Question about IBM Infoprint 1332 Laser Printer
Infoprint 1332 i have this printer with three trays. is it posible to have one print job print one sheet from each tray for colored invoice printiing so i dont have to buy multi color collated paper.
    Problem Solver:
  • 18 Answers
No. Purchase paper that comes in the colors you want (white, yellow and pink) then run 1 copy print job (from the pc) but set in the Paper Menu 3 copies (if you want 3 different colors) The printer can not do it for you, there is some $oftware out there that will do this but it is your $
Posted on Apr 05, 2010
In valid cartridge refill
Posted on Feb 10, 2010
How many pages per minute on a InfoPrint 1332
The InfoPrint 1332 has a maximum output speed of 35 pages per minute. This speed can be less if you are using thicker paper or paper that's not 8.5" x 11", and other factors can affect the speed as well.
Apr 14, 2010 | IBM Infoprint 1332 Laser Printer
Problem having paper size in tray 1>Excuvite,but i want trya1 A4,
All you need to do is adjust the size selector in the back of the tray to the correct size.
Jun 17, 2009 | IBM Infoprint 1332 Laser Printer
Load MP feeder.
It is in your setup menu, under "paper tray" settings or similar. set "MP tray" to "off"
Jun 15, 2009 | IBM Infoprint 1332 Laser Printer
PRINTER NOT PRINTING IN TRAY
Make sure the green part in the back of the tray is set exactly to the type of paper you are using. For example, make sure that if you are using letter paper, the paper size selector is set exactly on letter. if it already is try to move it off letter, and then line it up correctly again with letter.
Apr 03, 2009 | IBM Infoprint 1332 Laser Printer
Will not print to tray two message tray one empty stops
YOU NEED TO GO TO THE WEB MENU AND SET YOUR PRINTER TO AUTO SELECT TRAY AND SET BOTH TRAYS TO SAME EXACT PAPER TYPE
Feb 13, 2009 | IBM Infoprint 1332 Laser Printer
IBM Infoprint 1332 paper jam
one of the paper path sensors is blocked. check underneath tonner check if the sensor is playing freely.
Aug 19, 2008 | IBM Infoprint 1332 Laser Printer
Print Cartridge
Unfortunatly, no. This is the compatibility list for that part number: IBM2.gif InfoPrint 1352 / 1352n / 1372 / 1372n Laser Toner Printers
May 14, 2008 | IBM Infoprint 1332 Laser Printer
Infoprint 21 paper sticks exiting output tray
I replaced the rollers that come with the consumables kit and that fixed my problem.
Apr 22, 2008 | IBM Infoprint 21 Laser Printer
Printing from Other Drawers
this is the link to the manual if you need it http://publibfp.boulder.ibm.com/epubs/pdf/51024780.pdf page 47 shows how to manually describe the paper type in each tray - after that, when printing click on properties and select paper type - it should automatically select the correct tray - if you want the same paper in more than one trays, it will always use the first one first, then start using the others. Hope this helps :)
Mar 13, 2007 | IBM Infoprint 1332 Laser Printer
this is the link to the manual if you need it http://publibfp.boulder.ibm.com/epubs/pd... page 47 shows how to manually describe the paper type in each tray - after that, when printing click on properties and select paper type - it should automatically select the correct tray - if you want the same paper in more than one trays, it will always use the first one first, then start using the others. Hope this helps :)
Mar 08, 2007 | IBM Infoprint 1332 Laser Printer
IBM Infoprint 1332 Laser Printer Logo
124 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
