Question about Frigidaire CWS3600AS Top Load Washer
How do you replace the belt on stacked washer?
Though I am a chick, I love doing repairs myself. Can I do this myself or is this one for the pros? I imagine you can get to it from the front or back & not have to tip it over...help!! Thanks.
My part# is 134051000
  • 750 Answers
Hello elizabethdas,
Welcome to Fixya,
I'm Huuum,
You said, Though I am a chick, I love doing repairs myself. Can I do this myself or is this one for the pros? I imagine you can get to it from the front or back & not have to tip it over...help!! Thanks. My part# is 134051000
I have a repair and parts site here below for you!
1. Scroll down to page # 2 on the left side and click it open .
Then in the upper right of each diagram it says,Open This Diagram in a New Window Click it!!
There you will see how to open the machine.
2. Go to page #5 on the left side and click on it to see the belt and parts location.
http://www.pcappliancerepair.com/model-display.php
The belt cost only $11.05 plus shipping!
F28 134511600 V-Belt Goodyear In-Stock $ 11.05
I believe I solved your questions 100%
Let me know how it goes!
Thank You,
Huuum
Please remember to leave a rating.
Posted on Oct 21, 2008
My Dryer portion of my GE stacked washer/Dryer will turn on and I can hear the motor running but the drum will not turn. I pretty sure is the belt. I haven't been able to locate a schematic anywhere of the...
Not that easy but go to this web site www.applinace pros.com and look at it's diagram and you can see if you want to tackle this issue, if you do and rn into problems you can get help from us here if you need it.
Nov 13, 2009 | GE WSM2700W Unitized Spacemaker Washer and...
How do I replace the washer belt
Remove the front panel to the washer. Screws across the bottom. Push down on the front panel, then pull it out. Belt should go around transmission, motor pulley and tension roller.
May 13, 2009 | Frigidaire MET1041ZA Top Load Stacked...
Washer smoking
If the WASHER BELT is burnt or broken or the WASH TUB is not rotating properly.
FIRST CHECK THE BELT:
You can unplug the unit, remove the front panel of the washer and then slowly remove the belt. The replacement belt is easy to put back on. Finding a belt on the internet for under $10 is easy - just search for a belt with part number 134161100. Potentially the plastic pieces are from the damaged transmission. Replace the belt first to see if you can keep using the unit. If the transmission is damaged it is a bit expensive to replace and difficult to do yourself. I'll keep you posted if I have to do the same to my unit.
Remove and replace the washer belt (order part # 134161100 from google or ebay), arrived in two days and noticed busted plastic pieces and two semi-circular metal bearings that would have fit into the bearing.
IF REPLACING THE BELT DOES NOT WORK (read on)
Troubleshooting
Step 1: Keep the front panel of the unit off and run the unit in a normal wash mode. You can do this without filling up the wash tub with water by simply rotating the WASH dial to the proper setting (eg. RINSE). Be very careful as the moving parts could cause injury while the front panel of the washer is removed and the tub is turning.
Step 2: Watch to see if the belt is still slipping and the tub does not turn. If it rotates properly, then congratulations, you have fixed your problem with a new belt. If the belt still slips, ... proceed to step 3.
Step 3. Some web sites (and the user guide) say that the 'tension spring' may not be working. I don't believe this is the case. Upon closer inspection take a look at the 'transmission' which is the large metal part that rotates the tub. Unplug the unit and using your hands, see if you can rotate the tub simply by turning the transmission part. Turn the transmission in both directions. If you see that it gets STUCK from time to time, then the transmission needs to be replaced due to some worn bearings.
NOTE: From here you must first consider three things:
A. Do I want to get into a major repair with this washer, or simply purchase a new stack set?
B. Should I call a GE repair guy and have him replace the transmission?
C. Should I do it myself?
HOW TO FIX (If you chose "C" above):
FIX Prep Step 0. Gather a bunch of old towels around to clean up any water that spills
Step 1. Empty the wash basin and disconnect all external hoses, gas lines etc.
Step 2. Arrange the stack set so that you can lay it down on its back. Always good to have two people to do this step.
Step 3. Disconnect the tub basin springs and all electrical wires from the motor (this is easier to do while the unit is laying down; some channel lock pliers come in handy)
Step 4. You can stand the unit back up for this step. Slowly remove the tub basin from the unit, and position it upside down.
Step 5. Remove the transmission (requires standard socket set)
Step 6. Order the Transmission Assembly Kit online (I found mine at SEARS PARTS ONLINE, and when I called to check if they had it in stock, the customer service rep even gave me a code for 10% off the online order - not too shabby and makes me want to go back again. Great support service!)
Step 7. When the part arrives, re-assemble everything and test.
REORDER PARTS INFO
Tub Assembly Part Number: WH38X10014 (aka. GE part # 1603 on their 'break away' diagram)
Available on SearsPartsDirect.com
Note: The GE Parts people were unfortunately not helpful at all during this troubleshooting. In fact, when calling their support line I was told that they would not even sell me a transmission because I was not a certified repair man. The GE service rep was insistent that I could not find the transmission anywhere else except through them. Although they have nice diagrams of all the WSM2780 machine parts on their geappliance.com web site, don't look to them for any extended repair support.
You can contact me if you have any questions.
Thanks, Chringram
Jan 27, 2009 | GE WSM2780W Stacked Washer / Dryer
REPLACE BELT
look to see if you have the little access panel on the back,you can remove this and have access to the belt and pulley system,if not there let me know and we'll try something else-mike
Oct 31, 2008 | Frigidaire FEX831CS Top Load Stacked...
Thumping/knocking/rattles during wash agitation cycle
Mine is doing the same thing. I opened it up to see what was happening and it was the drive belt tension arm bumping around. Soon, the belt started slipping during the spin cycle. Now it won't spin and the belt starts to smolder from the friction of the drive motor. If you haven't checked your belt, that's a good place to start.
Jun 18, 2008 | Kenmore 98702 Stacked Washer/Dryer
Series 80 kenmore washer..doesn`t spin..
Make sure belts are still atached. Belts are relatively inexpensive and eazy to replace yourself.
Jan 14, 2008 | GE WSM2700D Top Load Stacked Washer /...
Kenmore Stacked Washer / Dryer Model Number 417.97802792
can the rear bearing on the drier be oiled/greased though the back casing, any easy way of stopping sqeek!
Nov 07, 2007 | Kenmore 98702 Stacked Washer/Dryer
Washer
pull washer away from wall and lay on it's back. panel will be accessable since belt is only accessible from the bottom because of the tensioner
Sep 22, 2007 | Washing Machines
Frigidaire CWS3600AS Top Load Washer Logo
144 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
