This error is generally caused due to conflict between windows updates and svchost.exe. For resolving this problem you have to download a hotfix from microsoft.com. There are some workaround as well to resolve this issue:
Method 1
loadTOCNode(2, 'workaround');
Leave the svchost.exe - Application Error dialog box open, and then follow these steps.
Step1: Check whether settings for the Automatic Updates service and for the Background Intelligent Transfer Service (BITS)
are correct
loadTOCNode(3, 'workaround');
To do this, follow these steps:
- Click Start, point to Run, type services.msc, and then click OK.
- In the details pane, locate and double-click Automatic Updates.
- Click the Log On tab.
- Make sure that the Local System account option is selected and that the Allow service to interact with desktop check box is cleared.
- Make sure that this service has been enabled in the Hardware Profile list. If this service has not been enabled, click Enable to enable the service.
- Click the General tab, and make sure that the Automatic option is selected in the Startup Type list. Under Service status, click Start to start the service if it is not already running.
- Repeat steps 2 through 6 for Background Intelligent Transfer Service (BITS).
Step 2: Reregister Windows Update components
- Click Start, click Run,
type REGSVR32 WUAPI.DLL, and then press ENTER.
- When you receive the "DllRegisterServer in WUAPI.DLL succeeded" message, click OK.
- Type the following commands in the Open box, one after the other, and then press ENTER after each command:
REGSVR32 WUAUENG.DLL
REGSVR32 WUAUENG1.DLL
REGSVR32 ATL.DLL
REGSVR32 WUCLTUI.DLL
REGSVR32 WUPS.DLL
REGSVR32 WUPS2.DLL
REGSVR32 WUWEB.DLL
Step 3: Rename the Windows Update temporary folder
The temporary folder of Windows Update may be corrupted. In this case,
you can rename the temporary folder of Windows Update. To do this,
follow these steps:
- Click Start, click Run, type cmd, and then press ENTER.
- At the command prompt, type
net stop Wuauserv, and then press ENTER.
- Click Start, click Run, type %windir%, and then press ENTER.
- In the folder that opens, locate and rename the SoftwareDistribution folder to SDold.
- At the command prompt, type net start Wuauserv, and then press ENTER to start the Automatic Updates service.
Back to the top
Method 2
Follow these steps:
- Click Start, right-click My Computer, and then click Properties.
- In the System Properties dialog box, click the Automatic Updates
tab.
- Click Turn off Automatic Updates, and then click OK.
- Restart the computer.
- Use the Windows Update Web site to install updates manually.
- After you install the updates manually, turn on Automatic Updates.
Link for downloading Hotfix :
http://support.microsoft.com/kb/927891/
Download the one which is for your Operating system.
I have automatic updates already installed. How do I change the update status from "Cancelled" to "Succeeded" for Windows XP Media Center Edition 2005.
Each time I close down the computer it re-installs the same updates.!
