Question about Sylvania SRPD442 42 in. EDTV-Ready Plasma Television
Sylvania SRPD442 no picture
I have sound but no picture on my Sylvania SRPD442 plasma screen.
  • Andrew Zebrun
    Andrew Zebrun Jul 24, 2006
    Thanks, I'm taking it to Sears for repair!
    President:
  • 3,130 Answers
Your problem is probably in the power supply as theres a voltage called the sustain voltage that is always keeping the screen charged so the address lines will activate the screen and make it light up Via the Microprocessor and the video processor. This is not a repair for a handy person as this set, you can cause more problems Please seek out a trained tech for this set. Good luck
Posted on Jul 24, 2006
SOURCE:
When you start light turns green but go's back to red . sylvania 6842thg
DOES THE TV STAY ON ??DOES IT TURN OFF?...MOST CASES IS A FAILURE IN ONE OF THE POWER PROCESSING BOARDS..WHICH MEANS THAT HAS TO BE REPLACED..
Mar 18, 2011 | Sylvania SRPD442 42 in. EDTV-Ready Plasma...
Is my ILO 42" "EDTV" plasma ready for just a regular antenna?
No, it doesn't have a digital tuner. If you want to watch digital channels you will have to acquire a digital set-top box and connect it to the tv thru the av inputs.
Jan 16, 2010 | Sylvania SRPD442 42 in. EDTV-Ready Plasma...
Where is the cable antenna hole?
There is none, you need to use a cable or satellite box with this TV. It's a monitor with no tuner.
Oct 11, 2009 | Sylvania SRPD442 42 in. EDTV-Ready Plasma...
I have a Sylvania 42 inch Plasma HD TV. It is 3
Hello
Before taking this to a local repair person, I suggest you check with your cable provider. See if they are having trouble with their HD transmission and then have them test your lines. Out here in Arizona with have constant problems with HD due to heat, rodents and poor installations. Your DVR only recorded the problems that were on your set. If these prove fruitless then take the TV to a reputable repair person.
Good Luck
Sep 24, 2009 | Sylvania SRPD442 42 in. EDTV-Ready Plasma...
Picture but no sound Samsung 42 inch
go to the sylvania website,and go to support,there should be a section for manuals there and you can either download it or just read it online,hope this helps.
Dec 07, 2008 | Sylvania SRPD442 42 in. EDTV-Ready Plasma...
RED LINE
If the line is vertical in nature then most likely then the plasma display panel is bad and won't be worth fixing because of cost. If the line is horizontal then the issue might be a lower or upper Y-buffer module.
Jun 08, 2008 | Sylvania SRPD442 42 in. EDTV-Ready Plasma...
Sylvania SRPD442: picture has lines and particles in it, can't make picture out
The fault can be the screen itself, or one of the driver boards for the screen. This has to be verified by trying the boards.
I don't know for your model if the backplane lamps can be replaced. In most of the models they can be.
Jerry G.
Nov 21, 2007 | Sylvania SRPD442 42 in. EDTV-Ready Plasma...
SRPD442 TV WILL NOT DISPLAY PICTURE AND WILL NOT SHUT OFF
This can be many types of faults. The set will need shop service. There may be cold solder connections on one or some of the boards, or there may be come components that are intermittant. In anycase most of the time, there will be the need for board replacments.
The cost for this type of repair can be fairly expensive. I would consider investing in to a new set because after having this serviced, there will still be many older components in the set that can potentialy fail.
Jerry G.
May 22, 2007 | Sylvania SRPD442 42 in. EDTV-Ready Plasma...
in this model, the ribbon cable conection fail many times, and tis sound to be the problem, just open it and secure all sokect conection better get a tech to do it ...good luck
Aug 09, 2006 | Sylvania SRPD442 42 in. EDTV-Ready Plasma...
TV goes on for minute, and then goes to standby
This could be anything but is more than likely a problem in the power supply or control board. There really are not any user serviceable parts in these units and they have dangerous voltages. Repair is best left to a professional.
Jun 15, 2006 | Sylvania SRPD442 42 in. EDTV-Ready Plasma...
Sylvania SRPD442 42 in. EDTV-Ready Plasma Television Logo
201 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
