Question about Fisher and Paykel GWL11 Top Load Washer
Fisher pakel water saver washer non stop beeping in cycle
The washer beeps constantly and very fast at begginning of cycle. Is this a electical issue, or can I reset board somehow.
  • leafdesign Oct 21, 2008
    Grant,
    Thanks for your great suggestion. I was suspicious that the previous load was out of balance with towel weight. I unplugged for almost 30 minutes, we mostly because on the incessant beeping
    and it seems to be working properly again.
    thanks mch
    Laura
  • 46 Answers
Hi any of these beeps that occur outside normal operation are normally indicating an error picked up by the processor and most times requires service you could try switching off machine and unpluging it for a couple of minutes then plug it back in ,this ill ussually reset any memery faults if they are able tobe reset
cheers grant
Posted on Oct 21, 2008
Replaced computer in fisher and pakel top loading washer and still does not work. what is wrong??
does it beep at you? is it dead? if some lights are on while it's beeping, they are an error code, can you relay them to me?
Oct 11, 2013 | Fisher and Paykel Washing Machines
Dishdrawer stops beeps mid cycle
It could have fogged up because you had the drawer cover off in the first place.
The problem may be the alignment of the mirrors. If the control board has slipped down so that the mirrors do not line up to the photo cell and led---that can cause the problem you are having. Make sure the mirrors (light tubes) are properly lined up with the photo cell and led on the control board. You may have to move the control board to make this alignment. Once aligned secure the board in place and this should solve your problem. NOTE: MAKE SURE THE POWER IS TURNED OFF BEFORE YOU MAKE THIS REPAIR.
Aug 19, 2013 | Fisher and Paykel 24 in. DS-603 Built-in...
Dd603 stops mid cycle with no beeps or alarms
Please check if this happens with the short rinse cycle as well.
Also when the fast cycle stops, check if the water is cold at room temperature. Normally water temperature for wash cycles should be at leat 40deg C.
May 04, 2013 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher Paykel washing machine Smartdrive 703 Advance, Power and Start buttons are non responsive when pushed. Is there a part that can fix this. Does the control panel have to be replaced?
Fisher & Paykel Smart Drive beeps and stops during rinse cycle. If I hit pause and wait and restart it eventually continues. It seems like it has problems detecting water level.
Apr 13, 2011 | Fisher and Paykel GWL11 Top Load Washer
When i put the wash cycle on it goes and does fill up with water, but then when comes to spin cycle it stops agitating and starts beeping constantly with the light on where the "lid locked" icon is.. When...
Hi Ellie,Just read your posting.Now does your machine drain most of the water from the machine but it does not spin the clothes dry?Is this correct?Also does the mahine only show the lid lock icon when the machine is beeping?Please reply with additional information on the questions and I am sure I can help you.Looking forward to your reply.
Aug 17, 2010 | Fisher and Paykel GWL11 Top Load Washer
I have a fisher & pakel eocsmart cycle but when it gets to rinse it starts beeping and wont drain the water
We had that problem and is was because we had the hose (which is long) too far into plumbing drain it would set off a syphon effect and stop. Then it would start the beeping
Oct 28, 2009 | Fisher Paykel EcoSmart GWL15
Fisher pakel water saver washer stopped early in cycle and is non stop beeping
www.ths.gardenweb.com/forum/laundry
try this website. I found answers to my questions on it that i did not find here.
repairman who came to my house yesterday said manuals are only available on dvd, not in paper anymore.
saw on the other website that you can order FP parts through Sears. have not tried, so don't know if that is reliable. maybe you can order a FP manual through Sears to tell you how to fix your issue.
Oct 21, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher pakel washer taking too long to wash clothes
How long does it take to fill the tub? if the water, on warm stteting, isn't blasting out fast or if, when set to cold, it's trickling out, your cold water valve is shot. I can help with this problem 'cause I had the same experiences you listed.
Oct 13, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel (Old model) Fresh 5.0
you probably have a foreign object in the pump impellor - the favourite is bits of bra wire
May 05, 2007 | Fisher and Paykel GWL11 Top Load Washer
Constant dinging
Please explain "dinging". When the machine stops, does it give a series of beeps and produce a fault code. The fault code is normally identified by the lights ( led's) that flash on the display module when the machine faults. When you look at the lights from left to right each one that is off represents a 0 (Zero) and each one that is lit represents a 1. ie If lights are on off on on off off the code would be 101100. If you can give us the fault code, we will be able to tell you what the problem is.
Mar 08, 2007 | Fisher and Paykel IWL12 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
134 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
