Question about Roper RAS8244KQ Top Load Washer
My Whirlpool Estate TAWB600EQ1 will not spin or agitate
My washing machine fills and drains just fine, it just will not agitate nor spin. Very aggravating as the laundry keeps piling up.
  • 5,911 Answers
If the washer does not agitate at all, does not spin, but will still drain, this is a symptom of a broken motor coupling.
The following link explains how to replace one:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
This is a very simple repair that doesn't cost much. The repair is actually much easier than you think and requires no special tools. The part number is included in the link I provided. Appliancepartspros.com carries a replacement motor coupling for about $11.
NOTE: A broken motor coupling is usually accompanied by a loud rattling noise. You can hear the motor engaging and running, but there is no tub action.
If you need an illustration, you can refer to the website I mentioned and locate item 13 under the Brake/Clutch/Gearcase/Motor/Pump section.
The motor coupling is located between the drive motor and the gearcase (transmission). It takes the place of a drive belt and commonly fails on Whirlpool manufactured top loaders due to normal wear and tear. This configuration is known as a "direct-drive" system. The replacement motor couplings are more resilient and resist breaking better, because the manufacturer added a steel grommet.
If you have any questions about this repair, or if you need additional assistance, please let me know. I hope you find this information helpful.
Posted on Oct 11, 2009
Whirlpool washer WTW57ESVW0 won't fill with water. I bought this machine two months ago was working fine and then just stopped filling water. Spin cycle and drain cycle work but it won't start fill...
Solution for WTW57ESVW0 Whirlpool Washer that won't fill or agitate, but will spin and drain water.
Replacing the Auto Load Sensing Switch (W10177795 - Illus. No. 12 on Control and Rear Panel Parts) fixed the problem.
In addition, a defective switch can also cause the machine to start agitating while it is filling.
It is relatively easy to replace and there are online videos that can help with the replacement.
Oct 27, 2010 | Washing Machines
My washing machine will not spin or drain,only fill up with water
Couple things could be happening;
Scenario 1: Your motor is dead, or the electrical connections leading to it are chewed up and no longer send electricity to the motor. If you have a voltage tester, you should see if you are getting power to it.
Scenario 2: The safety switch that stops the motor from spinning when the lid is open is compromised.. This is possible, but less likely, as the motor would still spin in agitate mode..
Jul 12, 2010 | Estate ETW4100SQ Top Load Washer
I got an estate whirlpool washer and it wont spin and i smell a burning smell
YOU HAVE SOMETHING STUCK IN THE WATER PUMP OR YOUR MOTOR COUPLING IS BAD
Jan 15, 2010 | Estate TAWX700JQ Top Load Washer
Washer stops after the tub fills, agitator and tub do not spin
Your lid switch is bad. If you give model number I can give you the part number you need.
May 18, 2009 | Whirlpool Washing Machines
Will not agitate
Replace the direct drive coupling. Directions are in the attached video.
Apr 03, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Washer keeps filling w/ water, only stops when changed to spin
Your drain line is too low.
OR the drain line is restricting air where it enters the drain stand pipe.
Remove the drain line and hold it up high.
Turn the washer on to fill. It should fill then stop.
This example should explain what you must do to correct the drain line problem.
Mar 12, 2009 | Whirlpool Washing Machines
Whirlpool TAWB600EQ1 - Washer
ck lid switch usually on right side of lid opening or on later models under back corner at lid hinge area
Aug 10, 2008 | Roper RAS8244KQ Top Load Washer
Estate by Whirlpool washing machine will not drain or go into spin mode in any cycle.
I would try and check voltage at the overload on the motor
when in spin cycle and see if you have power there..
 that should tell ya if your at least getting power from the timmer or not in the spin cycle to the motor
Sep 04, 2007 | Admiral AW22 Top Load Washer
Roper RAS8244KQ Top Load Washer Logo
742 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
