning propely..
cheers
Dec 20, 2008 | GE WBSR3140DW Top Load Washer
Won't go into the final spin cycle and overflows
For Dinkysouth:
Apparently your machine is getting power to the water valves when it should be draining and then going into Spin. Also, since it keeps filling to the point where it overflows there must be a constant signal from the electronic board that bypasses the water level pressure switch. If you can, you should go into the Service Program and check the individual items. Most likely, you will end up needing a new board.
Jan 23, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
123 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
