Question about Linksys Wireless-G WRT54G Router
Cannot access the internet
I have a desktop PC and a laptop PC. I cannot access the internet with the laptop using the WRT54G router as we had an electrical outage last night.
Everything was fine before that. The message I am getting says that the settings that are saved to my computer do not match the settings on the router.
How do I go about getting these settings right?
Monty
    Problem Solver:
  • 11 Answers
Try this :
1. it seems that the power outrage had caused your wireless settings to be restored to its factory settings .... so there is a need to reconfigure it again ...
the settings that are saved to my computer do not match" --- this usually pertains to the network settings saved on your laptop, if it is vista you must delete the old profile,it also applies for xp OS ....
VISTA :
>network and sharing center
> manage wireless connections
>under networks you can view or modify, highlight the old profile then remove
XP :
>netowrk connections
> right click on wireless network connection and go to properties
>click on wireless tab
>under preferred networks (box in the middle) highlight then remove
2. to check this do ipconfig on the cmd line
•check the default gateway if it is still 192.168.1.1 or 2.1 ( the default gateway is the rtr's address)
•open your browser, then type the rtrs ip
• leave the username blank, password is admin ( small caps)
• then you are in the set up page
• check the wireless tab, and very the ssid if it is still or the name of your network which you used to connect to ...
• just save the settings if you want to make changes
****** very impt : while doing this changes, your main pc or dsktop pc must be hardwired to the router ,, never make changes wirelessly coz the connection is very instable you will be kicked of everytime ..... ***********
GOOD LUCK!!!!!
Posted on Oct 24, 2008
Have a desktop PC and a laptop PC. I cannot access the internet with the laptop using the WRT54G router as we had an electrical outage last night.
Posted on Oct 22, 2008
  • 31 Answers
Is the laptop wireless?
Was it plugged into a surge protector during the outage?
Try :
1. deleting the network settings for the wireless connection in network settings of the control panel
2. readd the network connection.
Posted on Oct 21, 2008
Cannot connect to internet using laptop
If you have a wireless router and it is connected to the DSLor cable modem then - To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards in all the laptops/computers needs to be configured withthese router's wireless settings. Then the laptops/desktop computers cancommunicate with your wireless router and access the Internet via the DSL or cable modem.
Jun 15, 2011 | Linksys Wireless-G WRT54G Router
Whenever I connect the router it says no internet access....
If you have a wireless router and it is connected to the DSLor cable modem then - To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards in all the laptops/computers needs to be configured withthese router's wireless settings. Then the laptops/desktop computers can communicatewith your wireless router and access the Internet via the DSL or cable modem.
May 21, 2011 | Linksys Wireless-G WRT54G Router
I have the Linksys WRT54G router hooked up thru Ethernet to my desktop PC with Windows XP. I go thru a cable modem to the internet. I have 2 laptops, both with Windows Vista on, wirelessly linked to to the...
Low or poor signal is mainly caused by the following major factors:
Going Around Physical Obstructions
Wireless networks are also susceptible to obstructions that may lead to low signal. Often, the signal gets reflected, refracted or absorbed by the obstruction.
Common obstructions are:
  • Cabinets
  • Mirrors
  • Glasses
  • Metal objects
  • Thick walls and ceilings
If you have any of these objects between your wireless adapter and access point, consider relocating your access point somewhere high to get around the obstruction.
Aug 05, 2010 | Linksys Wireless-G WRT54G Router
I just installed security on my system through my router I used my laptop to enter the pass word. I am trying to connect with my router using 192.168.1.1 from my desktop. All it does is go to search. I...
The security you have installed on your system is restricting access to the router. Whatever security you are using, you need to add the router's ip address i.e. 192.168.1.1 in the exception list.
regards
Oct 11, 2009 | Linksys Wireless-G WRT54G Router
Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Apr 10, 2009 | D-Link AirPlus DI-524 Wireless Router
Setting up network with wrt54g with dial-up internet
There is no way a wirless or brodband roter will work for any dial up conecsions only will work for hugh speed internet or DSL internet. If you are chosing to upgrade lock at the chosis verizon has. Just go to www.verizon.com to see if you are elagable. They haves some very low cost deals and if it is ordered online you get a discount,
Jan 04, 2009 | Linksys Wireless-G WRT54G Router
I just got my first notebook it is a compaq evo n400c with a belkin 802.11b (32 bit cardbus)wi-fi card. i am trying to find out how i can get/have internet access where ever i go. how do i go about setting...
Hi Obadiah,
U can take ur laptop to any of the hotspots and u need to turn on the wireless switch in ur laptop so that u can automatically connect to the wireless internet..i think u r aware about hotspots...
If u want to use internet in ur home..u can buy a wireless router..there are lot of companies providing wireless routers..u can buy Linksys..model no is Wrt54g..this wrt54g is a wireless router where u can connect 4 wired desktops and 20 wireless laptops..its cheaper and best.u need to buy a internet connection to connect this router...I suggest u to go for a cable Internet..Cable internet providers are comcast,shah.go for comcast.Hope this info will be useful for u.for further clarifications revert back as soon as possible
Jul 09, 2008 | Belkin Computers & Internet
Need help getting the internet on laptop
you may need to register your router thru your cable company unless you already have..
so if you are wanting a wireless connection, then you will need your internet key to access it.. are you already connected with a desktop or are you just trying to get one pc connected? please clarify.. thanks..d
Feb 20, 2008 | Linksys Wireless-G WRT54G Router
I cannot get my new computer to recognize the linksys router I have Model No:WRT54G
do a search for linksys easylink advisor. it will guide you through setting up your second computer.
Feb 17, 2008 | Linksys Wireless-G WRT54G Router
Laptop
It really depends on what "modem" Orange provided you with and how your personal PC is connected to the modem.
If the "modem" provided by Orange uses WiFi (such as Livebox) networking, then it is a matter of setting up your daighter's laptop to access and use the Livebox WiFi Network. In this case no router is needed since your modem is also a router.
If your PC is connected via Ethernet port to the "modem" and Orange's "modem" is a single Ethernet output port, you would need an AP/Router (Wireless since I am presuming the your daughter's laptop would be accessing the Internet wirelessly) such as the LinkSys WRT54G.
If your PC is connected via USB port to the "modem" and Orange's "modem" has only a USB output port (no Ethernet), you need to make your PC as the default gateway/software router and share your PC's Internet connection. If you are connecting your daughter's laptop using Ethernet cable, then you don't need a WiFi AP/Router but an ordinary hub. If on the other hand the new laptop would connect wirelessly, you would still need something like the WRT54G.
Hope that this be of some help/idea. Pls post again how things turned out or should you need additional information.
Good luck and kind regards.
Dec 04, 2007 | 2wire (1000-400108-001) Router
Linksys Wireless-G WRT54G Router Logo
338 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
