Question about Dryers
Tumbler inside is loose. Clothes get caught and ruined.
  • 67 Answers
Most likely, one or more of the roller wheels is broken. to take apart most dryers, first take out 2 screws on the bottom of the front of the dryer. that should allow you to remove the bottom panel and allow you to get to 2 more screws that will remove the front panel and door. from here, you should be able to look under the drum with a flashlight and see what is going wrong. if you do need to replace one of the roller wheels, you might as well replace them both, they are cheap enough. you need to replace the wheel and the roller bearing that goes in the middle of it. using the model number of your dryer, you should be able to find replacement parts cheap enough online.
let me know how it goes!
Posted on Oct 21, 2008
Frigidaire Gallery dryer Model FSG447GHSO. Clothes and dryer sheets get caught between the drum and one of the three "bumps" inside the drum, causing burn marks on clothing. I can see the gap where it
There is a gasket that fits around the back side of the tumbler. Sounds like it needs replacing. It's job is to keep clothes inside the tumbler.
Oct 10, 2014 | Dryers
He5t tearing clothes
Are you sure that the clothes are not getting caught on exposed zips.
Why not load some things like towels sheets (without zips/buttons etc) in the washer and see if the issue repeats itself. You should also be able to see if there are any sharp edges or loose sharp items in the drum (mind your fingers)
Dec 14, 2013 | Kenmore Elite 45986 Front Load Washer
My Frigidaire front load dryer is ruining my clothes. I can only guess loose straps, strings... get caught on lint trap on door and with the continually spinning o the drum, they eventually break. I...
If you take front of dryer off, there is a half moon shaped piece of felt on top of door opening that most likely has worn and leaves a gap between drum and where that felt is. Replace that for right drum fit.
Sep 11, 2017 | Dryers
My GE Adora dryer is ripping clothes
look inside the drum with a flashlight and look for broken or loose tumbler rib, can be fixed with epoxy, sand smooth surfaces first, let cure and use appliance paint to paint it
Jun 09, 2012 | GE Adora Super Capacity Dryer
My clothes are being ruined in the dryer..I have the DCVH515 frontload model...clothes getting caught inside..i think some kind of seal from the inside around the door opening is gone..clothes are getting...
I have had the same problem for about 6 months. I have been sticking duct tape on the inside over where my clothes were getting hung/caught. It works :) but the heat makes the duct tape peel off so you have to keep replacing it. We finally had to call a repairman when the drum started making a horrible noise. He came out this morning and said one of the "sliders" the drum rolls on had broken. He said when the sliders begin cracking it can make a very slight gap where the clothes were getting caught. I have run 3 loads this morning and had only one dishtowel get hung whereas before multiple items in each load were doing it. He said there are multiple sliders so it may happen again.
He also said the clothes getting hung was an indication of a breaking slider so you may want to call a repairman to head off your drum doing what mine did. It cost me a total of $105 and I live in SE Texas.
Aug 02, 2011 | GE DCVH515EFWW Electric Dryer
We have a Maytag Electric Dryer, Model LDE512 , which leaves black marks on clothes while drying them. The dryer is about 18 yrs. old and has been working great except for this one problem. We have...
HI The drum is mostly stainless steel; The end that contacts the drum guide is just painted steel. After years of rubbing, some rust can form after the paint wears away,thus, causing the stain. Painting the bare metal (after removing all rust) and replacing the tumbler bearings,roller and roller shafts, will correct this issue and prevent it form happening in the future. You should also replace the tumbler seal while the unit is disassembled. Part numbers are below:
Tumbler bearings/Glides(You need two)- 306508
Roller - 12001541
Roller shaft - 6-3129480
Tumbler seal - 314820
Roller Shaft washer - 312535
Retaining Ring(shaft)- 410233
Jul 16, 2010 | Dryers
Clothes get caught between the drum and the front of the inside nonmovable part of the dryer and we are getting snags of the clothing inside and ruining the clothes
there is suppose to be a felt type piece that goes on the drum to full that gap it may have fell off . its a struggle to put on unless the drum is accessible. you can pop the top of the machine off to get better access.
Aug 23, 2009 | GE DBXR463EDWW Electric Dryer
Clothes have holes from getting caught in seall during spin cycle
YOUR OVERLOADING UNIT,,CLOTHES SHOULD ,,FLOP LOSELY..TAKE A LOOK A THAT DOOR BELLOWS AND MAKE SURE ITS NOT WARPPED ,,PITCHING TO FAR TO THE INSIDE OF UNIT,,ONTHEJOB..
Jan 12, 2009 | Frigidaire ATF6000ES Front Load Washer
Dryer Noise & Black Marks On Clothes
Most likely the front drum bearing part number 5303937139 needs to be replaced. Instructions come with the kit.
May 31, 2008 | Frigidaire FDE336RE Dryer
Dryers Logo
79 people viewed this question
Top Dryers Experts
