Question about Fisher and Paykel GWL11 Top Load Washer
Fisher pakel water saver washer stopped early in cycle and is non stop beeping
I have a 3 year old fisher pakel water saver washer, it sometimes does a intermittent beep when a load is unbalanced, although this time it is like a crazy really fast beeping, so annoying i had to unplug from the wall it was not stopping. Is there a reset button or something I can do to get the electronics board to start again. Now it doesn't let me stop or start anything.
any help would be greatly appreciated
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 22 Answers
Www.ths.gardenweb.com/forum/laundry
try this website. I found answers to my questions on it that i did not find here.
repairman who came to my house yesterday said manuals are only available on dvd, not in paper anymore.
saw on the other website that you can order FP parts through Sears. have not tried, so don't know if that is reliable. maybe you can order a FP manual through Sears to tell you how to fix your issue.
Posted on Oct 21, 2008
Replaced computer in fisher and pakel top loading washer and still does not work. what is wrong??
does it beep at you? is it dead? if some lights are on while it's beeping, they are an error code, can you relay them to me?
Oct 11, 2013 | Fisher and Paykel Washing Machines
Washer beeps as if unbalanced when in rince cycle and water is leaking a bit from somewhere, clothes are still damp. fisher and paykel
if it's leaking, take it somewhere to get checked, water and electronics don't end up mixing in a cheap way! the leak could be the pump or main seal. the unbalanced thing can be due to spring failure.
Aug 15, 2013 | Fisher and Paykel GWL11 Top Load Washer
F&P washer stops spin cycle
You will need to check the out of balance switch under the motor controller board for corrosion and replace if faulty.
May 24, 2013 | Fisher and Paykel Washing Machines
Hi, I have a WA75T65GW1 7.5kg top load washer. I run a favourites program with cold water cycle, auto level and fast spin. The cycle is getting stuck all the time between rinse and spin cycle, bowl is...
This problem will often occur with a light load of clothes. The beeping is usually the unbalanced load alarm. Often, redistributing the clothes around the agitator and moving the agitator manually up and down and side to side to center it again will fix the problem. You may need to advance a new cycle to where it spins out to empty the washer and run the laundry again.
Jul 30, 2011 | Fisher and Paykel Washing Machines
Fisher Paykel washing machine Smartdrive 703 Advance, Power and Start buttons are non responsive when pushed. Is there a part that can fix this. Does the control panel have to be replaced?
Fisher & Paykel Smart Drive beeps and stops during rinse cycle. If I hit pause and wait and restart it eventually continues. It seems like it has problems detecting water level.
Apr 13, 2011 | Fisher and Paykel GWL11 Top Load Washer
I have a Fisher Pakel washer GWL11 and it has developed a small leak under the washer. The cycle stops at rense and just quits. Any suggestions on what needs replacing?
Sounds like it could be overfilling Just a little and while it is agitating it will be splashing over, To fix this you will need to replace the MCU,
Jul 31, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher Pakel dish drawer sends F1 alarm flashing. It usually happens when there is a drop or change in water pressure. Have had 3 repairs on this disappointing product. Only repair person for Fisher...
F1 is a flood fault ir happens when the machine detects water on the base of the unit, to clear this fault you can remove the bottom draw and use a towel to clean up the water this should clear the fault, But usually there is only water on the base if the lid is not closing properly, this can happen due to you putting long utensils in and the lid cannot pull down or you have faulty lid actuators witch is probably the case and they wont pull the lid down correctly, So if the lid wont come down properly water splashes over the top and floods the base. :)
Jul 25, 2010 | Fisher and Paykel GWL11 Top Load Washer
Machine will not spin or drain water.
I have a problem with my MW512AU. Sometimes it drains after wash cycle, but sometimes it sticks when it goes to spin, doesn't get up to speed, water comes on for about 10 seconds and shuts off, and it tries to spin again. If I hit the wash progress switch it goes directly to final spin and works ok. I then have to run a 2nd wash cycle to rinse the clothes. I also noticed a buzzing sound when I turn on the power point, which lasts about 3 seconds before stopping. It will come back on every 3-4 minutes for 30 seconds. This is with the machine power switch off. It powers on normally.
Mar 13, 2010 | Fisher and Paykel GWL11 Top Load Washer
When the washer is pumping water in it makes a noise like the pump is starving for water. I have checked water flow through the lines and the inlet filters ar not stoped up.
The only thing I've ever had to replace on that model washer is the pump, and they go out all the time. You have to order it from fischer and pakel directly, and it is extremely easy to replace (can do it with no tools at all) Remove the wires from the pump. Ther is a plastic tab that releases it so you can turn it. Turn it 1/4 turn and it will come out. To get a pump call 888-936-7872 (fischer and pakel customer care)
Nov 26, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
128 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
