Question about LG CED 8120B CD-RW Burner
Does not read disc
My LG CED 8120B CD-RW often fails to read any type of disc. I have installed the latest driver but still fails to read most of the time. Sometimes opening and closing the door helps, but not often. I am a computer idiot but here's what I do know. I am running Windows XP, the discs I am trying are either new or work on another computer.
  • 33 Answers
Many problems arises when we speak bout unredable roms, or rom's that sometimes read. might be problem with weak lense, or a weak motor, or a bad board. then only thing u can do is try to clean ur lense with some spirit, or a CD lense cleaner.
if it still didnt work then it looks like u goota take it to an expert.
Posted on Oct 22, 2008
Where can I download the drivers for an LG CD-RW CED-8120 unit. The only sites I can find are those who run a "free" scan but you have to purchase the drivers. I cannot locate a driver download or even...
Assuming that you operating system is Windows XP, or Vista, Windows 7 you don't need a driver for this cd rom; these drivers are embedded in the operating system. You just have to connect the cd rom at your motherboard. In case of not working there has to be a problem somewhere else. Post me back what exactly is your problem in order to help you to solve it.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Sep 25, 2010 | LG CED 8120B CD-RW Burner
I have a LG dvd rwriter but it's not recognized in my computer.
use this link to get the drivers for your drive. this is one of many places to get your drivers. if its not seen its because its not installed. this should fix your rpoblem
http://driverplex.com/wp-content/uploads/2009/08/all-drivers.php?brand=LG%20CD-RW&tid=se-en-us-2101152
Aug 29, 2010 | LG CED 8120B CD-RW Burner
My LG CD-RW 8120 will read CD-Rs but nothing else and it will not burn discs. Could it be that I need to update the driver? If so, where would I find an updated driver because the LG website does not...
Go to this link Driver then go to the middle of the page and press this link
moz-screenshot-2.pngico4.jpg LG CED-8120B driver download
put the verification number in and press download.
Please retype verification code verimg.php
here and press
If you click and anything else it will send you somewhere else. It is not the best made site. but it should help you..
I hope this helps
May 30, 2010 | LG CED 8120B CD-RW Burner
My cd-rom drive keeps on opnening and closing?can you help me? i remove the IDE cable but it still opens and close...TNX
Dude CD ROM's are designed to close all by themselves in case if there is anything stuck in between,just unplug the CD Rom,and u might find a small hole,kindly punch in it using a pin so that the front portion of cd rom will open and clean up the entire drive using a soft brush(b careful about lens present inside)and fix it back and check out whether it works out
Nov 10, 2009 | LG CED 8120B CD-RW Burner
Need instuctions on how to operate LG GSA-E10L DVD rewriter
When I want to operate the rewrite , if i want to burn something what is the first step?
May 08, 2009 | LG CED 8120B CD-RW Burner
LG CD-RW CED-8120B will not read dvds
I have a LG CED 8120B in my computer right now. The reason you cannot read DVD's is because it is a CD player/burner, and not DVD.
Mar 01, 2009 | LG CED 8120B CD-RW Burner
Install to computer problem
Sounds like a case of jumper settings. If the CD-RW was installed as secondary IDE to an existing hard drive which is the Master, pls set jumper to SL. They are located at the rear of the CD unit between the IDE connector and the audio out.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Feb 19, 2008 | LG CED 8120B CD-RW Burner
Nero cr-rw burner install
is your hard drive the master on the primary cable? You shouldn't need a digital audio cable unless you want digital audio. Are you using Nero software witht he drive? may have to re-install the software, or better, uninstall it, clear the registry with CCleaner (free download on the web) and then try a fresh install.
Dec 13, 2007 | LG CED 8120B CD-RW Burner
CD Burner stops in middle of burning
Hi KayGo, People hate going over the basics but gotta ask: -Have you tried cleaning your read/write heads using a commercial cleaner? -Do you have any problems reading CDs? -What Brand of CDs are you using? If you're using the cheapies you should try a few quality brands such as HP or Fugi. -Have you checked the drives manufacturers specifications for blank disks? -What recording speed are you using? Try setting it lower and see if that has any effect. -How much reading and writing have you done with this drive? They do wear out and CD only R/W drives have a history of not lasting long. -Have you tried running a diagnostic on your drive? Here is a link to the Sony CD/DVD diagnostic tool. Meant for Sony drives but I have used this successfully on other drives - http://sony.storagesupport.com/cdrw/diagnostics.htm#dwn Let us know if you need any other assistance and don't forget to rate the posting.
Jan 03, 2007 | LG CED 8120B CD-RW Burner
LG CED 8120B CD-RW Burner Logo
278 people viewed this question
Top LG Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
