Question about Garden
Water pump leaks.
My shallow well pump seems to be leaking around the seal plate. I had a poor connection at the outlet and it leaked. I fixed that and it started to build pressure from the hot water heater. It took awhile but I finally put in a back flow prevent valve and new seals in the pump.It stills leaks, I though at first it might be coming from around the shaft. I did a few things and it didn't help, instead I think it might be leaking around the seal plate. I but the old O-ring on the seal plate because it was a tad bigger and it might have slowed drip a little. I have been getting about 5 gal. a day from the drip.
3 Suggested Answers
SOURCE: Leaks water out of the back
Well, I am no plumber but I would think that 108 psi is a bit high for your plumbing system. I have this pump installed in my house and have the max pressure set at 50 with a PRV on the outlet side of the pump.
Posted on Feb 22, 2010
aquaman987
  • 927 Answers
SOURCE: I have a 2hp sprinkler
1. You only should have one check valve; the one in the water is best, remove the other if you can.
2. Make sure there are no leaks in any of the piping between the water and the pump inlet.
3. Take the pump apart, thoroughly clean the new seal, the two halves of the pump that go under the metal band, the inside of the metal band.
4. Lubricate the new seal, the outer sides of the pump halves where the metal band squeezes together, the inside of the metal band where it contacts the halves and even the screw on the tightening device using petroleum jelly (Vaseline) or equal. Make sure the pump literature does not recommend against whatever you use.
5. Reassemble.
6. Fill the pump with water, open the discharge on top of the pump if possible and prime.
Normally, a pump, even with a long run will prime in 5 minutes or less.
Write back.
Your FixYa Texpert,
Gary
Posted on Aug 22, 2011
How do i keep water out of my trunk
New trunk seal , that rubber thing around the edge of the opening !
Nov 01, 2015 | 1998 Buick Regal
Ice maker leaks water into ice bin
Some things I have seen that causes this issue:
A. Plug not sealing properly in the bottom of the water reservoir
B. An issue dealing with the circulation pump. Maybe splashing water out of the reservoir while running due to crack in pump housing, especially around impeller, or hose that feeds water from recirculation pump to cold plate has a crack/split/loose connection.
Dec 23, 2013 | GE Monogram ZDI15C Automatic Icemaker
Miele G2020 leaking 2 spots help
please follow this steps and fix it. God bless you
Dishwasher Not Leveled
This is a very common reason for a leaking dishwasher especially if this was a new installation. The framing in a dishwasher is made up of mostly thin sheet metal, so if it is not sitting flat and level things can get distorted very easily.f3a0b0dc-c8b0-4678-bccb-f94392039827.gif
Door Seal
This is not very common in most dishwashers. To check this look for rips and distortion of the seal. If it is ripped or distorted you will need to replace.
Dispenser Seal
This is a more common place for a leak to develop. This is easy to check, remove the front panel and carefully inspect around the seal for water dripping or stainage. If any is found replace the dispenser gasket.
Water Inlet Valve
Usually it is the connection to the water inlet valve that ends up leaking. Check this connection ( there is usually some sort of adaptor between the valve and supply hose) for leaks. Check the connection on the back of the water inlet valve also. Ocassionaly a water inlet valve will leak around the solenoid in this case replace the water inlet valve.
Drain / Circulating Pump
Some dishwashers have separate drain and circulating pumps Some use one pump to serve both purposes. In either case you will need to check the housings for leaks along with all the connections. Some dishwashers have a seal that leaks down into the pump . This is easy and inexpensive to replace. Follow the tutorial on replacing the pump.
Door Latch
The door latch can become loose or misalinged. Check both the striker and the latch. To adjust the latch you will need to remove the front panel and adjust switch until properly aligned.
Door Hinges
They can cause problems, but this usually only happens from opening a heavy load of dishes on the door. Occassionaly a broken spring or cable occurs. You will need to remove the tow kick and maybe the front panel to inspect.
Jun 14, 2013 | Miele Dishwashers
Dishwasher leaks after I cleaned the air pump
If your dishwasher is Leaking check the following
This is a very common reason for a leaking dishwasher especially if this was a new installation. The framing in a dishwasher is made up of mostly thin sheet metal, so if it is not sitting flat and level things can get distorted very easily. Watch the video on leveling your dishwasher
Door Seal
Dispenser Seal
Water Inlet Valve
Usually it is the connection to the water inlet valve that ends up leaking. Check this connection ( there is usually some sort of adaptor between the valve and supply hose) for leaks. Check the connection on the back of the water inlet valve also. Ocassionaly a water inlet valve will leak around the solenoid in this case replace the inlet valve water
Some dishwashers have separate drain and circulating pump. Some use one pump to serve both purposes. In either case you will need to check the housings for leaks along with all the connections. Some dishwashers have a seal that leaks down into the pump . This is easy and inexpensive to replace.
Door Latch
The door latched can become loose or misalinged. Check both the striker and the latch. To adjust the latch you will need to remove the front panel and adjust switch until properly aligned.
Door Hinges
They can cause problems, but this usually only happens from opening a heavy load of dishes on the door. Occassionaly a broken spring or cable occurs. You will need to remove the toe kick and maybe the front panel to inspect.
Use the VOM, God bless you76c7517c-e034-47da-bf6c-02b58ecb7551.jpg6274586f-de4d-45f0-bbab-ada21592e251.gif
Apr 05, 2013 | GE Profile PDW8400J Built-in Dishwasher
My new pump leaks around seal plate
Leaking wet ends are a result of a bad shaft seal.Check to make sure it is installed properly or install a new shaft seal to prevent more leakage.If the motor runs and it will draw the leaking water into the motor and ruin your motor.Change the shaft seal as soon as you are able to prevent further motor problems.
Rod
US Parts Center
888-521-6813
Mar 02, 2013 | Pool & Spa
Challenger pump leaking at the band
You may need a seal plate o-ring or you may have a shaft seal leak. See if you can determine if there is water running down the outside of the seal plate from where the motor mates to the seal plate.
Feb 15, 2012 | Pentair 1 HP Challenger Pump
1/2 hp shall well pump. set at 30/50....seems to hesitate around 48 for an extra amount of time....have to shake the hose or tap the pressure plate to get pump to cycle off. also....noticed the pump...
50 PSI for a 1/2 HP pump is approaching the upper limit for that pump. Many things can affect the upper limit. How far the pump has to pull water up the well pipe, is there any air leak what so ever on the input. If the pump lost its prime because it could not attain the 50PSI, I would suspect it may be just outside the limits of the pump at this point in time. If this pump is on a shallow well, it may be that the shallow well point is beginning to plug and not allowing as much water in which would cause a harder pull for the pump. I would turn the high pressure side down to maybe 45 and see if it operates properly at that pressure.
I hope this helps.
Jun 22, 2010 | Flotec Corrosion Resistant Shallow Well...
My 2006 charger 3.5 is leaking coolant but only somtimes is it a sign of water pump malfunction no indications on the gauges but car seems to be running hot
this is most likely the water pump if it is leaking at front of engine, the water pump is under the large timing belt cover and driven by the timing belt, so both are changed at the same time.
Feb 04, 2010 | 2006 Dodge Charger
I have a five year old Rheem heater that has suddenly begun leaking out of the connections at the top of the unit. It seems mainly to be coming up around the seal for the hot water flow. What's with this?
It could just be a leak around the threads of the connection of the pipe nipple in the hot water outlet. If so, you'll have to take out the one there now and replace it with a new one.
Aug 31, 2009 | Water Heaters
Water leaking from under washer
Hi
You'll need to open the machine and check for the leaks in the hose connected to the drain pump. Also check if the clamp connecting the drain filter and hose is tight. Also check these things for leaks---
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you'll need to replace it.
Please do rate this solution as FixYa if found useful and revert for further assistance.
Thanks
Rylee
Apr 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Garden Logo
217 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
