Question about Cameras
Cannon Power Shot A560 tells me 'card locked' how do I unlock it?
  • Cameras Master
  • 4,738 Answers
Remove the SD card. Look on its left side for a tiny slide switch. Slide it to its other "unlocked" position. Reinsert the card and try it out.
Posted on Oct 22, 2008
How to fix card locked
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Aug 09, 2014 | Canon Silver Powershot A560 Digital Camera...
Memory Card does not work in our Cannon 6.0 MP Power Shot A540. Message says Memory Card Error - Card Locked.
Turn off your computer the remove the memory card. Look at the card, it should have a small tab on the side that could be slide up or down to lock and unlock it. Just adjust it opposite from its position now and it should be fine.
Hope this helps. Thank you for using FixYa.
Apr 25, 2011 | Cameras
Card locked
If this happened after the card had been removed then you may have inadvertently slide the card lock into the 'lock' position. If the card has not been disturbed, the very fragile 'switch' may be defective. I would try removing the card and operating the slide-lock several times and then leaving it in the unlocked position.
Jun 18, 2010 | Canon Cameras
Screen says card locked. How to unlock it?
There will be a small slidable portion on the SD card. By moving it back and forth u can unlock and lock the card
Thank u
Please rate me as it wil cost u just one click
Oct 23, 2009 | Canon PowerShot SD400 / IXUS 50 Digital...
Cannon power shot sx100is...view finder says "card Locked"
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Apr 15, 2009 | Canon PowerShot SX100 IS Digital Camera
Canon A560 will not erase pictures
Two possible solutions.
1. Apple users have reported that the switch on the memory cards performs the file lock function in either extreme positions Lock/Unlock. In some cases they have achieved success in centering the Lock/Unlock switch allowing access to the read/write operation of the memory card
2. Connect to PC
Access drive via windows explorer
Right click on drive (MEMORY CARD)
Select properties
Confirm that RO (Read Only) is not selected.
Selected RO
Try reading card
Repeat properties un-select RO
Try deleting files
If not successful card is likely defective
Hope this helps?
Mar 12, 2017 | Canon PowerShot A560 Digital Camera
Cannon power shot A560...how do you delete pictures
You can download the Basic and Advanced User Guides from the manufacturer's web site at http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=320&modelid=14904
Jan 27, 2009 | Canon PowerShot A560 Digital Camera
Canon Powershot A560
Remove the SD card from the camera. Slide the tiny slide switch on the side of the card to the other "unlocked" position. Reinsert the card in the camera. That should do it.
Sep 07, 2008 | Canon PowerShot A560 Digital Camera
Card locked
Greetings jdep,
On your card there is a small slide on the side that will lock the card and write protect it. Slide this to the unlocked position and you should have no issues resuming picture taking or deletion.
I hope this helps!
Thank you,
Dorothy
Go Ahead. Use Us.
Apr 24, 2008 | Cameras
Cameras Logo
82 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
