Question about Samsung ML 1250 Laser Printer
Samsung ml-1250 Printing stopped
My Samsung ml-1250 used to work real well until I started getting the "Jobs stopped" message. There are 3 jobs in the queue and I can't get them to print. Is there some way to resume printing that I'm missing?
Richard
  • 94 Answers
Try purging the 3 pending print jobs then try to print again. Go to Printer and Faxes on XP, then right click on your printer icon then select purge print jobs. Or double-click on the printer icon on your system tray (lower right hand of the screen) then click on the pending print jobs then purge it. Then try to print again.
Posted on Oct 21, 2008
Why does my Samsung ML-3712ND printer say "paper empty in MP tray" when it is not empty?
The MP tray is the fold down 50 sheet tray that is built in to the front door of the Samsung ML-3712. It is usually used for thick papers, letterheads and unusual sized paper.
Sometimes people mistake the 250 sheet cassette tray that slides underneath the printer for the MP tray.
If you want to print on plain paper in your cassette tray and you keep getting this message.
1. cancel all print jobs
2. try printing a new document ( you can make a new word document with just one line)
if that works
Usually one of the settings in the print job you are printing will be out of specification ( could be too small margins) and the printer will be trying to feed from the MP tray
If the new print job doesn't work, the problem is likely in your default printer settings/properties
Dec 01, 2014 | Samsung Office Equipment & Supplies
The printer does not accept print jobs and orange warning light is on along with green ready. Both lights sart blinking when a printing job is sent. The printer does not print. How can I fix the probl
Dear
I am not familiar with Ubuntu. So in case of windows SMART PANEL/EASY PRINTER MANAGER can be down loaded from samsung web this will show the errors that the machine has.
Try to print a self (demo page) pressing stop s/w a while. If it works check the life of toner cart.
Thanks.
Sep 19, 2014 | Samsung ML-2571N Laser Printer
Samsung ML-2152W won't initialize
I am working on one of these right now for a customer. It is doing nearly the same thing. I am 99% sure it has bad capacitors in the power supply. I have removed the power supply board and found swelled and leaking caps. I will get them replaced to verify, but I am positive that is the solution. Your printer will need either a new/repaired power supply or have your existing power supply board repaired.
Good Luck
Nov 26, 2009 | Samsung ML 2152W Laser Printer
I have a Netgear PS121v2 USB printer server connected to my rounter and a Samsung Laser Printer ML-1250. For some reason I cannot print anything because the printer status indicates the printer is paused....
Try purging the pending print jobs then try to print again. Go to Printer and Faxes on XP, then right click on your printer icon then select purge print jobs. Or double-click on the printer icon on your system tray (lower right hand of the screen) then click on the pending print jobs then purge it. Then try to print again.
Oct 22, 2017 | NetGear PS121 Print Server
Samsung ML-2510 will not print from MAC OS on Macbook
This printer has problems with Leopard last updates.
Contact Apple to see if a patch is available to run the printer on updated Leopard:
Apple - How to Contact Us.
Regards.
May 23, 2009 | Samsung ML-2510 Laser Printer
Hi, sorry to hear you are having problems,
OK, first of all, you can stop worrying about solution #3, this printer is a USB or Parallel, there is no networking on this printer so no possibility of an AppleTalk connection.
You say you have downloaded the latest version of the driver from the Samsung website.
And, the Mac is connected DIRECTLY to the printer via USB.... ( It won't work if it's connected to a PC and then shared.. well it might work but I have not been able to make this kind of connection work...)
Well, if this is the case and you are unable to print while the PC prints fine, I expect that it is over the Parallel port or do you plug and un-plug between the Mac and PC...
It might be that the printer needs to reset after switching between the Mac and the PC, Shut off the Printer, I mean really, shut it down, unplug it for 30 seconds then connect it to the Mac and restart the Mac and start up the printer....
If it still does not work, do you have another Mac you can connect to for testing?
Also, the first test should not be FireFox, open the Text Edit app and type ( TEST ) and just print that...
Give that a whirl..
Dec 22, 2008 | Samsung ML-2510 Laser Printer
I have a Samsung ML 2510 printer. It was printing just fine and then the red light below the triangle with the exclamation in it came on. When I send jobs to the printer nothing happens. I have checked...
Toner in your catridge might be over. Turn off printer. Click Start, settings, printers and faxes. Make sure it is your default printer and double click on it. Cancel all the pending jobs. When everything is deleted close the box and turn the printer on and continue your job.
Dec 17, 2008 | Computers & Internet
I had the same problem and spent some time trolling the Net. But....I found it.
Run installer from CD.
Tthen go to system preferences > print and fax
Delete the ml-2510 by clicking the minus square
Click the add square..
Select the ml-2510 again, and make sure that at the bottom of this window, under the "Print Using:" field, you again select the ml-2510.
Click add.
That's it! You're good to go!
Aug 05, 2008 | Samsung ML-2510 Laser Printer
I had the same problem and found the solution on the Apple discussion boards. Apparently, OSX 10.4 installs the printer as a Lexmark 510 series, not a Samsung ML-2510.
Just add a new printer and change the type from Lexmark 510 series to ML-2510 series.
Worked a charm for me!
See: http://discussions.apple.com/thread.jspa?messageID=5955598
Aug 12, 2007 | Samsung ML 2010 Laser Printer
Unable to stop printer from printing documents
The actual folder in Windows where spooled documents are stored just before printing is: C:\WINDOWS\System32\spool\PRINTERS. I?ve never had print jobs hanging around after the print queue has been deleted but if you clear out anything in this folder that should take care of it. Let us know how things work out and please don?t forget to rate this posting.
Mar 17, 2007 | Samsung ML 2010 Laser Printer
Samsung ML 1250 Laser Printer Logo
156 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
