I have an X5470. I have done the unplugging and restarting as suggested, but I cannot get it to scan. Please help. My grandchildren did some copying, could they have changed some button to stop the scan working?
  • 849 Answers
I need to re install scaner driver
Posted on Oct 21, 2008
Rint,copy,scan or fax on my x5470 lexmark all in one. I unplug and restart compture and the fax still says paper jam check rollars dont see noughting.
Leading cause of paper jams is debris / foreign objects that accidentally fell into the paper feed area. Please try this approach to fix the problem:
  1. Remove the sheets of paper from the feeder.
  2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
  3. If you're willing and physically able, you may also carefully turn the printer over. Any debris should just freely roll out from the feeder.
  4. If feeder is clear, place the printer on the table. Open the printer cover and remove the cartridges.
  5. Check the cartridge area for any obstructions in the paper path.
  6. Close the printer cover.
  7. Re-brick your printer by pulling out the power supply - the black box where the power cord is plugged into. Re-plug after 30 seconds.
  8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again to verify that the problem is fixed.
Dec 09, 2011 | Lexmark X5470 All-In-One InkJet Printer
Unable to scan with x5470 Lexmark all in one
please try scanning with another program, for example you can try paint to start paint
press and hold the windows key, then press r. the run menu comes up, type in mspaint. ones the mspaint is open click file and select from scanner or camera, follow the scanning wizard and let me know the results.
Sep 24, 2008 | Lexmark X5470 All-In-One InkJet Printer
Need a cd for my lexmark x5470.please advise .Jim
You can download the Lexmark X5470 driver from the Lexmark website at http://bit.ly/aNFBAO. When scanning documents for editing, you will need the Lexmark OCR scan software which is only available in the installation disk. Contact Lexmark technical support for assistance with the scan software. Thank you for choosing Lexmark.
Oct 09, 2010 | Lexmark X5470 All-In-One InkJet Printer
Scanner & Copier doesn't work
If you get this error when trying to scan from the computer try starting the scan directly from the device and see if that works. If not, unplug and replug the USB cable(assuing you are connected to the computer via USB cable) and install the driver, if you get any plug and play prompts. Let me know if this doesn't work.
May 06, 2009 | Lexmark X5470 All-In-One InkJet Printer
How do I digitally tune my westinghouse TV SK32H24OS. Lost manua
The easiest way might be to unplug the power from the set for several minutes, plug it back in and then run through the setup procedure. You are specifically looking for the channel auto scan function.
Feb 25, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Trying to scan and the display says ''Cannot retrieve application list''. What does that mean and how can I get rid of it?
When all else fails, turn it off an on. Lexmark web site suggests:
  1. Unplug the power adapter from the back of the printer.
  2. Plug it back in after 30 seconds.
  3. Submit the scan job again.
If that doesn't work, reply back with your connection (usb or wireless.) Also will it print?
Steve
Feb 17, 2009 | Lexmark X5470 All-In-One InkJet Printer
Lexmark x5470 all in one printer
Where is the black line when you scan? Where is it when you print? Does it appear on every print job or only things you have scanned?
Steve
Sep 12, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark x5470
When you got this message were you trying to scan?
What I want you to do is a copy. Doing a copy will generally not require you to be hooked to the PC.
Scanning and Printing all require communication from the printer to the computer. Failure in communication can either be something on the computer, something wrong with the cable or rarely something wrong with the printer.
I'm assuming you have done the following:
1. Power off your printer and your computer.
2. Unplugged the power from the printer
3. Unplugged the USB cable from both the printer and the computer.
4. Reconnect the USB cable to the printer and the computer.
5. Plug the power back into the printer and make sure the printer is on.
6. Turn on the computer.
Those are general troubleshooting steps that can be done for any communication problem.
If you have done all of those try this:
Press and hold down the Windows key on the keyboard, and then type the letter R.
Type "devmgmt.msc" and then click OK on the Run dialog.
Find the item Universal Serial Bus controller.
Click the + sign next to the word Universal Serial Bus controller.
Do you see USB Printing Support?
Yes:
Right-click on USB Printing Support, and then click Properties.
Does the Device status say “This device is working properly.”?
Yes:
Have you tried uninstalling and reinstalling the software?
No:
Click the Troubleshoot button to try to resolve the problem.
Does the Device status now say “This device is working properly.”?
Yes:
Try your print again (might need to restart)
No:
Might have a problem with your Printing Support
No:
Let me know - if you have a problem with your printing support you'd really need to contact your PC MFG for help - but you can always try uninstalling the USB Printing Support and reinstalling it (only if you have your disks that came with your printer).
Sep 10, 2008 | Lexmark X5470 All-In-One InkJet Printer
Scanner
this happened to me yesterday after recieving whatever lexmark update my computer downloaded. I restarted everything, computer and turned on/off fax and unplugged for a bit.
It seems to be working OK now.
I know that's lame dell-style, advice, but the restart worked for me.
Feb 12, 2008 | Lexmark X5470 All-In-One InkJet Printer
37 people viewed this question
jasbo
jasbo
