Question about Koss CDR200 2-Disc CD Recorder
Koss cd recorder won't open
Turn player on, or press open a or b, sez "reading", then "A no disc", then ----, ----, and that's it, what's up with that? I'm not positive, but I'm pretty sure there are no discs in unit.
  • sdnycook Jan 09, 2009
    i have the same problem and i dont know if i need to take it to the shop
  • cowboy red Apr 14, 2009
    I TURN ON MY KOSS CDR200 2-DISC CD RECORDER AND A SHOWS NO DISC BUT B DOES NOT SHOW ANYTHING AND TRAY A AND B DOES NOT OPEN AT ALL.
5 Suggested Answers
dsom
  • 56 Answers
SOURCE: I can not get my CD recorder to record
You should use consumer cd's that are rather expensive. You probably tried to record a recordable cd-rom (a cheap computer disc). It's not possible to burn a pro-disc (computer disc) by using your Pioneer, and that's why you got that message on the screen. Refer to the user manual of your cd recorder and learn what sort of blank cd you should use.
Posted on Aug 07, 2007
shanth
  • 108 Answers
SOURCE: KOSS CD player will not read CD says '' no disc
1.Your Disc might be damaged
2.Your cd player laser beam reader lens might be weak or dead
3. Check whether it happens to all Disks
4. if it does not play all the disks then you have to change the laser diode lens assemble.
5. contact service centre to fix news lens
Posted on Dec 22, 2007
  • 112 Answers
SOURCE: koss cdr200 dual burner
I had an issue similar to this - I found if I didn't try to record from the internal player it worked ok. Does it say 'recover' when you try to record anytime? If you open the unit,you might see some capacitors on the power supply on the left hand side have leakedand the power is cutting in and out. 'Recover' usually comes up when a recording is interupted if you switch the unit off during recording.
Posted on Jan 15, 2008
  • 99 Answers
SOURCE: I get a "Data Disc" message when I press record.
have you purchased the correct blank discs? sounds like you've inserted discs that can only be used on a PC. these players can only record onto blanks bearing the "compact disc digital audio" mark. these are for use on home audio recorders. hope this helps?
Posted on Jun 15, 2009
I am unable to engage the record button, the display reads "unreadable or unrecordable disc"
There are several types of blank discs (CD-R, CD-RW). This unit only handles the CD-R discs. Unfortunately, this particular unit is even fussy about the CD-R discs it does accept. Even more unfortunately, there is no way to determine which will be accepted and which will not work. At this point, I can only advise you to try CD-R discs from a different manufacturer. Read the first review on amazon.com. Same issue I have had. Sorry and good luck.
Jul 24, 2011 | Koss CDR200 2-Disc CD Recorder
Can I record from a cassette player to the koss
should be able to go directly from tape out of cass deck to input of your koss, as long it has line level inputs (which it should). from there its play on the tape and record on the cd rcrdr. seems the simplest solution
Jan 30, 2010 | Koss CDR200 2-Disc CD Recorder
KOSS CDR 200 RECORDING
Yes, but you, like I could use an owners manual for this thing, as it isn't as easy to operate as the Philips Audio CD recorders. Owner's manual anyone?
You can just press input select for analog, press record, wait then press 'play' to start recording.
Aug 04, 2009 | Koss CDR200 2-Disc CD Recorder
Recording
Willthe b deck playback a normal cd? Sounds like your record laser is gone. It's a philips laser and they are known for it.
Jan 23, 2008 | Koss CDR200 2-Disc CD Recorder
KOSS CDR200
can I record from an outside source, like a casset player to cd, on the cdr200, if so, how, thankyou
Nov 25, 2007 | Koss CDR200 2-Disc CD Recorder
Koss cdr200 dual burner
Aug 28, 2007 | Koss CDR200 2-Disc CD Recorder
Koss CDR200 2-Disc CD Recorder Logo
Top Koss Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Steve K
Rick
Are you a Koss Audio Player and Recorder Expert? Answer questions, earn points and help others
