Question about Microsoft Windows XP Professional for PC
Cannot open my harddisk in windows explorer
After copy some files from my cd disk,cannot open my harddisk in windows explorer,the harddisk open,but automatically windows explorer closed the drive.pls help me
Cannot open my computer
Posted on Oct 21, 2008
NEED TO KNOW HOW I CAN PREVENT BACKUP FILES FROM GOING INTO MY RECOVERY(D), AND FILLING IT UP. I AM RECEIVING MESSAGE THAT I HAVE LOW DISK SPACE IN RECOVERY DISK. HOW DO I FREE UP THIS SPACE, AND HOW
Are you sure the files are going in there? Many times the manufacturers only allocate the size that they need partitioned on that drive. I have seen many cases where that drive is full from factory and people always get that message.
  1. Click Start c01508537.gif and right-click Computer .
  2. Select Properties .
  3. Click System Protection from the left side of the Window.
  4. In the section "Automatic restore points", remove the selection next to the D: drive, and then click OK . If the D: drive was not selected, close this window. Figure 3: System Protection tab with D: drive unselected
  5. Right-click Start Explore All Users .
  6. Before you can remove the backup files and folders, you need to be able to view hidden system files as follows:
    1. From the explorer window press the Alt key on the keyboard to make the menu bar appear in the window.
    2. From the file menu, click Tools , and then select Folder Options .
    3. Select the View tab.
    4. Select Show hidden files and folders , remove the selection from Hide protected operating system files and then click OK .
  7. From the Folder Options window in explorer, double-click Recovery (D:) .
  8. If a Window opens stating "You don't currently have permission to access this folder" opens. Click Continue .
  9. If you previously copied or created any files into Recovery (D:) and you want to keep them, copy them to another drive - such as the C: drive.
  10. Find and delete any files that you previously copied onto the Recovery (D:) drive.
    CAUTION:Do not delete any files that are associated to recovery! Do not delete the items RECOVERY, $RECYCLE.BIN, boot, hp, PC-Doctor, pcdr, or PRELOAD! Doing so can prevent a future system recovery from the hard drive. If you are not sure, do not delete the file.
    Press Shift + Delete to permanently remove the files.
    To delete files created from MS Backup (MS Backup files are not recovery files), find and delete the folder with the same name as the computer name in the Recovery (D:) partition. For example if the computer name is BOB-PC, the folder containing the backup files would be named BOB-PC and would be deleted.
  11. Several confirmation windows open. Click Continue , and Yes until the folder is deleted.
  12. To set Windows Folder Options back to their original setting as follows:
    1. From the explorer window press Alt to view the file menu.
    2. Click Tools , and then select Folder Options .
    3. Select do not show hidden files and folders and select Hide protected operating system files .
    4. Click OK .
  13. Close explorer. The Out of Disk Space errors should no longer appear. If you would like to use the Microsoft Backup Tool again, open it and select a different external backup device to store the backup files on.
Aug 17, 2012 | HEWLETT-PACKARD Computers & Internet
Lost software to printer
You can download software from HP website, I will give you the link
Aug 26, 2008 | HP Officejet 5610 All-In-One InkJet...
Tip
The Installation CD Does Not Start Automatically in Windows XP
This tip answers issue regarding CD's that come with your HP printer. <span>If after putting the installation CD into the CD drive, the software does not automatically start installing the software you can do either one of the following.</span> <span>1. On your pc, go to Start, click My Computer, right-click the CD-ROM drive then click Autoplay.</span> <span>2.If nothing happens, check whether the Autorun feature is enabled, if not enable <b>Autorun</b> by going to t</span><span>he <b>Control Panel</b>, double-click <b>System</b>, go to <b>Device Manager</b> and click the plus sign next to CD-ROM Drive entries. Right-click the name of your CD-ROM and go to <b>Properties</b>. In the<b> Properties</b> screen, go to <b>Settings</b> and check the box next to <i>Auto Insert Notification.</i></span> <span></span><span>Or</span> <span>Click <b>Start</b>, then <b>Run</b>, type <span>gpedit.msc.</span>Click <b>Administrative Templates</b> under <i>Computer configuration</i>. Click <b>System</b>, then click <i>Turn off Autoplay</i>.Right-click <i>Turn off Autoplay</i>, then click Properties. Under <b>Setting</b>, click <i>configured</i>.</span> <span>3. If any of the two won't work you can manually install the HP software CD. To do this, c</span><span>lick <b>Start</b> and then click <b>Run. </b></span><span>Click <b>Browse</b> and then select My <b>Computer</b>. </span><span>Click the CD/DVD drive. </span><span>Double-click the <b><u>setup.exe</u></b> file.</span><span>If nothing happens, it may be because CD drive is unable to read the CD.</span> <span>4. Check whether the CD drive is working by playing other CD or DVD.</span><span>If music CD/Video CD is not working then there is an issue with CD/DVD drive, contact Computer manufacturer.</span><span>If the Music/Video CD works with the CD drive, clean the HP software CD using a soft cloth damped in distilled water and wipe the CD with lint free cloth.</span><span>Reinsert software CD and wait until it auto plays.</span><span>If it fails again then try inserting software CD in a different drive if any.</span> <span>5. </span><span>If CD is not working in any of the available drives then copy the files to the hard drive.To do this,c</span><span>lick <b>Start</b> and open <b><i>My Computer</i></b> or double-click <b>My Computer</b> on the Desktop.</span><span>Double-click <b>C:\</b> or <b>D:\</b> , assuming C: and D: are the computer hard drives.</span><span>Right-click the empty pane in C:\ or D:\ of <b><i>My Computer</i></b> and select <b>New</b> .Then click <b>Folder</b> .</span><span>A new folder is created. Rename the new folder <b><i>HP Driver</i></b> .</span><span>Right-click <b>Start</b> and then click <b>Explore</b> to open Windows Explorer.</span><span>Locate the CD-ROM drive letter in the left pane of the window and select it so that the contents are displayed in the right pane.</span><span>Click <b>Edit</b> in the <b><i>File</i></b> menu and then click <b>Select All</b> to highlight all of the files and folders.</span><span>With the files still selected, click <b>Edit</b> and then click <b>Copy</b> .</span><span>Close Windows Explorer. Open the HP Driver folder created in step 1, click <b>Edit</b> , and then click <b>Paste</b> to copy the files to the HP Driver folder on the hard drive.</span> <span><br /></span> <span></span><span>If while copying, a <span>Cannot copy from source disk or drive</span> or <span>Cannot copy specified file</span> error message is displayed, then check the functionality of the CD drive by using a different CD. </span> <span><br /></span> <span>If other CDs work correctly, it means there is an error reading the HP software CD.</span> <span><br /></span> <span></span><span>If the files cannot be copied from the CD, the CD may be defective. In this case, you can either download a software or order a CD at <u>support and drivers</u> page of hp.com.</span>
on Apr 03, 2011 | HP Officejet 5610 All-In-One InkJet...
Toshiba Protege 4004 recognizes a CD-R (52X, 700 MB) blank disk in the drive, displays dialog box "choose program to open the file". Running Windows XP professional, 2002 I want to format the CD, then...
you are getting this message, because it has viruses.
You can open this by selecting inernet explorer from the menu or Open my computer and go to address bar and select CD Drive from the drop down menu. it will open. use a usb harddisk or flash drive to take the back up of your system.
Feb 15, 2010 | Computers & Internet
I need to burn dvd with phptos and vidio on the one disk
  • Click on "Start" in the lower left-hand corner of the desktop screen. Then select "All Programs," "Accessories" and "Windows Explorer."
  • Open the DVD burner tray and insert a blank DVD or CD. Close the tray.
  • Navigate to the hard drive that has the files to be burned. Click on the files or folder to be burned, and drag to the DVD burner drive icon in Windows Explorer.
  • Select "File," then "Write these files to CD." Ensure that all the files that need to be written to the CD or DVD are on the list in the temporary files area that can be found in Windows. The CD writing wizard will open; follow the instructions in the wizard.
  • Remove the CD or DVD when finished and apply label. Close drive tray.
Thanks, SF
Jan 28, 2010 | Microsoft Windows XP Professional
How do i copy a disk
Before you Begin Make sure there is no program runing that has opened any file on the original disk. You cannot run the Disk Copy procedure if any file on the original or destination disks is in use by any program. For example, if you were editing a document in MS Word, saving to the disk in Drive A, and now want to copy it to another disk: FIRST quit the MS Word program, then execute the Disk Copy procedure. Caveat LectorThis Disk Copy procedure will make an exact copy of the original disk on the copy disk. It will completely overwrite the copy disk, replacing anything on it with the contents of the original (source) disk. That means that if there are any files on the copy (destination) disk before you begin, those files will be destroyed. You might want to take a look at the destination disk before beginning to be sure there's nothing on it you want to save. -------- Copying a Disk
  1. Double-Click on the My Computer icon on the Desktop. The My Computer window will open.
  2. In the My Computer Window, click once (not the usual double-click!) to select the icon for 31/2 Floppy A:
  3. Click on the File menu and select Copy Disk. The Copy Disk window will open onscreen.
  4. In the Copy Disk window you will see the option:Copy from 3 1/2 Floppy (A:) to 3 1/2 Floppy (A:)Click on the Start button.
  5. A new window will open prompting you to Insert the disk you want to copy from (source disk). Insert the disk and then click on the OK button. The program will begin "reading" the files from this original (source) disk. You can watch the progress in the little "progress bar" in the Copy Disk window.
  6. Once the original disk has been read into memory you'll be prompted toInsert the disk you want to copy to (destination disk)Now remove the original (source) disk from the drive and insert the copy (destination) disk into the drive. The click the OKbutton. You can watch the progress as the computer "writes" to the copy (destination) disk in the Progress bar in the Copy Disk window.
  7. When the copy is completed you'll see a new, small window popup that will report:The copy completed successfullyNow remove that copy (destination) disk. You are finished!
------- This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Nov 04, 2009 | Acard Technology (ARS-2030LD) DVD±RW...
XP Installation and win32k.sys
hi,
this problem is occured due to corrupt or scratched disk.
u need to install XP with new bootable disk.
Sep 18, 2009 | Microsoft Windows XP Professional for PC
Evesham explorer laptop,format,booted from disk,formatted partition ,reaches stage of copying windows files to folders but has been running for 5 hours..and files still not copied...
Change your windows disk.
Also delete all partition of harddisk and create partition again .
Then boot with disk.
Try this 2-4 times you done it.
Let me know if you need more assistanse.
Thanks.
Aug 28, 2009 | Computers & Internet
I am trying to burn a disk with my Dell 4300 Computer. When I in
1) Insert a Blank CD-R into your CD Drive and push the button to close the door.
2) Wait a moment for the What do you want Windows to do? box. If
this box does not appear, you can open the Windows Explorer by
double-clicking the My Documents icon or the My Computer icon
on your Desktop.
3) When asked What do you want Windows to do?, click Open
writable CD folder using Windows Explorer.
4) Once the Windows Explorer opens, click on the link on the left that
says My Documents to get to your My Documents folder.
5) To copy everything in the My Documents folder to CD, click Edit
and then click Select All. All the folders and documents on the
right will be selected.
a) Note: If you only want to copy certain files/folders to CD, hold the Ctrl
key on your keyboard to select only the files / folders that you want to copy.
6) Once your files are selected, click Copy the selected items on the
task pane on the left side of the window. (If you do not see these
words on the left, click the Folders button once.)
7) When the Copy Items box appears, select the CD Drive (D:) and
click Copy.
8) Once the files are finished copying, you will see a balloon in the
bottom right corner of your screen saying that You have files
waiting to be written to the CD.
9) If you are only copying you’re My Documents folder to CD, you
can click that yellow balloon to complete the CD burning process.
Note: If you do not see that balloon, wait a few more moments. If you still
do not see it, click on the My Computer link on the task pane on the left,
then double-click the D: drive. Then proceed with the next step.
10) Clicking the balloon will bring you to the D: drive and you will see
the files you have copied under the Files Ready to Be Written to the CD section.
11) On the left, click Write these files to CD.
12) You will be asked to type a CD name. This simply gives the CD a name and is optional (16-
character limit).
13) Click Next.
14) When the CD Writing Wizard is complete, your CD will be ejected and you will see a box telling
you that you have successfully written the files to the CD. Click Finish.
15) To ensure that the files have been successfully written to the CD, insert the CD again and wait a
moment. The CD and its contents should appear on your screen after a few seconds.
You can continue to copy files to this CD until the CD is full. When the CD is full, you will be told so by
Windows. CD’s cannot be erased. Once a file is copied to a CD, it is permanently there.
The files that you have copied to CD are Read-Only. This means that you cannot make changes to a
file on the CD and save those changes directly back to the CD. If you want to change a file on the CD,
you must open the file, save it to your PC’s hard drive (My Documents or Desktop folders are
recommended), then follow the steps above to copy the file back to the CD, clicking Yes when asked if
you want to replace the file on the CD with the new one.
Jan 17, 2009 | Dell Dimension 4300 PC Desktop
Microsoft Windows XP Professional for PC Logo
162 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
