Question about Intel Motherboard
Boot problems! New Gigabyte GA-P31 Socket 775 Mobo, Intel Celeron Dual core CPU, 7600GT graphics and trying to use to old Maxtor 80gb IDE drives. One set to master, the other to slave. Boot begins until just prior to when the XP screen should start, then re-boots itself. This is a continuos routine. Can you help?
  • gcooper1873 Oct 24, 2008
    Thanks for your solution. Took some time but worked a treat.
  • 2,351 Answers
Hi gcooper1873,
If your primary IDE has a copy of windows already on it, than that alone can cause the system to re-boot & go into a loop of re-starting. It is alway recommended to install windows fresh when a user replaces the motherboard with a new motherboard. The only execption to this rule is if your replacement board is an exact match of the motherboard. Plat it safe. If you have another IDE data cable replace your current data cable. See if the system restarts.
If you have data on the primary IDE & do not wish to loose the data from your old windows than you need to create a new partition within the IDE's free space. This should stop the system from restarting. You can leave both IDE drives connected for this. Load your Windows XP CD & boot to it.
If the system does not load the Win CD than manually restart the system & press the F8 key every two seconds as the system boots. You should get this screen:
High-light the CD-ROM with the windows CD in it & press enter.
Read the display from windows XP's screens. You want to create a partition within the free space of your primary IDE. Than you want to install windows onto that new partition. By doing this you will not loose any data from your old windows partition. (You'll be able to delete the old win partition later).
Install windows complete & install all of your motherboard drivers from the Gigabyte CD.
Turn on windows firewall for protection. Click on, Activate Windows & do so by phone. Its free.
Update window. (Suggestion, when updating windows look through the updates & find .Net framework 1.0) & install. Its prefered to install all .Net framework's in order. ( 1.0, 1.1, 1.1 hotfix, 2.0, 2.1 ECT). Windows will want to restart your system inbetween some of these. Do so. You will also notice you may have to click on your user ID to log into windows, this will go away after all .Net frameworks have been installed. Do not remove guest from within user accounts in control panel. Once windows updates are finished you can now copy the old partitions data folders to the new windows folders.
Suggested folder's to copy:
C:\Documents and Settings\ User name\Application Data\Microsoft\Address Book
C:\Documents and Settings\ User name\Desktop
C:\Documents and Settings\ User name\Favorites
C:\Documents and Settings\ User name\Local Settings\Identities
C:\Documents and Settings\ User name\My Documents
Data from any program you may have installed.
Now you need to get rid of the old partition with the old win XP on it.
Use windows disk management program.
Click the start button, click on run & type in " diskmgmt.msc " & press the enter key.
You'll need to change the old win partition to a different drive letter. Example: Your IDE drive had one drive letter assigned to it - C:\. Windows most likely kept the letter C:\ assigned to your old windows.
With disk management you can re-assign all your drive letters. Once your sure you have all your data copied over onto the new installation you can delete the old windows partition.
Which one of these motherboards is your's? Click the link below;
Good luck gcooper1873!
Any question? Post it here....
Posted on Oct 22, 2008
  • Mike Peluso
    Mike Peluso Oct 24, 2008
    Hi gcooper1873,
    I'm glade everything worked out to your liking. As they say, all good things takes time.
    If the suggested method above stopped your system from restarting, please adjust you vote to fix.
    I enjoy helping PC users & ask for a fare vote.
    Have a great day & thanks for using Fixya!
Pentium d cpu clock speed 3.0
Aug 31, 2013 | Intel Gigabyte GA-8I945P-G Dual-Core CPU...
Pentium d 3.0 Hz
is all the right things in the right place cpu the video card dvd hard drive cable right and the right ram as will?
Does the GA-8I945P-G supports the Core2duo Processor?
No since this is a older mobo the manufactre only recomndes you use Pentium D, Pentium 4 HT, or Celeron D. many people have tried this and have had alot of problems and little success.
May 04, 2011 | Intel Gigabyte GA-8I945P-G Dual-Core CPU...
You can buy a sound card and install it on a PCI port
Oct 27, 2010 | Intel Gigabyte GA-8I945P-G Dual-Core CPU...
Bios won't boot, fans work, drives are flashing but it won't boot, no beeps.
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
good luck
Sep 09, 2010 | Intel Gigabyte GA-8S661FXM-775 SiS 661FX...
Nobody has a list of cpu's that will work with this mobo. Biostar P4M800-M7A Ver. 7.0. It was sold as compatible with dual core cpu's, but no-one has a list of which intel 775 dual cores. Did New Egg lie?...
P4TAW Extreme 1.0 925X Socket 775 Pentium 4 3.6GHz I915P-A7 1.0 915P Socket 775 Pentium 4 3.8GHz Celeron D 3.06GHz I915G-M7 1.0 915G Socket 775 Pentium 4 3.8GHz Celeron D 3.06GHz I86PE-A7 1.0 865PE Socket 775 Pentium 4 3.8GHz Celeron D 3.06GHz I865G-M7 1.0 865G Socket 775 Pentium 4 3.6GHz Celeron D 3.06GHz N4SIE-A7 1.0 NF4 SLI Intel Ed. Socket 775 Pentium 4 3.8GHz Celeron D 3.06GHz P4M80-M7 1.0 P4M800 Socket 775 Pentium 4 3.6GHz Celeron D 3.06GHz
Dec 08, 2009 | Biostar P4M800-M7A Motherboard
I have gigabyte series g31 m-es2L i want use memory pc 5300.... it's support with this mainboard ???? tx pls reply to :
First, clarification: the closest Gigabyte model is GA-G31M-ES2L... there is no "g31 m-es2L"
For this kind of question the easiest way to find the answer is from the manufacturer: Gigabyte
A quick search of their products results in:
which states that up to 800mhz DDR2 (PC6400) is supported
( 667mhz (PC5300) is also supported. )
Generally with motherboards, if a higher speed of memory is supported, the lower speeds are also supported.
PS: mhz times 8 yields the PCxxxx number, PCxxxx divided by 8 yields the mhz number
Feb 09, 2009 | Gigabyte Matx Intel G31 775 DDR2-800...
Does msi motherboard P4M900M3 support this cpu Intel Celeron D CPU 3.20GHZ 512 Socket 775
MSI has two boards P4M900M3-F, P4M900M3-L.
Both of this will support your CPU
Nov 26, 2008 | MSI Computers & Internet
Uppgrade of processor!
looks like that mobo can only suppoport up to 53 mhz front side bus for a celeron d processor
wht tht means is tht u can get any cpu tht has the front side bus up to 533mhz with the 775 socket forur motherboard
and forpentium 4 its 800mhz and agian any cpu with up to 800 mhz front side bus and 775
so ur best cpu for tht mobo would be the SL7RR it supports hyperthreading
here a direct link to intel'ssite
3.40 GHz
800 MHz
109.6 W
512 KB
2 MB
0.13 µm
pls rate my answer if i helped u
Sep 22, 2008 | Computers & Internet
Intel Motherboard Logo
97 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
